39,453 Members 1,489,866 Posts
Wheel Bearing
This is a discussion on Wheel Bearing within the Octavia I forums, part of the Skoda Model Discussion Area category; Can someone tell me what it sounds like when a wheel bearing starts to fail?? I have noticed a sort ...
Old 18-07-2006, 19:53   #1
roblatus's Avatar
Members Car: Mazda MX-5 RS Spec
Wheel Bearing
I have noticed a sort of whine/howl from my car since i swapped a wheel from the front to the back to pinpoint a vibration through the steering wheel which is down to bad balancing and i am getting all the wheels finger plate balanced tomorrow.
The noise sort of sounds like the type of thing you get when you drive on an old concrete road instead of a tarmac one?????
It doesn't seem to get particularly worse when going faster either.
Also the car has only done 23k miles so what is the likelihood of a wheel bearing failing that early?
finally what sort of period of time should i expect it to get worse over if it was a bearing?
Thanks for any help or advice
1998 Mazda Roadster 1.8 RS Spec. spending a lot of time sideways
roblatus is offline
Old 18-07-2006, 20:06   #2
Site Sponsor
Members Car: octavia vrs 03
Re: Wheel Bearing
the wheel bearing on my octy started to whine a month ago and i quickly found it to be one of the fronts then checked which direction it made more noise (i.e turning right at speed in this case ) so replaced the front nearside bearing,all is well now it was buggered.
Was told by the local scud dealer that front failures are common.
f1btn is offline
Old 18-07-2006, 20:10   #3
Cupra Bush King
Lummox's Avatar
Images: 2
Re: Wheel Bearing
A good way of checking them is jack the car up, spin the wheel whilst holding the road spring. If the bearing has failed you can usually feel a vibration/rumbling in the spring.
www.unit18.co.uk
Lummox is offline
Old 18-07-2006, 20:26   #4
roblatus's Avatar
Re: Wheel Bearing
I jacked the car up last weekend and spun each wheel in turn but could not notice anything out of the ordinary. Will maybe try again tomorrow but hold the spring this time
If i needed to replace one how easy a job is it??
roblatus is offline
Old 18-07-2006, 20:35   #5
Cupra Bush King
Lummox's Avatar
Images: 2
Re: Wheel Bearing
You need a hydraulic press to do it.
www.unit18.co.uk
Lummox is offline
Old 18-07-2006, 20:59   #6
roblatus's Avatar
Re: Wheel Bearing
My car is still under warranty so if it looks like it is the bearing then i may give the dealer a call.
Wonder if they will try and blame the bearing failing on fitting bigger alloys or vRS suspension though? and therefore not do it under warranty
Unless i can get one of these hydraulic press things and do it myself.
roblatus is offline
Old 18-07-2006, 21:08   #7
Cupra Bush King
Lummox's Avatar
Images: 2
Re: Wheel Bearing
Well a good quality press to do bearings will set you back a few hundred quid at least. The VAG one we have was £1500.
www.unit18.co.uk
Lummox is offline
Old 18-07-2006, 21:12   #8
roblatus's Avatar
Re: Wheel Bearing
Thats that idea out of the window then
Getting wheels balanced and swapped around tommorrow, will also spin wheels and check for vibration through spring, if it looks like a bearing then i will give the dealer a call. I have a few other minor issues that it needs to go in for anyway such as a rattling radiator.
Thanks for the help
roblatus is offline
Old 18-07-2006, 21:13   #9
roblatus's Avatar
Re: Wheel Bearing
Just out of interest is there anyway that a wheel bearing faliure could be casued by my wheels or suspenison mods?????
roblatus is offline
Old 18-07-2006, 21:47   #10
Cupra Bush King
Lummox's Avatar
Images: 2
Re: Wheel Bearing
In thoery yes, unlikely but your dealer could get out of it should they wish to. But give it a go.
www.unit18.co.uk
Lummox is offline
Old 18-07-2006, 22:15   #11
roblatus's Avatar
Re: Wheel Bearing
cheers for the advice, i am on first name terms with the worskhop manager and he know my car has some mods but they have always been ok with it when it has been in for a few things in the past so i will keep my fingers crossed if it comes to taking it in.
Thanks again
roblatus is offline
Old 19-07-2006, 18:14   #12
roblatus's Avatar
Re: Wheel Bearing
Jacked the car up again today one wheel at a time, spun each wheel inturn while holding the spring with the other hand. I could feel no vibration through the spring while doing this on both the front wheels. I also tried the back too and felt nothing.
I am begining to wonder if it is noise from the tyres perhaps as i have also tried turning hard round a roundabout to see if the sound gets worse and i does not. I have also tried some hard left hand turns too and still the noise is not worse.
roblatus is offline
