This is a discussion on What's a fuel injection pump?? within the Octavia I forums, part of the Skoda Model Discussion Area category; I had the Octy in the garage with a few niggles. A starting and running lumpy problem was diagnosed as ...
| Briskodian Join Date: Oct 2004 Location: Northern Ireland
| I had the Octy in the garage with a few niggles. A starting and running lumpy problem was diagnosed as a faulty temperature sensor inside the Fuel Injection Pump. The garage have ordered on in which i shall be getting fitted mid month. But what is it? what does it do?? Is it the same as a fuel pump? JD
__________________ Octy Elegance TDI (110bhp) |
| | #2 | |
| Briskodian Join Date: Dec 2005 Location: Caribbean
| Quote:
http://tdiclub.com/TDIFAQ/TDiFAQ-1.html http://www.vwvortex.com/artman/publi...icle_325.shtml http://tdiclub.com/ Last edited by MaxLugo; 08-05-2006 at 20:15. | |
| But his 110 bhp has a regular injection pump. It does have a temp sensor built into the top of the pump.
__________________ Unit 18 Automotive Services now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| Apparently the temp sensor cannot be changed alone, and the whole pump must be replaced.
__________________ Octy Elegance TDI (110bhp) Last edited by cmcm789; 12-05-2006 at 10:58. |
| Briskodian Join Date: Feb 2005 Location: Leics UK
| We had the diesel pump replaced on our old 1.5D Citroen AX and it cost £550 :'( - not a nice repair to suffer.
__________________ Do something useful - Join the BRISKODA Folding team: http://www.briskoda.net/modules.php?...warticle=&id=26 |
| | #6 | |
| Quote:
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.09 mpg... | |
| | #7 | |
| Quote:
Luckily the car still has 3 weeks of warranty left. That's why i am making the most of it now. I def wouldn't want to be replacing it outside warranty if that's what it costs.
__________________ Octy Elegance TDI (110bhp) | |
| In that case i'd edit your about post about you know what just incase.
| Briskodian Join Date: Nov 2006
| The temp sensors in the injection pump can be changed. It is not very difficult and replacement part should not cost much. You will probably have to go to an diesel injection specialist for the part. Search tdiclub.com for details.... |
| | #10 |
| Replacing fuel temp sensor, tutorial - TDIClub Forums Tools required: 10mm nut driver (or socket) to remove engine cover 3/8" ratchet handle 5" (at least) extension TX30 socket (male, non security or security) TX10 socket (male, non security or security) 13mm socket MetalNerd injection pump tool 1 wire-tie (optional, but recommended) some rags Part required: Fuel Temperature Sensor VW part no. 028 906 040 C
__________________ Cars make CO2 and trees absorb CO2. By driving your car you're feeding a tree and helping the environment. Last edited by cheezemonkhai; 06-11-2006 at 23:18. |
