This is a discussion on Slower with CAI? within the Octavia I forums, part of the Skoda Model Discussion Area category; Hey all. Just fitted a c.a.i that was off my previous car, I dont know weather its just me, but ...
| Hey all. Just fitted a c.a.i that was off my previous car, I dont know weather its just me, but it feels a bit slower. Could this happen?, or is it that im getting used to the power( ive had the car just over a week). Or maybee its just the warm weather. I dont know. I suppose the only way to tell would be a trip to the rollers. |
| Have you cleaned the filter?
__________________ Unit 18 Automotive Services now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| Yes, cleaned it out with an air blower, and oiled it aswell |
| Hopfully not to much oil.
| No, just a light misting. |
| Briskodian Join Date: Nov 2003 Location: Walsall, West Midlands
| what make of CAI is it? some "cheaper" makes off EBay have been known to cause problems on the 1.8T engine.
__________________ Sea Grey Mondeo Titanium X |
| | #8 | |
| "COFFIN DODGER" Join Date: Jan 2005 Location: South East
| Quote:
| Briskodian Join Date: Mar 2006 Location: Newcastle
| the carbonio from awesome arrived on my doorstep this morning. hope its makes a difference then
__________________ sigs are un-cool |
| | #10 |
| Briskodian Join Date: Dec 2005 Location: North West England
| Isn't a CAI just a lengthened tube with an air filter on the end? Wouldn't a flexi-hose to the radiator grille and sealed over the inlet pipe do a similar job?
__________________ Mk1 Octavia vRS. The thinking man's Hot Hatch. PS. Give Cyclists Room! We're quite vulnerable. If I can slap your window, you're too close |
| | #11 | |
| BRISKODA Staff Join Date: Oct 2002 Location: darkest Hampshire
| Quote:
My CAI uses the standard air inlet route from the wing....I have suplimented this with a flexi hose inputting from the lower lhs grill and into the filter heat shield. The vast majority of CAI are a length of pipe with a filter...filter usually is placed behind the lhs headlamp.
__________________ Adrian. | |
| | #12 |
| NOW @ PEUGEOT Join Date: Nov 2003 Location: Bicester,Oxfordshire
| My Carbonio works just fine Phil
__________________ 1)RED ONE, FEW MODS; AND A HEALTHY 237bhp 2)GONE BUT NOT FORGOTTEN, 2ND OWNER OF THE BLACK BEAST, GOD WHAT A HOOT ![]() LACK OF PLANNING ON YOUR BEHALF DOES NOT CONSTITUTE AN EMERGENCY ON MINE |
| | #13 |
| Mine was a ripspeed, It was a cotton filter enclosed in a carbon fiber shroud thingy. It was £90. I have just put a k&n panel filter in now. Not as loud. |
| | #14 | |
| Quote:
the 'grille' in the lower passenger side doesn't have any holes in it! It could do with a few adding to it.
__________________ Mk1 Octavia vRS. The thinking man's Hot Hatch. PS. Give Cyclists Room! We're quite vulnerable. If I can slap your window, you're too close | |
| | #15 | |
| Quote:
I have a Jabbasport CAI which has a heat shield around the filter and makes a seal with the bonnet.....I have the flexi tube plumbed into the heat shield. Yes....I had to drill out the lower lhs grill...forgot about that. ![]()
| | #16 |
| ah, ok. I purchased a 3m length of 100mm ducting from a certain large DIY store on the way home from work (-only a fiver), but realise that it's a bit wide and probably don't quite need that much ! As the Turbo heats the air will there be much point in attempting to collect slightly cooler air from the lower bumper region? Looking at the inside of the top of th air box there is a removable 'ram pipe'. I assume that is better left in place to help with smoothing the air flow rather than having a step-change in cross-section (memories of lots of equations containg COSH terms....) at the MAF inlet although the effective area of the air filter is reduced considerably. I'm slightly tempted to remove the grilles from the MAF housing.
__________________ Mk1 Octavia vRS. The thinking man's Hot Hatch. PS. Give Cyclists Room! We're quite vulnerable. If I can slap your window, you're too close Last edited by MC Bodge; 13-05-2006 at 09:32. |
| | #17 | |
| Briskodian Join Date: Nov 2003 Location: Hampshire
| Quote:
) that the idea here is that the colder the air you initially suck up, the more dense it is (therefore more oxygen it contains per unit volume).So regardless of whether it expands again via heating as it passes through the turbo, you should still have more air entering the block if it is colder to start with? However I suspect that on the road, it makes no noticeable difference and might only account for a child-sized handful of horsepower when measured on a rolling road. I think I would be more tempted to take your £5 ducting and see if you can route it from the front air intake to around the back of the engine and have it blasting some cool air (when moving at speed) directly at the turbo/manifold to take some heat out of it during operation.
__________________ Lee Want to be carbon-neutral while driving? Hold your breath! | |
| | #18 |
| The main difference should be "seen" when on the move...sitting in traffic your shouldn't really see any real difference if any at all due to the air essentially being at ambinet temp....heat shields/filter encasements will reduce heat soak temps but not by great. Rolling road may not seen gains as expected as you're not really getting the amount of air as per on the road.
| | #19 | |||
| Quote:
The oxygen:nitrogen ratio will be almost the same whether it's cold or hot. The density of both will change. Quote:
__________________ Mk1 Octavia vRS. The thinking man's Hot Hatch. PS. Give Cyclists Room! We're quite vulnerable. If I can slap your window, you're too close | |||
| | #20 |
__________________ Mk1 Octavia vRS. The thinking man's Hot Hatch. PS. Give Cyclists Room! We're quite vulnerable. If I can slap your window, you're too close Last edited by MC Bodge; 20-05-2006 at 23:59. |
