This is a discussion on Swapping steering wheel - easy job? within the Octavia I forums, part of the Skoda Model Discussion Area category; Hello all, Does anyone know what is involved in swapping steering wheels on an 2002 Octavia? The current airbag will ...
| Briskodian Join Date: Aug 2005 Location: North London
Members Car: Octy 4x4 1.8T Elegance Hatch Thanks: 34
| Swapping steering wheel - easy job? Hello all, Does anyone know what is involved in swapping steering wheels on an 2002 Octavia? The current airbag will be going back into the new steering wheel - is it just a case of remove airbag cover, remove airbag module (presumably after disconnecting the battery??), undo large nut ? put new wheel in place, put airbag back in and replace cover?Any help would be greatfully recieved. ![]() Cheers, Lee
__________________ ![]() Thanks to JKM: REVO STAGE 2+ remap, Evoms CAI, Piper Turbo back Exhaust, Autotech Fuel Pump, Torque Arm Insert, Forge Recirc, Neuspeed Turbo & Intercooler pipes, APR FMIC, Iridium plugs, Koni FSD's, Eibach springs, Eibach F + R anti roll bars. VF short shifter. 345mm Brakes. 280BHP & 330LB/FT - enough room for a proper trip to B&Q and 36mpg on a run!!! |
| Briskodian Join Date: Jun 2004 Location: West Yorkshire
Members Car: Audi S8 Thanks: 41
| Re: Swapping steering wheel - easy job? It's easy. You need a screw driver and an M12(IIRC) spline drive. The airbag and cover are one unit. To remove the airbag you to turn the wheel a quarter turn from centre and you will find a hole on the back of the wheel, insert a screw driver and release the clip. Then turn a quarter turn from centre the other way and release the 2nd clip. Return the wheel to the centre. Disconnect the battery, unplug the airbag. Undo the bolt, swap the wheel, refit bolt. Plug airbag in push into place making sure both clips click into place, reconnect battery. Do this at your own risk and take sensible precautions.
__________________ EddyH Audi A6 Avant 2.7 TDI Audi A3 2.0 TDI Sport |
| Re: Swapping steering wheel - easy job? Remember to leave the battery disconnected for 15 mins before disconnecting the airbag. |
| Briskodian | Re: Swapping steering wheel - easy job? Got my Golf R32 wheel swapped over by someone who works at Skoda dealer. Took him no longer than 5 mins, as didnt even bother disconnecting the battery for the airbag reason. I was shocked, but he said you didnt need to do that |
| Briskodian Join Date: Nov 2005 Location: West Mids UK
Members Car: Octy 1.8T 4x4 Hatch Thanks: 11
| Re: Swapping steering wheel - easy job? Be warey that even a disconnected airbag CAN go off on it's own!
__________________ 1.8T 4x4 Black Hatch |
| | #6 | |
| Re: Swapping steering wheel - easy job? Quote:
Can you imagine anyone transporting one that 'could' go off? | |
| | #7 | |
Cheers
__________________ 1.8T 4x4 Black Hatch | |
| Re: Swapping steering wheel - easy job? I have set many off before (used to be policy before returning them). Agreed static 'could' set one off so i guess you are correct. New airbags are delivered in anti static wrapping usually. |
| Re: Swapping steering wheel - easy job? Cheers for the advice guys - the airbag going off was my worry I guess. If I disconnect the battery for 30 + mins I hope that should cover things. By the sound of it I'd better put my PC building anti static wrist strap on too! Cheers again, Lee
