39,348 Members 1,485,741 Posts
Under steer in Octy 4x4
This is a discussion on Under steer in Octy 4x4 within the Octavia I forums, part of the Skoda Model Discussion Area category; In general I'm very happy with the handling of my 4x4 and if accelerating through corners it's very planted and ...
Old 19-04-2005, 12:04   #1
EddyH's Avatar
Members Car: Audi S8
In general I'm very happy with the handling of my 4x4 and if accelerating through corners it's very planted and on roundabouts it's very easy to induce a little over steer to power round with.
However last night on a very long bend, exit slip road which is almost a full circle I got to the point where I couldn't apply any more power and had to hold a constant throttle. At this point I think the haldex disengaged and the car felt a little twitchy and like it was about to under steer.
Any ideas if there's any mods I can do excluding coilovers which could improve this. Current chassis setup is: H&R springs, R32 front ARB, Powerflex bushes up front, uprated dogbone and upper engine mount, 18x8 wheels with 225/40/18 Goodyear Eagle F1 GSD3 tyres.
I would really like a rear ARB but AFAIK there isn't one that'll fit the 4x4 due to the spare wheel well. A little more feedback would be nice as well, after fitting the F1's grip is much better but there is a little less feedback than the Ultrac's.
EddyH
Audi A6 Avant 2.7 TDI
Audi A3 2.0 TDI Sport
EddyH is offline
Old 19-04-2005, 12:06   #2
DGW
BRISKODA Staff
DGW's Avatar
Have you sorted the Haldex ECU out yet, Eddy, or is it still showing a memory error? (Just wondering if the Haldex is working as advertised).
Denis
DGW is offline
Old 19-04-2005, 12:11   #3
Site owner
ColinD's Avatar
Members Car: Roomster Scout
Images: 3
Correct Rear ARB is unique to the Octavia. StuartJ was / is looking to get one made.
Haldex as you know works on slip detection. I had a huge understeer with mine on Pembry. Was slighlty off line and just went, classic understeer onto the kerbs. Jon (TaviaRS) had some flow charts I was using to tweak the setup when I was on coilovers. I got it (standard arb's) to the point of almost being oversteery...
I think you have to take stock of where you were, speed and what you have. On a recent Porsche chase upto about 120 before a sharp right hander 40 max we were doing well...where the prosche went round the corner like he was rails I had odd smells and flashing ESP lights and a hint of the rear end on my mirror...no way I could follow the porker round that bend at the same pace. Have to take my meal ticket and get in line, no way the Octy will do what that porker did.
Did it actually understeer? IIRC on mine if it got to that point I could lift slighlty to upset the balance then apply, the logic being that the esp and haldex would kick in.
ColinD
1.9 Scout Roomster - Standard
www.BRISKODA.net :: Site Owner
E-Mail : webmaster at briskoda dot net
Got a comment to make about the site? Please feel free to use the feedback form here, we welcome your views.
ColinD is offline
Old 19-04-2005, 12:13   #4
EddyH's Avatar
No, not sorted yet, and something that did cross my mind. Hoping to get this sorted soon but I'm waiting on responses from others before it can be moved on.
EddyH
EddyH is offline
Old 19-04-2005, 12:24   #5
EddyH's Avatar
It wasn't going 'that' fast so was a little suprised at the car feeling twitchy, it didn't actually under steer, I just held it at that point but it felt like it was ready to break away. ESP didn't kick in at all. However this is the time I've experienced this, thinking back prehaps the bend had adverse camber. I certainly wasn't worried that I was about to loose control just I'd like to improve this characteristic if possible and take similar bends with a little more speed.
EddyH
EddyH is offline
Old 19-04-2005, 12:45   #6
stathap's Avatar
Members Car:
Eddy,
Won't a stiffer front ARB than standard without a rear ARB to match make it understeer more ? I'm sure you don't want to take the R32 one off though
"Classic" Black Magic
stathap is offline
Old 19-04-2005, 12:49   #7
Om nom nom nom
Neo_VR's Avatar
Members Car: A White Car
What about one of those fancy EIP haldex controllers?
ColGod the UberMod
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 19-04-2005, 12:57   #8
BRISKODA Staff
SkodiRS's Avatar
Members Car:
Originally Posted by stathap
Eddy,
I'm sure this is too simplistic an explanation?
I always thought if the front was a lot softer relative to the rear you were more likley to understeer.....i.e there is more give and then physics kind of take over and a lot stiffer rear lends itself to oversteer.
Or something like that.
Adrian.
SkodiRS is offline
Old 19-04-2005, 13:09   #9
EddyH's Avatar
I'm considering one but I don't think it will help on this type of corner as it will still only engage if the fronts are spinning or if I put my foot down.
EddyH
EddyH is offline
Old 19-04-2005, 13:19   #10
stathap's Avatar
Members Car:
Adrian
Did you just say
Softer front than the rear = Understeer
Stiffer rear than the front = Oversteer
Am I missing something ?
stathap is offline
Old 19-04-2005, 13:24   #11
EddyH's Avatar
Eddy,
If the rear is 'rolling' and the front isn't then yes you're right. That's why I want to stiffen the rear up. I'm gonna find out if uprated ARB bushes are available for the 4x4 in an attempt to improve the rear in the absence of an uprated ARB.
EddyH
EddyH is offline
Old 19-04-2005, 13:25   #12
EddyH's Avatar
Adrian
Did you just say
I noticed that too!
My understanding is stiffer front = understeer, stiffer rear = oversteer (but usually only induced by lifting off).
EddyH
EddyH is offline
Old 19-04-2005, 13:29   #13
BRISKODA Staff
SkodiRS's Avatar
Members Car:
Adrian
Did you just say
Yeah....I know where you're heading with this Pete...but it's not as simple as that.
Difficult to describe....and not that I fully understand it ..where's that damn flow chart I got from Jon.
Adrian.
SkodiRS is offline
Old 19-04-2005, 13:51   #14
stathap's Avatar
Members Car:
I wasn't good at dynamics at school Adrian but I like this concept of tire lateral load tranfer distribution
"..... one might even assume that a firmer anti-roll bar, which leads to better camber control, would lead to better traction. If we add a firmer anti-roll bar to the front, traction loss diminishes, so understeer is reduced, right?
Wrong. Let's evaluate more closely the meaning of TLLTD--tire lateral load transfer distribution. Stated another way, we might describe TLLTD as the relative demand of side-to-side energy control that is placed upon the tires. Because a firmer anti-roll bar allows less deflection, it will transfer side-to-side energy (lateral loads) at a faster rate.
As the rate of lateral load transfer increases, additional demands are placed upon the tire. So if we install a firmer anti-roll bar in the front, then we increase the distribution of lateral load transfer toward the front tires. This increases the front TLLTD value, which will result in additional understeer, holding all else constant.
The same logic also holds true in the rear. A firmer anti-roll bar in the rear will increase the rate of lateral load transfer, placing more demand upon the rear tires, accelerating lateral traction loss and creating more oversteer, holding all else constant.
This is why blindly adding parts to your car may not produce the desired results. A wise consumer consults with--and buys from--knowledgeable experts that have the tools to make informed tuning recommendations...."
the full story is here ARBs
Now I now a lot of stuff on the net is pap but I still think that
stiffer ARB on front = increased understeer
stiffer ARB on back = increased oversteer
but i would love to be wrong
stathap is offline
Old 19-04-2005, 13:55   #15
Dinosaur
TaviaRS's Avatar
Members Car: Merc E class & SLK
Was it a right hander per chance? If so, I reckon it wpould be the change in wheelbase that did it (hint, when the wishbone bush is FUBAR, the wheelbase will change as the wheel will move back and forward as well as up and down) HTH
Adrian, do you mean this or this?
A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast.
Official mobile chicane for Briskoda trackdays
TaviaRS is offline
Old 19-04-2005, 14:01   #16
EddyH's Avatar
It was a left hander. I'll have to try it again when the wishbone bush is sorted.
EddyH
EddyH is offline
Old 19-04-2005, 14:02   #17
BRISKODA Staff
SkodiRS's Avatar
Members Car:
Aha....now this make sense and would eplain why on standard set-up the car understeers and then when adding the ARB understeer is reduced.
But going overly stiff at rear, as in stiffest setting on Neuspeed ARB, produces oversteer.
Cheers.
Adrian.
SkodiRS is offline
Old 19-04-2005, 14:05   #18
stathap's Avatar
Members Car:
Cheers.
Adrian you've battered me, you win
stathap is offline
Old 19-04-2005, 14:07   #19
Mine tends to have tooooo much understeer, The Front ARB mod I have also been told hasent helped, It did Improve when Powerstation tracked my car & I specifically told them to dial out as much as they could
Speed is an addiction for which thankfully there is no cure
Stuart_J is offline
Old 19-04-2005, 14:09   #20
BRISKODA Staff
SkodiRS's Avatar
Members Car:
Adrian.
SkodiRS is offline
Old 19-04-2005, 14:10   #21
BRISKODA Staff
SkodiRS's Avatar
Members Car:
Yep...those are the ones.
Adrian.
SkodiRS is offline
Old 19-04-2005, 14:13   #22
EddyH's Avatar
Stuart - Any update on the rear ARB?
Doesn't look like uprated bushes are available for the standard rear ARB, AFAIK the standard rear ARB is 13mm, powerflex only offer bushes for the TT/S3 which has a 14mm rear ARB.
EddyH
EddyH is offline
Old 19-04-2005, 14:18   #23
Site owner
ColinD's Avatar
Images: 3
Eddy, see if you can find koni inserts for KW v2....if you can then forget what I said in pm about price...or half it
Unless I can find half a set of rear KWv2's for the vRS...you mayaswell get use out if them
ColinD
ColinD is offline
Old 19-04-2005, 14:36   #24
EddyH's Avatar
Colin you've confused me! I've sent you a PM to try figure out what you mean!
EddyH
EddyH is offline
Old 19-04-2005, 14:51   #25
Couldnt be done echonomically as far as I could find, Jabba were trying to get the std one tweaked but that couldnt be done either by their contact so have sort of given up on it.
Re Colins post KW V2 Will certainly help, ask Bengie about how he finds them
Stuart_J is offline
