This is a discussion on Unusual ESP Intervention within the Octavia I forums, part of the Skoda Model Discussion Area category; When driving the Octavia on Sunday I was breaking hard from 'high' speed in an NSL before entering a 30. ...
| Briskodian Join Date: Jun 2004 Location: West Yorkshire
Members Car: Audi S8 Thanks: 41
| Unusual ESP Intervention When driving the Octavia on Sunday I was breaking hard from 'high' speed in an NSL before entering a 30. This was done whilst in a straight line and although the ABS didn't kick the ESP light flashed up. The car didn't feel to be getting out of hand at all and I wasn't doing anything I haven't done before. I'm not that fussed about it TBH but thought it would make an interesting point for discussion and it would be nice to hear others thoughts on this.
__________________ EddyH Audi A6 Avant 2.7 TDI Audi A3 2.0 TDI Sport |
| Briskodian | Re: Unusual ESP Intervention Perhaps your suspension setup has had an affect of the ESP sensors? I assume the ESP is calibrated for a particular vehicle. |
| | #3 | |
| Re: Unusual ESP Intervention Quote:
__________________ EddyH Audi A6 Avant 2.7 TDI Audi A3 2.0 TDI Sport | |
| Briskodian | Re: Unusual ESP Intervention I'm assuming the ESP is programmed to know how a car will ride in a skid etc. Whilst your car was very well planted, the ESP doesnt know its modded so may have expected a "situation" that in this case would never have been there. If you get what I mean. |
| | #5 | |
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 51
| Re: Unusual ESP Intervention Were you braking hard enough to trigger the ABS? I ask because the ESP light comes on if the ABS system fails; and if there is a fault in the ABS system, ESP does not operate.
| | #7 | |
| Re: Unusual ESP Intervention That info is straight out of the Owner's Manual - pages 74, 78 and 112-114 which are worth rereading. Yes, EBS-equipped cars have a specific ABS controller - mine is shown as ESP ALLRAD MK60 by VAG-COM. I would try a scan of Address 03 - ABS brakes - for starters to see if any fault has been logged. On the 4X4 the ESP system operates in combination with the ABS, EDL and EBC. EDL wouldn't have been operating to brake individual wheels in these circumstances - and I understand that when it does the noise it makes is very noticeable. Likewise EBC wouldn't have been operating since the throttle was presumably closed while you were braking.
| Briskodian | Re: Unusual ESP Intervention I've had a couple of odd experiences. Once, under heavy braking, all four wheels locked. I assume that a freakish set of circumstances allowed the ABS computer to decide that the vehicle had stopped (or was going slow enough to allow it to let the wheels lock). ESP light didn't flash and no faults were logged. The other time my ESP triggers (flashes and cuts engine power, doesn't brake wheels) for the wrong reasons is on a road with a severe right-handed camber on a sweeping righthand bend. If I take this bend at 40mph (it's NSL), the ESP triggers very regularly even though there's nothing wrong with the road surface. Faster or slower and it doesn't happen. Again, no faults, so its physics engine is just misunderstanding things in a specific set of circumstances ![]() Edit: standard suspension, uprated pads, Jabba, 4x4 hatch.
__________________ Octavia 4x4 Last edited by TKW; 16-01-2006 at 17:29. Reason: add information |
| | #10 | |
I'll check the vagcom codes. EDL has never kicked in and I wouldn't expect it to on the 4x4. I had it on my old golf but reprogrammed the ABS ECU to disable it as it was just annoying. What's EBC and why does it only act if the throttle is in use? Is like Electronic brake distribution or am I getting mixed up?
| | #11 | |
The ESP control unit is also supplied with signals which are transmitted by highly sensitive sensors. What is measured is the spinning rotary motion about the vertical axis of the vehicle, the lateral acceleration of the vehicle, the brake pressure and the steering lock. Apart from ABS input, none of these apply in Eddy's case but they do in the situation you describe. Maybe the ESP steering angle sensor needs its zero position calibrating - and this can be done with VAG-COM. I don't know about the other sensors. But if it isn't a major problem I would live with it.
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.57 mpg... | |
| | #12 |
Members Car: 4x4 turbo estate Thanks: 17
| Re: Unusual ESP Intervention only ever had my ESP cut in when accelerating to hard on a corner of braking to hard into/round a corner could be down to your standard damper/lowered springs combo, if the car bounces or lifts slightly then ESP would cut in.
| | #13 |
Members Car: Ford Escort 1.6LX + Fab Estate Thanks: 46
| Re: Unusual ESP Intervention Fabia vRS with ESP here - it doesnt always like the yellow stripes across the road to indicate the roundabout is nearing, Bracknell after A329(M) has those bl*dy things. The tricky thing is that it is more slippery on the lines themselves and it's not a straight approach. Suppose that's kinda the braking to hard into/round a corner scenario. Feel sorry for motorbikes though, I've seen a few have near-misses as it catches them out ![]()
__________________ WW --->> Project Journal (pic links in first post there)Lummox'/Ross thread on Unit18 Automotive progress on my car: here |
| | #14 |
| Re: Unusual ESP Intervention I would think its something to do with the lateral sensor. This monitors forward and aft movement to the suspension. Get a few odd faults with these, but usually log a code to check. |
| | #15 |
| Re: Unusual ESP Intervention Thanks, I'll check if any faults have been logged.
| Your next car should be fitted with ESP | aixlad | Fabia I | 24 | 20-12-2005 19:26 |
| Octavia VRS...To ESP or not to ESP? | ventmore | Maintenance & Performance | 26 | 23-06-2004 23:19 |
| Snow & salt or ESP fubars my 4x4 brakes ? | Fabpreza | Maintenance & Performance | 15 | 08-03-2004 16:59 |
| ESP - Is It A Waste Of Time ? | Fabpreza | Maintenance & Performance | 54 | 24-12-2003 17:56 |
| Vrs Asr Now As Esp? | Loukas | Maintenance & Performance | 24 | 07-10-2003 20:10 |
