This is a discussion on What tyre Pressure? within the Octavia I forums, part of the Skoda Model Discussion Area category; OK chaps. I have a standard vRS (53 plate)(hatchback) with the standard 17 inch wheels. What should the correct tyre ...
| Briskodian | What tyre Pressure? OK chaps. I have a standard vRS (53 plate)(hatchback) with the standard 17 inch wheels. What should the correct tyre pressures be? One looks a bit low to me and my handbook is at home. |
| Briskodian Join Date: Nov 2003 Location: Walsall, West Midlands
Members Car: Sea Grey Mondeo Titanium X Thanks: 0
| i run mine at 32psi on the front and rear... i think this is slightly higher than the recommended pressure of about 28-30psi but i like my tyres a little bit harder.
__________________ Sea Grey Mondeo Titanium X |
| Briskodian Join Date: Jan 2004 Location: Ireland
Members Car: Skoda Octavia vRS Thanks: 23
| I have 16" tyres on mine, and run them at 30psi. When I bought the car off the previous owner, he had 55psi all round!!! Way too hard, rattles your fillings loose and no grip in corners... keep it around 30-ish and you'll be fine
__________________ Dear Lord.. The gods have been good to me. For the first time in my life, everything is absolutely perfect just the way it is. So here's the deal: You freeze everything the way it is, and I won't ask for anything more. If that is OK, please give me absolutely no sign. OK, deal. |
| Briskodian | My octy has the pressures for variuos different yre types inside the fuel filler, have you looked there? ![]() |
| Briskodian | mine are just about flat at the bottom |
| | #6 | |
Members Car: Octavia II vRS Thanks: 29
| Quote:
I'd say that felt good going around corners in the wet ![]()
__________________ GAFF ![]() Briskoda Ireland Events, Meets & Pictures.....Race Blue Octavia MkII vRS.....Old Octavia MkI vRS | |
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 51
| If someone would like to post the data on the filler flap, I will put it into a FAQ. It's probably the same as that for my 4X4 but I don't want to publish incorrect info for want of checking. I'm off to check mine now..... ![]()
| Octavia 4X4 Half load - pressure when cold in kPa (psi) 195/60 R15 - Front 220 (32) Rear 220 (32) 205/60 R15 - Front 220 (32) Rear 230 (33) 205/55 R16 - Front 220 (32) Rear 230 (33) Full load 195/60 R15 - Front 230 (33) Rear 290 (42) 205/60 R15 - Front 230 (33) Rear 280 (41) 205/55 R16 - Front 230 (33) Rear 280 (41)
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.57 mpg... Last edited by DGW; 14-04-2005 at 20:45. |
| | #9 | |
| Briskodian | cheers chaps Quote:
| Spare Wheel - Tyre Pressure | steviec | Octavia II | 7 | 12-04-2005 13:11 |
| Preparing a road car for track day use | Real Skoda | Maintenance & Performance | 8 | 10-04-2004 19:20 |
| Preparing a road car for track day use | Real Skoda | Maintenance & Performance | 0 | 10-04-2004 05:48 |
| Running On Low Tyre Pressure... | Flanno | Maintenance & Performance | 5 | 21-10-2003 11:31 |
