39,455 Members 1,489,875 Posts
What plugs do I need for my 4x4?
This is a discussion on What plugs do I need for my 4x4? within the Octavia I forums, part of the Skoda Model Discussion Area category; Any help would be welcome ... My car has a splutter when cold for the first min or so and ...
Old 10-10-2007, 19:31   #1
jmk
Members Car:
My car has a splutter when cold for the first min or so and a cheap thing to change before the garage start investigating is some new plugs but I'm not sure what to buy. Any help welcome.
Car is a 2002 Octavia 4x4. The start of the chassis no (taken from windscreen) is TMBKL21U02.
I've seen some sites which ask for an engine code and quote 3 digits, would mine be U02?
Is there anything else obvious you'd check for the splutter. The car is jumpy and feels as though it's going to stall, but doesn't. Had a new fuel filter fitted a few months ago and last serviced in Dec.
Thanks
jmk is offline
Old 10-10-2007, 20:15   #2
VRSPhil's Avatar
Members Car: Passat Sport TDi
Re: What plugs do I need for my 4x4?
Is it a 1.8t? If so, this seems quite a common problem. Mine is a dog for the first minute or so (sometimes, other times it's ok). I don't have any fault codes and as far as I can tell, no boost leaks. Car is serviced every 5k miles and plugs are changed every 15,000 or so - it makes no difference.
The plugs I use in my VRS are NGK PFR6Q, which are identical (minus the VAG logo's) to the standard parts. I would imagine they're the same in the 150bhp, possibly with a different gap.
'54 Passat PD130 Sport... 55mpg
Octavia vRS WRC - Gone but not forgotten!
VRSPhil is online now
Old 10-10-2007, 20:32   #3
jmk
Members Car:
Yeah, the 1.8t.
Same as you - rough as a dog for maybe 500 meters. dealer can find no faults.
I'll try the plugs and if it's better let you know.
Thanks
jmk is offline
Old 10-10-2007, 20:34   #4
mluton's Avatar
Same here.
Start engine and wait for the revs to drop (some pump Stops) then set off.
Red Skoda Octavia V//RS
mluton is offline
Old 10-10-2007, 20:35   #5
Wayne Kerr's Avatar
Check out "Oilman" on this site. Denso plugs are the dogs, just replace them & the plug problem will be solved.
Sounds like coil-packs to me ,,,,,,, lodsa squids ,,,,,, had mine changed twice!
It's a VAG problem that we all are paying for. VAG
Deli G ,,,, leader of the Peckham Massif!
KW Coilovers fitted, Forge TIP fitted, KK fitted, Blueflame full system fitted, CAI fitted, Forge 007 D/V fitted, PBVH4 fitted, Forge adjustable rear tie bars fitted, FMIC fitted, 312's fitted, Tints fitted.
Was that a 4x4 Skoda??? It's IMPOSSIBLE!
197.2 BHP & 263.1Nm
Wayne Kerr is offline
Old 10-10-2007, 21:10   #6
Members Car: OCTAVIA vRS (53 reg.)
I also use denso iridium plugs, supplied by oilman (opie oils).
My vrs is running IK20's gapped @ 0.8mm, and has no misfires etc (touch wood).
bill.
vrs180 is offline
Old 11-10-2007, 10:45   #7
DGW
BRISKODA Staff
DGW's Avatar
The code for the 1.8T engine in the 4X4 is ARX. I use the original equipment NGK PFR6Q Longlife spark plugs in my remapped 4X4.
Denis
DGW is offline
Old 13-10-2007, 19:51   #8
Wayne Kerr's Avatar
Just a thought mate ,,,,, why use original equipment with a remap
Seems daft to me!
197.2 BHP & 263.1Nm
Old 14-10-2007, 11:24   #9
Need more power
martziniuk's Avatar
Members Car: octavia VRS
Originally Posted by mluton View Post
Same here.
The pump noise will be the secondary air pump.This supplies more air to warm the cat up quicker from cold start.Could your problems be from this?
Make sure the pipe from the secondary air pump is still connected to the air box they are a real bad connector
Regards Martin
Turbo back blueflame exhaust ,Forge 007p Dump valve, Ramair filter, Prosport boost gauge, Autobahn88 TIP, Ecu Evolution Remap, FMIC
martziniuk is offline
Old 14-10-2007, 11:38   #10
DGW
BRISKODA Staff
DGW's Avatar
Seems daft to me!
Jabbasport considered them to be suitable and I have had no problems with them, so why change? Likewise everything else on the engine is standard apart from the DV. I opted to fit a Bailey since it is of more robust construction than the original plastic one which is prone to splitting of the diaphragm.
Denis
DGW is offline
Old 14-10-2007, 14:45   #11
FocusZtec's Avatar
Same here; remapped with lots done to it and standard plugs - no problems whatsoever.
IMO you only change from standard parts when there is a specific problem with it.
Lee
http://img.photobucket.com/albums/v610/FocusZtec/neiloctypipersignature.jpg
Thanks to JKM:
REVO STAGE 2+ remap, Evoms CAI, Piper Turbo back Exhaust, Autotech Fuel Pump, Torque Arm Insert, Forge Recirc, Neuspeed Turbo & Intercooler pipes, APR FMIC, Iridium plugs, Koni FSD's, Eibach springs, Eibach F + R anti roll bars. VF short shifter. 345mm Brakes. 280BHP & 330LB/FT - enough room for a proper trip to B&Q and 36mpg on a run!!!
FocusZtec is offline
Old 14-10-2007, 14:53   #12
richm's Avatar
Members Car: vRS
If you're wanting to change plugs to see what happens, try NGK BKR7E - they are a standard copper core equivalent plug but one heat range colder. They will work at least as well as expensive platinum/iridium parts, and in some conditions better, as the copper core allows heat to dissipate faster from the hot plugtip region. They just don't last as long which is why they aren't used as OE. They cost almost nothing (£2 ea), so just change them every 6-8K and get the benefit of newer plugs for longer in their life cycle.
Many won't agree with this philsophy no doubt, but I make no apologies, just offering the benefit of experience
richm is offline
The Following User Says Thank You to richm For This Useful Post:
VRSPhil (14-10-2007)
Similar Threads
spark plugs steady Favorit, Felicia, Fun and Forman 3 23-09-2006 16:02
RS Plugs sdmegawuk Octavia I 2 06-10-2005 17:39
plugs? Mull3tt Fabia I 0 05-10-2005 17:00
These the right glow plugs? anyone? devonutopia Maintenance & Performance 1 12-01-2005 09:18
When to change plugs on RS Flanno Maintenance & Performance 11 14-05-2004 22:17
