This is a discussion on vRS Mk1 HID Kit within the Octavia I forums, part of the Skoda Model Discussion Area category; I found this HID kit on ebay am I right in thinking the bulbs needed to replace the dipped beam ...
| Briskodian Join Date: Sep 2006 Location: York
| I found this HID kit on ebay am I right in thinking the bulbs needed to replace the dipped beam are H4? Do you need a high low kit so that you still get your main beam? New BOSCH 6000K H4 Bi-Xenon Hi Low HID Conversion Kit on eBay Head Lamps, Lights Lighting Accessories, Car Tuning Styling, Cars, Parts Vehicles (item 270152627896 end time 17-Aug-07 21:00:00 BST) Thanks Chris
__________________ Octavia vRS Mk1 55 Plate Corrida Red Blueflame turbo back exhaust 200 cell Cat, Carbonio C.A.I, Forge T.I.P, Forge Diverter Valve, Forge/Samco Hoses, N75-J Valve, Toyo Proxes TR1's and remap soon to come |
| Briskodian Join Date: Oct 2006 Location: North Ayrshire
| Re: vRS Mk1 HID Kit That's the very ones you need. A standard HID kit will take a single voltage and output a single voltage, this is good if your Main & Dipped beams are separate - like the Fabia and most other VAG cars. As the Octavia only has one bulb, the Bi-Xenon HID kit will take two feeds, and adjust the bulb fillament when you flick to your main beams rather than the dipped. Hope this helps - HID's make a huge difference to nightime driving ![]() |
| Re: vRS Mk1 HID Kit nice one i want a pair now. shame they dont do a full range of colours |
| Re: vRS Mk1 HID Kit You can get various colours, not colours as such though. They're referred to as Temperatures - measured in Kelvins. The most popular is the 6000K temp - which give off a deep blue light without being too OTT - the higher you go the more colour and less brightness you get. So, if you go for 4300K you get very bright HID's - but closer to OEM bulbs, less blue. If you go for 120000K bulbs you get a pretty much Purple colour - though they're not as bright as the others. It's a shame you can't get "proper" colours though - I think Green would be ideal for a Skoda ![]()
__________________ '03 Ovni Mk4 Ibiza TDI Sport 130 Private Reg - Xenons - Evo Coilovers - Stainless Exhaust - Phatbox 40GB FR mirros - Cupra Bushes - New Sport 16" Alloys - Pressed Plates - Polo Wiper |
| Re: vRS Mk1 HID Kit ahh so they do diferent ranges. nice to know |
| Briskodian Join Date: Apr 2006 Location: todmorden
| Re: vRS Mk1 HID Kit how legal are these kits as far as MOT ect are concerned
__________________ Octavia Vrs-Gone Clio 182-Gone C4 VTS "family car" with a fabia Vrs at the weekends Subaru Legacy GTB Twin Turbo "cheap runabout" |
| Re: vRS Mk1 HID Kit Aftermarket HID's like this kit are illegal. I beleive for them to be legal you require your headlamps to have washers, projectors and also be self levelling. Don't quote me on that though. I've had HID's on my Ibiza and also my Toledo (For about two and a half years all in) and never had a single problem with being pulled over, being flashed and also sailed through two MOT's. Again - its going to be one of these things like having fancy registration plates... what the beat are like in your area and who does your MOT.
| Briskodian Join Date: May 2006 Location: Copenhagen, Denmark
| Re: vRS Mk1 HID Kit I have been driving with a H4 HID kit for about a year now. I am not impressed and the Octavia H4 headlights are not suitable for HID fidment. The spread of the light i too much so you end up blinding others unless you adjust the headlights to point down. But pointing them down you will loose the effect of the great light that xenons give. I'm going back to halogen for a while untill I find the original xenon headlights (If I can find som cheap ones). You need theese Bildelsbasen - Sveriges största databas med bildelar My advice - DONT DO IT.
__________________ Regards, Martin 2002 Octavia RS |
| Briskodian Join Date: Jun 2008
| Re: vRS Mk1 HID Kit hi everybody. i just purchased a new skoda laura 1.9 diesel in india. i want to convert the headlamps to hid's. i have identified the philips xenstart d1s as a replacement for the low beam. i want to know if the bulb can be fitted straight into the car without any modifications. also, was looking for which bulb i could use to replace the high beam (h4) lamp with a hid without any modifications. thanks. |
| | #10 | |
| Briskodian Join Date: Apr 2007 Location: Finland
| Re: vRS Mk1 HID Kit Quote:
The high beams are H1 and dipped beams are H7 when car is equipped with halogens. If the car is equipped with Xenon dipped beam, then the bulbs are D1S for dipped beam and H1 for high beam. So your only option is to buy a aftermarket HID kit I'm afraid. (They're not road legal, but that might not be a problem). Or if you want to spend some serious money, then you'll need a new headlight assemblies which have xenon dipped and halogen high beam, levelling sensor kit for dipped beam autoleveling, headlight washers (if not already equipped) and a new rheostat control for dimming the interior illumination.
__________________ '05 OctaviaII 1.6FSI Combi Elegance : Xenons, Aftermarket H1 HID kit on main beams, Rain sensor, Autodimming rearview mirror, Light assist, Dual-Zone Climatronic, MFD2, Kufatec Digital music interface (USB, SD), MaxiDot (Retrofitted, parts from VrStu), Multi-function steering wheel (Retrofitted, parts from VrStu), Rear Parking Sensors. | |
| | #11 |
| Briskodian Join Date: Mar 2008
| Re: vRS Mk1 HID Kit i have the headlamps for the d1s kit but havent found anywere that they do this kit and from skoda main dealer its a fortune!!!! |
