This is a discussion on Wheel alignment on 4x4? within the Octavia I forums, part of the Skoda Model Discussion Area category; Having lowered my car the rear wheel have a lot of negative camber on them... I have looked on Autodata ...
#1 |
| Briskodian | Wheel alignment on 4x4? Having lowered my car the rear wheel have a lot of negative camber on them... I have looked on Autodata they say the rear camber is not adjustable, is there any way around this? Also does anyone have any settings other than standard that they use for better handling? Cheers ![]() |
| Briskodian Join Date: Jan 2003 Location: Winchester
| Re: Wheel alignment on 4x4? Adjustable Tie rods need to be fitted, I bought some off of Forge 3 years ago for about £250 + the dreaded + postage I believe Jabba may be able to source them for less, They are made in the States & are meant for TT's but fit the 4x4 Powerstation in Cheltenham are excellent at 4 wheel allignment if you are that way, I travel from hampshire just to get the wheels aligned there They can dial in or out understeer to suit what you want, they have vast experience with rally & race cars so tend to use their knowledge rather than a book
__________________ Speed is an addiction for which thankfully there is no cure Last edited by Stuart_J; 03-10-2006 at 13:31. |
| Briskodian Join Date: Aug 2005 Location: North London
Members Car: Octy 4x4 1.8T Elegance Hatch Thanks: 29
| Re: Wheel alignment on 4x4? Hi mate, they arent adjustable as standard but speak to the nice people at Jabba and they will sell you a set of adjustables rear control arms which when fitted, allow camber to be adjusted. ![]() Its what I have and they work brilliantly. Lee
__________________ ![]() Thanks to JKM: REVO STAGE 2+ remap, Evoms CAI, Piper Turbo back Exhaust, Autotech Fuel Pump, Torque Arm Insert, Forge Recirc, Neuspeed Turbo & Intercooler pipes, APR FMIC, Iridium plugs, Koni FSD's, Eibach springs, Eibach F + R anti roll bars. VF short shifter. 345mm Brakes. 280BHP & 330LB/FT - enough room for a proper trip to B&Q and 36mpg on a run!!! |
| Briskodian | Re: Wheel alignment on 4x4? cheers guys, will be on the phone to them then! Doing 800 miles this weekend though so might have a rather rough ride (need dampers) and a lot of tyre wear ![]() |
| Re: Wheel alignment on 4x4? Not wanting to scare you mate but have a peek at this lowered, non adjusted Passat 4 motion... Forge Motorsport ![]()
| Briskodian | Re: Wheel alignment on 4x4? oh bugger. Might have to pinch the recce car from work if its back from cyprus for the weekend That does not look great! Do I need anything else before I order them? |
| | #7 | |
| Re: Wheel alignment on 4x4? Quote:
Jabba can do a mean set of dampers as well ![]()
__________________ Speed is an addiction for which thankfully there is no cure | |
| Re: Wheel alignment on 4x4? If you want to stick with Std dampers I have a complete set in the garage off a 52 plate 4x4, came off the car about 3 years ago, covered 8000 miles from new call on 07799 623693 if interested
| Bored! Join Date: Apr 2005 Location: Macclesfield - Cheshire
Members Car: Octavia VRS Thanks: 30
| Re: Wheel alignment on 4x4? |
| | #10 |
| Briskodian | Re: Wheel alignment on 4x4? Stuart thats very kind thanks, but I think it is uprated dampers I need really, whilst the ride was quite bouncy before I lowered it the car has only done 40k so surely the dampers can't be that worn? Also there is a lot of weight in the back of the car all the time so I reckon that will make a big difference... If you think otherwise please do say! JAYMD, thanks for that, unfortunately the link isnt working, takes me to the search page saying the the page you were looking for is no longer available... |
| | #11 | |
I have tried both Kw variant 2 & 3. The 3's are slightly better but cost more (still running the 3's) Lee (FocusZtec) had a different set up fitted which hes very pleased with but I cant remember what it was. (edited to say, Just read his signature, its all on there)
__________________ Speed is an addiction for which thankfully there is no cure Last edited by Stuart_J; 03-10-2006 at 15:48. | |
| | #12 | |
| Briskodian Join Date: Jun 2005 Location: NW Kent
Members Car: Metalic Black 1.8T 4x4 Estate Thanks: 9
__________________ Deli G ,,,, leader of the Peckham Massif! KW Coilovers fitted, Forge TIP fitted, KK fitted, Blueflame full system fitted, CAI fitted, Forge 007 D/V fitted, PBVH4 fitted, Forge adjustable rear tie bars fitted, FMIC fitted, 312's fitted, Tints fitted. Was that a 4x4 Skoda??? It's IMPOSSIBLE! 197.2 BHP & 263.1Nm | |
| | #13 |
Members Car: 4x4 turbo estate Thanks: 17
| Re: Wheel alignment on 4x4? i have lowered mine and forgot to change the tiebars at the back, my camber is a bit out but haven't noticed any really odd tyre wear and no funny handling either. its been round silverstone twice at trax in '05 and '06 and gets driven hard round the roads. ![]() they haven't snapped either ![]()
__________________ owner of a skoda octavia 4xvrs3 Last edited by bengie; 06-10-2006 at 17:09. |
| | #14 |
| Re: Wheel alignment on 4x4? looks more like an S3 to me ![]()
| | #15 | |
| | #16 | |
I drove a Cannonball with my car lowered but without the bars as I could not obtain any before I went. Nothing broke but one rear tyre was treadless on the inside, that was in about 3000 miles albeit 3000 virtually flat out miles at speeds of up to an indicated 150. The tyre had done about 1000 miles before the event Strange only one tyre went, I put it down to a combination of tracking & Camber out, I also hit a small sleeping policeman at ??mph, it was hard enough to buckle the front & rear alloy on one side of the car so Im guessing that probably knocked the tracking out on the rear. Thankfully the sump missed it !!
__________________ Speed is an addiction for which thankfully there is no cure Last edited by Stuart_J; 05-10-2006 at 06:03. | |
| | #17 |
| Re: Wheel alignment on 4x4? i think that was probably the cause of your tyre wear as mine has seemed normal whenever i look ![]()
| | #18 |
| Briskodian Join Date: Jan 2004 Location: Sheffield
Members Car: Octavia Thanks: 0
| Re: Wheel alignment on 4x4? I've got KW v1s without adjustable tie bars. I haven't gone mega low which may help a bit but 8000miles with no uneven tyre wear here. Iirc Demon Tweeks measured it at 2 degrees of negative corner, just on the allowable factory limit.
__________________ ![]() Mondeo Tdci 115, sweet! |
| | #19 |
| Re: Wheel alignment on 4x4? i might get out a protractor and spirit level one day and measure my camber ![]()
| | #20 |
| Briskodian | Re: Wheel alignment on 4x4? Fitted new vrs dampers on the front yesterday (only £34 from Skoda!) and that has pretty much sorted the front end. Think I will be going with rear tie bars and adjustables on the back, the toe in and camber are way out so definately needs attention! Cheers for all the suggestions and will keep updated ![]() |
| | #21 | |
| | #22 |
| Briskodian | Re: Wheel alignment on 4x4? |
| | #23 |
| | #24 |
| Re: Wheel alignment on 4x4? as normal my fingers are too fast for me ![]()
| | #25 |
| Briskodian Join Date: Jun 2004 Location: West Yorkshire
Members Car: Audi S8 Thanks: 41
| Re: Wheel alignment on 4x4? Not had chance to read the whole thread but like Bengie I had no tyre wear problems when lowered on the H&R springs. However I did on R32 springs as the rear was very low.
__________________ EddyH Audi A6 Avant 2.7 TDI Audi A3 2.0 TDI Sport |
