39,455 Members 1,489,894 Posts
When to change hydraulic lifters?
This is a discussion on When to change hydraulic lifters? within the Octavia I forums, part of the Skoda Model Discussion Area category; when to change hydraulic lifters is there any rule about that ?...
Old 20-04-2008, 13:21   #1
Members Car: 1,8t
eNcode is offline
Old 20-04-2008, 17:52   #2
Student
andrew_lumb's Avatar
Images: 2
Re: when to cange hydraulic lifters
I've never changed them in my life.
If I ever have cause to remove the head, or cams, I would leave them in a bath of oil over night, which removes the dirty oil from them.
I wouldn't be inclined to dismantle the top end of the engine just for the sake of cleaning the lifters though, unless it was tapping like a mare!
Mods: Pipercross Panel Filter, Forge 007P Recirc Valve,
Blue Flame Cat-Back Exhaust, AP Coilovers, Powerflex Dogbone Bush, and ICE.
Plans: Sports Cat & Down Pipe, Remap, Rear ARB, Wheels & Tyres, and a bit more styling .
andrew_lumb is offline
Old 20-04-2008, 19:29   #3
Members Car: 1,8t
yes it taping but i do not know , how much they can go on
so i m thinking to change all 20 of them
eNcode is offline
Old 20-04-2008, 19:35   #4
Cupra Bush King
Lummox's Avatar
Images: 2
Are you sure its the lifters at fault? Whats the oil pressure? Sure its not the timing chain?
www.unit18.co.uk
Lummox is offline
Old 20-04-2008, 19:42   #5
Members Car: 1,8t
timing chain ????????
on oposite side od timing belt
when is his time to change
car has 185 t km
i replaced timing belt, wather pump etc but not the chain
eNcode is offline
Old 20-04-2008, 19:52   #6
Cupra Bush King
Lummox's Avatar
Images: 2
There isnt an interval for the chain but it isnt unheard of the tensioner to loose its strength and the chain starts rattling, especially on start up.
www.unit18.co.uk
Lummox is offline
Old 21-04-2008, 08:09   #7
Members Car: 1,8t
can this tensioner be changed with out taking of timing belt or not
eNcode is offline
Old 21-04-2008, 12:32   #8
KenONeill's Avatar
Members Car: Octavia TDi110
Re: When to change hydraulic lifters?
In the first place, my TDi sounds slightly tappetty when the engine's cold and it needs servicing soonish. So maybe it just wants an oil change?
Secondly, with the note that I've not done the job, the chain provides a drive from the one cam to the other, and is at the opposite end of the head to the main drive belt.
KenONeill is offline
Old 21-04-2008, 12:52   #9
Lfd
Members Car:
Have you tryed useing engine flush when doing a oil change,that may help
Lfd is offline
Old 21-04-2008, 18:07   #10
Pimpmyskodia's Avatar
Members Car: Octavia elegance
my tappets ound pretty bad when engine is cold, and i just changed the oil, so im using engine flush tomorrow and putting my magnatec edge oil in it, hopefully help the engine out.
Octavia 1.9TDi, exeons, painted brake calipers, 18" VW anniversary wheels, rear spoliler, front and rear aero wipers, Ram-Air induction kit, 2x JBL 1200w subs, JL audio door speakers, 3000w Amp, sony GT710 CD player, Tuning box unit. Longlife Full stainless exhaust system, Decat pipe.
Pimpmyskodia is offline
Old 22-04-2008, 09:06   #11
KenONeill's Avatar
Another thought on this; if hydraulic lifters really do need cleaning or replacing, ultrasonic cleaning, the same as for injector reconditioning!
Old 22-04-2008, 11:28   #12
GarryC's Avatar
Members Car: Mk1 Octavia VRS
At work (Piper Cams) we advise customer to change followers at 60 to 80 thousand miles. Just as a mater of caution rather than a need to change them. Its because the spring in them gets soft over time. We also found that once a follower had started to "tap" they are un fixable. Some people say to leave them in a bath of oil etc... but we find that in most cases (not all) this wont cure it, not in the long term anyway. That said, if you know you have had some crap go around the engine, something wear out, then cleaning out the crap to free the oilway out can indeed help.
I hope this sheds some light on them for you.
Kind Regards
Garry
Black MK1 Octavia VRS - 18"BBS RC,H&R Coil Overs, Eibach Rear ARB, Golf R32 Front ARB, Custom Code -Phase 2,JBS CAI pipe, Forge Eliminator DV, Spec Clutch, Single mass flywheel + more
GarryC is offline
Similar Threads
Hydraulic / Gass Bonnet lifters for Mk1 Octy? Rob_OctaviavRS Octavia I 18 18-02-2008 23:20
Change the Clutch Hydraulic Fluid ? Clunkclick Fabia I 4 15-02-2008 22:26
For a cambelt change should I replace the hydraulic damper as well. opinions please?? motoxrob Octavia I 3 25-01-2008 15:58
Hydraulic Clutch TFFabClass14MPI Fabia I 14 07-12-2006 00:16
Hydraulic tappets ivanv Maintenance & Performance 2 21-03-2004 12:40
