39,422 Members 1,488,150 Posts
Is water pump change essential or is it all hype?
This is a discussion on Is water pump change essential or is it all hype? within the Octavia I forums, part of the Skoda Model Discussion Area category; Getting my cambelt changed soon (2003 VRS now on 82000 miles) I was wondering..... is the water pump change essential, ...
Old 16-12-2007, 19:04   #1
I was wondering..... is the water pump change essential, and if so how many people really have had thier plastic ones fail?
Also, Westover Skoda, Dorset have qouted me £220 for cambelt change (they say they have never known a water pump to fail and alot of it is hype?). Would this price be for a full cambelt kit (rollers / pulleys etc?) Would most places change the cambelt as a whole kit, or just the belt?
Thanks in advance
Geoff
blocko is offline
Old 16-12-2007, 19:11   #2
gathy's Avatar
Re: Is water pump change essential or is it all hype?
dont seem to pricy for the dealers
my mate owns his own garage and its a very common problem is the water pump going
on all 18t engined vag models
getting hold of a 18t engine from a breakers is impossible or a proper fortune if your pump does go and snapped your cambelt
i will wait for mine to go before flapping about it as you'd end up replacing all the bits on your car with better bits to avoid engine failures etc .
THE SPLUTTERER
LASTEST PREVIOUS CARS
03 S60 T5=54 CLIO 182
02 S40 T4=51 ACCORD TYPE R
gathy is offline
Old 16-12-2007, 19:13   #3
mattbeef's Avatar
get it done mate.
I had mine done at 48k and the water impella was in about 5 pieces!
I few bits here and there but im happy to Performance Torque
Go on click me you know you want to
mattbeef is offline
Old 16-12-2007, 20:14   #4
Liverpool-Lad's Avatar
Yup, youd be a fool not to,
2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!
Smiles all 'round
Liverpool-Lad is offline
Old 16-12-2007, 20:19   #5
daverapid's Avatar
Definately change the water pump while the belt is off, it'll be a false economy not too especially as they are pretty cheap anyway.
David McKinney
TREASURER OF SKODA OWNERS CLUB GREAT BRITAIN
www.skoda-owners-club.org.uk
daverapid is offline
Old 16-12-2007, 20:34   #6
Belcher's Avatar
I started a thread a few weeks back. Mine failed big time. Its a 2003 Octy VRS on 45K. It was a plastic impeller type. When it came out, it came out in pieces! Just search this site for issues with overheating under power, and running normal when idle. These are the typical symptoms of a failed water pump, and it is quite common. In my opinion, a mechanic that says it's all hype is obviously not used to working on the 1.8T engine. Get it changed, and get it changed for the metal impeller one.
Regards,
Belcher. 'urp !
MCSE:S, MCSA:S
CompTIA Security+
CompTIA Linux+
Linux LPI Level 1
Belcher is offline
Old 16-12-2007, 20:46   #7
Why So Serious
fatty5000's Avatar
Look at all these water pumps not one of them has failed http://www.briskoda.net/forums/octav...lt-pump/80669/. But do they look good to you. Anyway what would I know, it's all hype
fatty5000 is online now
Old 16-12-2007, 20:49   #8
FORE!!!!
Hedge's Avatar
I would also lookup Westover Skoda as several people have written reviews about them.
http://www.briskoda.net/forums/skoda...imborne/38238/
Hedge is offline
Old 16-12-2007, 21:05   #9
Belcher's Avatar
Hee, hee Hype indeed then !
Some garages would benefit from the vast source of knowledge contained within this site
Regards,
Belcher. 'urp !
MCSE:S, MCSA:S
CompTIA Security+
CompTIA Linux+
Linux LPI Level 1
Belcher is offline
Old 16-12-2007, 21:05   #10
splash!!!!
bengie's Avatar
get it done for sure and get a metal pump fitted as its actually cheaper than a dealer supplied plastic one.
to change the water pump requires the removal of the cambelt so for the sake of a £20 pump its well worth it.
owner of a skoda octavia 4xvrs3
bengie is online now
Old 16-12-2007, 23:56   #11
starch's Avatar
I would always change the water pump on a car that had the pump driven by the cambelt, weather or not it needed it. Whilst you are there it is daft not to IMHO.
The other day I replaced one on a 306 gti about 10,000 miles after it had been done previously just to make sure.
The normal sign that a water pump is on its way is that it starts leaking, (usually they are designed to do this) but if the impeller breaks as is all so common with these there is no notice, it just gets very hot and causes a lot of damage.
Had a Octy, Vrs and loved it
Then a 1.9 tdi A4
Currently scraping my bum on the floor in a S1 Elise
Project biota is moving on well.
http://www.briskoda.net/forums/proje...nderway/70851/
Gamertag: Starchr
starch is offline
Old 17-12-2007, 00:12   #12
ScoobyChris's Avatar
I hope Westover have improved. They did the warranty work on my Fabia and royally bu66ered it up!!! For the cost of a new water pump, I'd get it done as it'll save you £xxxx if the original one does fail
Chris
ScoobyChris is offline
Old 17-12-2007, 00:19   #13
DGW
BRISKODA Staff
DGW's Avatar
Fortunately I had opted to have the water pump changed along with the cambelt at just 18738 miles and 4¼ years. This is what the original looked like when removed:
Denis
DGW is offline
Old 17-12-2007, 07:29   #14
mbames's Avatar
Get it done.. but not by Westover. £220 sounds cheap for the full works to be be done by a dealer. Ask they what they actually change.
I just did my 131k belt change, so I did the pulleys, tensioners, water pump and the aux belt and a coolant change. Cost was parts only as I did the work myself, but it was time consuming!!
mbames is offline
Old 17-12-2007, 10:21   #15
Wow! Looks like a metal one it is then ....... cheers folks
I think Im going to stick with JKM performance in Portsmouth in that case. They have been the most honest and helpful so far
blocko is offline
Old 17-12-2007, 11:08   #16
cheezemonkhai's Avatar
Thanks in advance
Geoff
Yes I would get it changed as if the water pump goes you will be paying out at least the amount for a full cambelt change to save £25.
I'd also avoid Westover skoda like the plague, since IMHO they are at best a steaming pile of sh*te. Until they completely replace a large portion of their dealer staff and lose the attitude that they are doing you a favour when you go there, I don't think my opinion will change.
If you have a look for them under the review section you will see similar comments.
If you want a main dealer I'd recommend Meadens in Sway/Bransgore (B'mouth Seat are also part of the same lot)
cheezemonkhai is offline
Similar Threads
Cambelt/water pump change at £550+ max24 Fabia I 6 12-09-2007 23:15
Water pump musky Octavia I 2 21-05-2007 17:55
Is it worth combining a water pump change with a cambelt change? DGW Octavia I 34 20-09-2006 19:16
is water pump change standard... noodles Octavia I 6 25-04-2006 14:09
Water pump swrtwannabe Maintenance & Performance 3 21-06-2004 12:39
