This is a discussion on Strut brace.... within the Octavia I forums, part of the Skoda Model Discussion Area category; No doubt been covered a dozen times, but i'm after a front strut brace, anyone got any recommendations as to ...
| Briskodian | Strut brace.... No doubt been covered a dozen times, but i'm after a front strut brace, anyone got any recommendations as to the most suitable make / price and where from? Cheers Guy |
| Briskodian Join Date: Dec 2007 Location: Oxford
Members Car: Octavia vrs Thanks: 3
| Re: Strut brace.... I have an Audi S3 Strut brace on mine. I bought mine second hand form another member on here for £30 but I believe you can buy them direct from Audi dealers for not a lot more. You do need to drill holes in the metal at the top of the struts so that you can put some bolts through. ![]() |
| Briskodian | Re: Strut brace.... Last edited by gixxaboy; 12-07-2008 at 23:29. |
| Briskodian | Re: Strut brace.... Why would you want to fit one of these? The Octy's handling gives understeer as standard and by fitting a rear ARB the car becomes more neutral and with good coilovers (KW V3's) gives much better body control with a very good ballance. When set up right, no understeer or oversteer just 4 wheel slides. Why would you want to dial the understeer back in by fitting a brace when thats what you've paid good money to get rid of? It really is not required nor beneficial in my opinion. I see in another post your going the ring. Mine is set-up for the Nurburgring and is going for the 3rd time in 3 weeks and I would't fit a strut brace to mine. Everyone to their own tho eh.
__________________ There's nothing like seeing feathers going in the opposite direction to the bird! ....................................... Last edited by Octavia Vrs!; 12-07-2008 at 23:56. |
| Silver bullet Join Date: May 2003 Location: Planet Earth......
Members Car: 345bhp Silver Octavia vRS Thanks: 48
| Re: Strut brace.... The top brace is for show IMHO. The lower brace is quite effective though.
__________________ The silver bullet Jabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.![]() |
| Briskodian | Re: Strut brace.... Ta for the advice. I'll see how it feels just on the coilovers that are going on next week, and then i'll try the brace, and see what it feels like then. I'm new to the car set up lark TBH, so any ideas and opinions are welcomed! If the brace feels ****e, i'll sell it. Unlike bikes, getting decent suspension etc for cars is quite cheap, so i don't mind playing with ideas and stuff, and if they don't work, going back to the drawing board. How did you set the car up for the Ring? I found the Octy as standard handled OK but lacked that low down punch. I felt it needed body roll ironing out (although compared with other cars it felt minimal), and was wondering how you go towards minimising the understeer with coilovers. Cheers! |
| Briskodian | Re: Strut brace.... Like bike suspension you get what you pay for. Ohlins for bikes is much like KW for a car. A set of KW Variant 3's for the Octy cost £1000 so NOT CHEAP. Things like Jamex and your wasting your money - not saving it, dampers will blow in no time and the set-up not controlled due to minimul if any testing and development on the car. A freind almost bought a cheap set of coilovers for an Alfa 147GTA untill we realised it was the same part number for a 1.6 litre engine as the 3.2 V6 gta. They would not of controlled the extra weight of the V6. The best place to start on the Octy is a rear anti roll bar. This will make more difference to body control than the coilovers alone will and removes 90 percent of the understeer the car produces as standard. Next is a DECENT set of coilovers and finish off with uprated bushes to make suspension joints tighter. This will give a good balance and with the KW's changing damping rates via the valves for bump and rebound you can make it handle how you like. The Cheapest set of coilovers I would put on the Octy are Weitecs - a budget KW. Remember the ring is the bigest test of any car and short falls will be apparent very quickly. After 3 years I've got mine just about as good as I believe the Octy can get, considering it does not have independant rear suspension. Anything else is a waste of money really. As stevie says the lower brace I believe can make a difference but I have not tried it as the ballance is just about perfect now. Remember you'll have to drill your struts for the top brace so not really a good if I dont like it i'll remove it case. The front of the octy is quite stiff with next to no strut movement - Its pointless. Also a bump on one wing can destroy both struts .
__________________ There's nothing like seeing feathers going in the opposite direction to the bird! ....................................... |
| Briskodian | Re: Strut brace.... cheers mate, i'll give em' a go, if they are ****e then so be it. Gotta start somewhere I suppose |
| strut brace What are they and what do they do? | craig0031 | Fabia I | 17 | 14-06-2008 21:56 |
| strut brace?? | daveclayton | Fabia II | 1 | 14-05-2008 15:34 |
| strut brace | ns_sullivan | Fabia I | 8 | 13-05-2008 10:34 |
| Seat Strut brace vs. Forge brace | jasc1988 | Fabia I | 13 | 25-02-2008 23:50 |
| Strut Brace | uwoodd | Fabia I | 9 | 22-05-2005 10:08 |
