This is a discussion on Vrs Fan Belt which way??? within the Octavia I forums, part of the Skoda Model Discussion Area category; Any one out there that can put some light on which way the fan belt goes on, either a good ...
| Briskodian Join Date: Feb 2007
| Vrs Fan Belt which way??? Any one out there that can put some light on which way the fan belt goes on, either a good description or a pic. Cheers all |
| Re: Vrs Fan Belt which way??? Sorry forgot to say 2004 model AUQ engine 20v turbo |
| Briskodian Join Date: Jan 2008 Location: WIRRAL
| Re: Vrs Fan Belt which way??? hi mate ill try an describe you have 4 pulleys plus tensioner start from crank, lowest pulley at rear of engine then work forward to next lowest by front of engine. then there are 2 above this 1, route it through the inside of the middle 1 then round the outside of the top pulley then down under tensioner back to crank hope this helps and is understandable |
| Re: Vrs Fan Belt which way??? Cheers for that perfect |
| Fan belt tensioner Superb | triumph900 | INTRODUCE YOURSELF! First time visitors, say hello here. | 2 | 02-04-2008 14:36 |
| 1.9 sdi fan belt asap | sandysaxo | Octavia I | 1 | 22-01-2008 14:07 |
| Fabia VRS Fan | jrsid | INTRODUCE YOURSELF! First time visitors, say hello here. | 2 | 25-10-2007 20:16 |
| New Fabia Vrs Fan! | akz | INTRODUCE YOURSELF! First time visitors, say hello here. | 6 | 14-10-2007 20:11 |
| Timing belt? Camshaft belt? Alternator Belt? | zhangzheng | Maintenance & Performance | 1 | 29-10-2004 09:16 |
