This is a discussion on vrs surging? within the Octavia I forums, part of the Skoda Model Discussion Area category; hi, under acceleration my rs surges then holds back with a distinct rhythm, it rocks u in the seat in ...
| Briskodian Join Date: Sep 2005 Location: staffordshire
| vrs surging? hi, under acceleration my rs surges then holds back with a distinct rhythm, it rocks u in the seat in 4th n 5th gear its that bad, no error codes, but fuel consumption is erratic to say the least, cruising its may be doing 40+ then drops to 30 for no reason and the car seems down on power some of the time, any good ideas??though of fitting a boost gauge to see if boost surging?? noticed some oil on turbo outlet pipe at back of engine but nothing to concern me. help.john |
| Re: vrs surging? Try disconnecting the MAF. If the problem's no worse, or better, replace it. Otherwise if sounds very like fuel starvation, so try replacing the fuel filter. |
| Re: vrs surging? where is the fuel filter on the vrs??certainly not been changed for 20k |
| Briskodian Join Date: Aug 2006 Location: Liverpool
| Re: vrs surging? Forward from the drivers side rear wheel underneath the chassis. IIRC its meant for the life of the car but a swap cant hurt.
__________________ 2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!Smiles all 'round |
| Midnight Mod! Join Date: Jun 2004 Location: Aotearoa - land of the long white cloud
Images: 1 Thanks: 155
| Re: vrs surging? I'm pretty sure the service book recommends changing the fuel filter every 60,000 km
__________________ Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand! Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge www.pimpmyskoda.co.uk www.clubley.org Facebook |
| Briskodian Join Date: Aug 2007 Location: Staffordshire
| Re: vrs surging? Airmass Meter? Didn't flag anything up when mine started surging but I disconnected it and it worked fine afterwards. |
| The Following User Says Thank You to Rhyzz For This Useful Post: | jskelton555 (13-08-2007) |
| | #7 | |
| Re: vrs surging? Quote:
This sounds very similar to the issue I had, hough yours sounds more pronounced. My problem was the turbo intake pipe had come off the turbo, but at some point my MAF had also failed, probably by trying to over adjust itself to compensate for the erratic readings it woould have been getting. Unless you have an aftermarket TIP it's almost impossible for that to have come off but it could be a split pipe elsewhere.
__________________ Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand! Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge www.pimpmyskoda.co.uk www.clubley.org Facebook | |
| The Following User Says Thank You to RobClubley For This Useful Post: | jskelton555 (13-08-2007) |
| Briskodian Join Date: Jan 2007
| Re: vrs surging? when mine surged it was the DV needing an adjustment, if your car is mapped try this 1st.
__________________ Mods- ABD racing CAI --- ABD racing TIP --- Forge DV --- Blue flame full sytem --- Koni FSD's --- Bosch aero twins --- Fuel 4 5 Stud - 18" --- Milotek 3 grill set --- Milotek bonnet lifters --- Eibach springs --- Impossible Performance custom remap 'Impossible' is Nothing |
| The Following User Says Thank You to Ender For This Useful Post: | jskelton555 (13-08-2007) |
| Re: vrs surging? Hi john, from what you are saying, it is possible that your N75 valve has given up, i have fixed a couple of 1.8t's with the symptoms you have described by replacing the said valve. The best way to check this is to unplug it and to take it for a drive and see if your symtoms clear up.
__________________ 06 RACE BLUE vRS 18" ZENITHS - DUAL-ZONE CLIMATE - MFD2 - MAXIDOT - PARROTT 3200 - STILL TO DO - CRUISE CONTROL. |
| The Following User Says Thank You to VRS_RICHIE For This Useful Post: | jskelton555 (13-08-2007) |
| | #10 |
| Re: vrs surging? hi, i've ruled out pipes as it comes n goes, when it is cold it seems to perform far better and be more economical. the n75 valves had me wondering as it may explain the lack of go at times. will try unplugging n see what happens.thanks |
| | #11 |
| Briskodian Join Date: Jun 2007 Location: Cornwall
| Re: vrs surging? Hmm, mine does this a bit too lately i've noticed. If only half putting my put down it can surge in some gears. It's fine if you floor it though, just over half throttle it seems to do it... Getting a service / mot in a month so will see if they can pick up on anything! |
| | #12 |
| Here's Johnny ! Join Date: Nov 2004 Location: Edinburgh
| Re: vrs surging? My car also done this until i changed the lower IC pipe. |
| | #13 |
| Re: vrs surging? Hi guys, Ok, fancy getting mine sorted now. Two of you have suggest unplugging the N75 and the MAF. How do I unplug these? It is simple a case of pulling a plug out, can this harm the car? |
| | #14 |
| Don't talk, drive! Join Date: Feb 2003 Location: The B roads of Britain
| Re: vrs surging? The MAF plug is just to the left of the airbox on top of the big circular pipe as you look from the front of the engine. The N75 is the little valve with the small hoses going to it at the back rh corner of the engine. I would suggest doing this test with the MAF only. I believe unplugging the N75 will effectively disable your turbo, and probably put the car into limp mode. |
| | #15 |
| Re: vrs surging? It's been suggest a couple of times in this thread so I doubt it would? |
| | #16 |
| Re: vrs surging? OK you know best. The N75 is the wastegate control valve. Unplugging it will cause the turbo to be either on all the time or off all the time (hence my use of probably above, since I'm not sure which). This means you will either have no boost at all, or potentially be overboosting and damage the turbo. Your choice. More info here Last edited by ncarring; 25-09-2007 at 11:58. |
| | #17 |
| Re: vrs surging? Ok, relax. I wasn't having a go... Just saw it suggested earlier on and people had success! Guess I won't be able to just unplug it and see if that's at fault then ![]() |
