This is a discussion on Stuck in reverse within the Octavia I forums, part of the Skoda Model Discussion Area category; Can't get my manual Octy out of reverse gear. Was all fine, no clutch problems or selector issues before hand. ...
| Briskodian Join Date: Feb 2004 Location: Cambs
Members Car: Octavia SLX TDI HB 99(T) & Ford Puma 1.7 01(Y) Thanks: 0
| Can't get my manual Octy out of reverse gear. Was all fine, no clutch problems or selector issues before hand. Any ideas how to get it out??? Thanks Ken |
Members Car: Octavia 2001, 110TDi Elegance estate Thanks: 0
| Re: Stuck in reverse Check that no hoses, etc have got jammed in the linkage above the gearbox..... |
Members Car: Black Magic Fabia vRS Thanks: 360
| Re: Stuck in reverse Didn't Jason manage to jam his 'box when the inside cover for his headlight fell off into the engine bay...?
__________________ |
| Re: Stuck in reverse headlamp covers are nice and big. Pretty sure that someon (with a TDi - maybe) got the small (little finger sized) air hose from the filter box jammed.... |
| Re: Stuck in reverse Thanks for the suggestions, I'll check :>) I did look last night but no hoses seemed to be in the way. |
Members Car: Audi S3 Thanks: 145
| Re: Stuck in reverse Any news?
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| Re: Stuck in reverse all looks clear nothing in the way of the gear lever mechanism or the gearbox. both cables thro the bulkhead look ok. I suspect it might be the mechanism on the gear box but not sure how it should look normally. Thanks Ken |
| Re: Stuck in reverse Thinking about, Mark had a small piece of plastic brek on his that prevent selection of gears..... about 6 months ago? |
| Re: Stuck in reverse on top of the gearbox? |
| | #10 |
| Re: Stuck in reverse You could try taking the linkage off the top of the selector on the box and see if it's a linkage or gearbox problem.
| | #11 |
| Briskodian | Re: Stuck in reverse As Matt said I had a piece of plastic that held the selector to the wire break on a previous car, but it is kind of obvious. Have you tried putting some WD40 on the selector over night and some suitable grease or similar on the ball at the base of the gear stick? I'd say worth a shot before you start looking at the more expensive options. It might be worth trying to take the handbrake off and gently rocking the car in gear. IIRC we did this to a friends uni banger to get it out of a gear it was stuck in.
