This is a discussion on What is wrong with my Mk1 vRS within the Octavia I forums, part of the Skoda Model Discussion Area category; Last month I bought an '03 Mk1 vRS from a Skoda dealer. On the day that I picked it up ...
| Briskodian | What is wrong with my Mk1 vRS Last month I bought an '03 Mk1 vRS from a Skoda dealer. On the day that I picked it up I noticed a problem whilst accelerating. The car would die off around 2,500 rpm and then further up the rev rang it would 'surge'. I think this is different to the splutter problem which a lot of people have reported. It has been back to the dealer who has changed the MAF, Dump Valve and ECU. Now they are refusing to do anything else to the car, claiming that there is nothing wrong with it. Even though it is exactly the same as when they first started looking at it. I drove another vRS of a similar age today and it felt amazing compared to my car. What do people recommend now? |
| | #3 | |
| Silver bullet Join Date: May 2003 Location: Planet Earth......
Members Car: 345bhp Silver Octavia vRS Thanks: 48
| Quote:
That, if it plays up can cause the power to surge. Steve
__________________ The silver bullet Jabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.![]() | |
| Briskodian | Re: What is wrong with my Mk1 vRS I don't have access to VAGCOM. Isn't the N75 the dump valve? They have put a new dump valve on and it has made no difference. |
| Briskodian | Re: What is wrong with my Mk1 vRS I have done a bit of research and you might be correct. Would Skoda fit an N75J valve or do I need to go to an aftermarket retailer? |
Members Car: Audi S3 Thanks: 145
| Re: What is wrong with my Mk1 vRS Skoda will replace the N75 with the correct one for your car. Alternatively you could buy your own J valve if that's what you want. It could also be down to a split hose on the vacuum.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| Briskodian Join Date: Jul 2006 Location: Cleveland
Members Car: Passat Sport TDi Thanks: 206
| Re: What is wrong with my Mk1 vRS I'm fairly sure that Skoda have another name for the N75 valve but I'm afraid I don't know it! It's worth finding out before you go though so that they don't look at you with blank faces! |
| Re: What is wrong with my Mk1 vRS The N75 is the N75, that's what they call it.
| | #10 |
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 51
| Re: What is wrong with my Mk1 vRS There is quite a lot of useful troubleshooting info about the 1.8T engine here, including an explanation of what the N75 electronic solenoid valve does. ![]()
| | #11 |
Members Car: 4x4 turbo estate Thanks: 17
| Re: What is wrong with my Mk1 vRS if its under warranty keep taking it back until they fix it and if they don't complain like mad until it is fixed.
| | #12 |
| Need more power Join Date: Feb 2007 Location: Driffield, Good old yorkshire
Members Car: octavia VRS Thanks: 54
| Re: What is wrong with my Mk1 vRS Dirty throttle body maybe? i know it made a lot of difference to mine. |
| | #13 |
| Briskodian Join Date: Aug 2005 Location: South west UK
Members Car: Std. 2002 Octavia vRS in Silver Thanks: 23
| Re: What is wrong with my Mk1 vRS In case the N75 thing doesn't work... Start recording the dates of your visits to the dealer, what has been said/admitted & what has been done to the car at each visit. Start talking about 'Not of merchantable quality'. Set them a deadline to fix the car. Try to get as much as you can from them in writing. Phone them every day! Hope it doesn't come to this |
| | #14 |
| Site Sponsor Join Date: Apr 2006 Location: brighton
Members Car: octavia vrs 03 Thanks: 0
| Re: What is wrong with my Mk1 vRS Actually the n75 valve is called a dumpvalve by vag so you need to find out if the replaced the pressure valve or the dump valve,as they could of changed either part if they called it a dump valve,it could be either part that is creating the problem as well,find a good after market garage with vag-com or knowledge of these engines and im sure it will get sorted out! Where in the south east if you would like to use us!
__________________ |
| | #15 | |
| Re: What is wrong with my Mk1 vRS Quote:
If you are claiming to be a VAG specialist then I for sure wouldn't come to you if you think the N75 is the dump vlave mate. The N75 is the wastegate regulator. An electrical solenoid valve and not a vacuum operated recirculating valve which is what the Diverter valve (dump valve) is. N75 - ![]()
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio | |
| | #16 | |
| SMOGUS MAXIMUS Join Date: Jan 2005 Location: Essex
Members Car: Toyota Auris SR180 Images: 3 Thanks: 50
__________________ Skoda performance was "IMPOSSIBLE", now its Japanese and 177 bhp and 295 lb ft torque of SMOG. Gerry "HONI SOIT QUI MAL Y PENSE" Last edited by VRStu; 22-03-2007 at 19:06. Reason: Removed copy of picture I posted. | |
| | #17 |
| Ex-Moddy Join Date: Jul 2005 Location: Hampshire
Members Car: Golf PD105 Thanks: 187
| Re: What is wrong with my Mk1 vRS I've been in there, did'nt fill me with confidence tbh.
__________________ Superchips Bluefin only £390 @ JKM http://www.jkm.org.uk/performance/bluefinxmas2008.htm |
| | #18 |
| Still a **** | Re: What is wrong with my Mk1 vRS If they didn't fill you with confidence did they fill your pockets with money so they have the right to advertise on here.
__________________ The Red Devil |
| | #19 |
| Re: What is wrong with my Mk1 vRS as said the N75 is the actuator regulator and not a dump valve, its basically an air injector like the instal in cossies for more accurate ECU controlled boost pressures and the dump valves is what recirculates teh boost pressure from the inlet system back before the turbo to prevent turbo stall ![]()
| | #20 |
| Briskodian | Re: What is wrong with my Mk1 vRS Just incase anyone followed my initial post I thought I would write an update. Skoda Customer Services persuaded the garage to take another look at my car. They would provide them with any technical knowledge they needed. When I took it in I asked them to check the N75 following the advice on here. They replaced it and the car now works fine. So a big pat on the back to everyone who recommended I check the N75! |
| | #21 |
| Re: What is wrong with my Mk1 vRS Anyone have any idea on the cost of the N75? Glad to hear all is now well OSGrooves ![]() |
| | #22 |
| Permanently banned Join Date: Mar 2006 Location: Buckingham Palace Car Park
Members Car: Honda Civic Type-R Thanks: 86
| Re: What is wrong with my Mk1 vRS ![]() |
| | #23 |
Members Car: '97R BMW 328i Saloon Thanks: 679
| Re: What is wrong with my Mk1 vRS Good result fella. I'm sure that you would now like to return the favour to Briskoda by coughing up £1 a month to join Freedom! ![]() I'm glad you got it sorted anyway, nice one.
| | #24 |
| Briskodian Join Date: May 2006 Location: Copenhagen, Denmark
Members Car: 2002 Octavia RS Thanks: 0
| Re: What is wrong with my Mk1 vRS Hmm I think i'll try that N75 valve trick on mine too. It can be a little jerky when trying to accelerate smoothly in fx. 2. gear. Happened after a remap. Is the trick to just replace it with another original one? Part# please? ![]()
__________________ Regards, Martin 2002 Octavia RS |
| | #25 |
| Briskodian Join Date: Jan 2004 Location: Ireland
Members Car: Skoda Octavia vRS Thanks: 23
| Re: What is wrong with my Mk1 vRS Funny that the box description for the N75 valve indicated by this thread says "dump valve"....... http://www.briskoda.net/forums/octav...74/#post893786 Looks like someone got a flaming for nothing.
__________________ Dear Lord.. The gods have been good to me. For the first time in my life, everything is absolutely perfect just the way it is. So here's the deal: You freeze everything the way it is, and I won't ask for anything more. If that is OK, please give me absolutely no sign. OK, deal. |
