This is a discussion on TDI (110bhp) waterpump - anyone had fail ? within the Octavia I forums, part of the Skoda Model Discussion Area category; HI has anyone had or heard of octy 110 tdi (ASV) waterpumps failing ?? I take it they are the ...
| Briskodian Join Date: Jul 2005 Location: west midlands uk
| HI has anyone had or heard of octy 110 tdi (ASV) waterpumps failing ?? I take it they are the dreaded plastic impellor type ?? I'm having my belt etc changed next week and dont know if I should have another genuine part fitted or get an aftermarket one - but I read on here that GSF no longer do metal impellor pumps ?? thanks ![]() |
| C+ à Paris! Join Date: Sep 2003 Location: Tilehurst, Berkshire
| IIRC, it's often recommended to change the water pump when you do a cambelt change, so that may be an indication that they are prone to failure over time ![]() Not sure about plastic / metal impellors though so can't advise on that, sorry ![]()
__________________ Xavier |
| I don't know specifically about the 110, but a mate had the impeller on his 90 fail a couple of months back. Said mate's garage now thinks he knows a psychic, since I fingered the exact cause of his overheating problem from 500 miles away. As for the why of changing both together, you have to do most of the same dismantling for the water pump replacement as for the cambelt, so changing them both together saves time and money. Hence, when there are known issues with the plastic impeller pumps... |
| The Following User Says Thank You to KenONeill For This Useful Post: | octywagon (04-06-2007)
| Briskodian Join Date: Jul 2006 Location: South Birmingham
| To be safe i would have the metal impeller water pump installed.
__________________ Support Briskoda----------------------> ![]() Red Skoda Octavia V//RS Mods to date: Carbonio CAI Forge 007 DV Aero Wipers Briskoda Stickers KVW100 GB Wheel Inserts RS Tuning Remap Delocked Piper Cat Back Kenwood KDC-W6541U Fli Twin 12" Active Sub Parrot CK3100 ------------------------------------------------ ![]() |
| Not heard of problems on the TDI. This may be due to lower revs. I would definitely change it since IIRC using genuine parts it added £35 to the cost of the cam belt change. If the pump was to fail after the change you would be looking at a minimum of the labour for the cambelt change again. If you are using all genuine parts then I would also use a genuine water pump due to the warrenty that is associated with this.
| The Following 2 Users Say Thank You to cheezemonkhai For This Useful Post: | Chris Adams (04-06-2007),
