This is a discussion on tail light within the Octavia I forums, part of the Skoda Model Discussion Area category; on my octavia reah lh tail and front position ligt do not work i check fuse, bulbs and they are ...
| Briskodian Join Date: Dec 2007 Location: Dublin
Members Car: 2003 Octavia VRS (180bhp) Thanks: 0
| Re: tail light Are you sure the fuse is ok (it's one of the 5amps on the top left of the fuse board). The front side light and the rear tail light are common to each side (ie. RH front and RH tail are on the same wiring & fuse). If the fuse is ok then you probably have a break in the wiring which you'll have to trace. |
| Briskodian Join Date: May 2007 Location: Trimsaran, Llanelli
Members Car: Octavia 1.9 SDI Thanks: 2
| Re: tail light Just a thought, have you checked the brake light sensor switch on the pedal? I know that on my previous car that stopped the lights working, can also cause them to stay on. Not sure where it is on the Octy but try searching for a post on here someone must know about it. |
| Tail light spray | Mil | Fabia I | 16 | 07-06-2006 01:11 |
| facelift tail light on ebay | RallyRed | Fabia I | 0 | 04-05-2006 02:23 |
| Tail Light change in 2001? | 150HP&counting | Octavia I | 5 | 21-04-2005 13:47 |
| Tail Light Covers | Marki | Octavia I | 0 | 09-03-2005 22:17 |
| Fabia Offside Tail light - which fuse? | neild | Fabia I | 1 | 09-12-2004 15:59 |
