39,455 Members 1,489,904 Posts
Where is the MAF
This is a discussion on Where is the MAF within the Octavia I forums, part of the Skoda Model Discussion Area category; Hello all. I have been reading the the threads on here about a problem my wife 2001 110tdi Octavia has. ...
Old 04-02-2007, 15:04   #1
Members Car:
Where is the MAF
Hello all.
The problem being extreme lack of power.
Im thinking (from what I have read) it could be a MAF problem, a VNT (is this some kind of variable vane mechanism?) or
(I'll have to explain this as I dont know what it is called)
theres a component at the rear drivers side of the engine bay in the inlet tract with an actuator, actuator arm and what looks like a diaphragm on top if it.
This is what I suspect could be at fault as on idle this thing makes a rythmic chirping noise plus the shaft (that is on the end of the actuator arm) that looks like it controls a valve within the component (the component with with the metal diaphragm on top) shows quite a lot of oil witness as if the seal is failing.
My plan is to get the fault codes read, then clean/replace the MAF and then remove/ inspect/ replace this actuator assembly.
Does this sound like a reasonable approach?
Also I would be very grateful if could someone describe or post a pic of the MAF please. I
Thanks in advance for your help
Ryan
Ryan220 is offline
Old 04-02-2007, 15:51   #2
Briskodiodion
TeflonTom's Avatar
Members Car: Fabia 2.0/Felicia
Re: Where is the MAF
the maf is located between the airbox and the engine...
TeflonTom is offline
Old 04-02-2007, 15:57   #3
Briskodiodion
TeflonTom's Avatar
Old 04-02-2007, 18:09   #4
Members Car:
Thankyou very much.
So I just give the MAF as good clean - any particular cleaner to use or avoid?
Could you also tell me the name of the part that is just above and to the left of the filler cap please.
Cheers
Ryan220 is offline
Old 04-02-2007, 22:51   #5
Briskodiodion
TeflonTom's Avatar
any decent carb/intake cleaner aerosol can will do... the part above and to the left of the oil filler cap is the egr valve
Old 05-02-2007, 13:50   #6
KenONeill's Avatar
Members Car: Octavia TDi110
What does your wife drive like? There's a known problem with the variable geometry control on the 110 sticking if it never gets exercised, so if she's a gentle driver the inlet side of the turbo may need cleaning.
KenONeill is offline
