This is a discussion on windscreen wipers juddering within the Octavia I forums, part of the Skoda Model Discussion Area category; When it's raining my current wipers swing to the right nice and smoothley but when going back to the bottom ...
| Briskodian Join Date: Jan 2005 Location: Durkar
Members Car: Octavia 130pd Elegance Estate Thanks: 119
| windscreen wipers juddering When it's raining my current wipers swing to the right nice and smoothley but when going back to the bottom of the windscreen they jump and always miss a chunck of rain water. It's driving me up the wall not being able to see clearly Does anyone have any ideas? I've changed new bosch blades and new aero blades and get the same results with each. Pic attached to show what I mean. |
| NOW @ PEUGEOT Join Date: Nov 2003 Location: Bicester,Oxfordshire
Members Car: 2 x octavia vrs 03&01 Thanks: 32
| Re: windscreen wipers juddering Try using some glass "cutting" compound, most window manufactures use it... Worked a treat on mine HTH Phil
__________________ 1)RED ONE, FEW MODS; AND A HEALTHY 237bhp 2)GONE BUT NOT FORGOTTEN, 2ND OWNER OF THE BLACK BEAST, GOD WHAT A HOOT ![]() LACK OF PLANNING ON YOUR BEHALF DOES NOT CONSTITUTE AN EMERGENCY ON MINE |
| The Following User Says Thank You to piv34uk For This Useful Post: | matt@theforce (11-02-2008) |
| Briskodian Join Date: Jul 2006 Location: Newport/Preston
Members Car: Skoda Octavia vRS Thanks: 216
| Re: windscreen wipers juddering or clay your windscreen |
| The Following User Says Thank You to Babs For This Useful Post: | matt@theforce (11-02-2008) |
| Re: windscreen wipers juddering I know this may sound daft, does a glass cutting compound clean the cr4p off the glass? |
| Re: windscreen wipers juddering yes - since it'll be a very fine cutting polish. I would personally try the clay first as it'll be less abrasive |
| Re: windscreen wipers juddering wonder if I should just get the windscreen replaced. It's had too many repairs to mention on the left side of the screen, strange though, no chips on the drivers side though or any damage reported. |
| ECUless | Re: windscreen wipers juddering Juddering can be caused by a bent or twisted wiper arm , it maybe my eyesight but your wiper arm looks a little mis-shapen to me. |
| Briskodian Join Date: Aug 2006 Location: East Lothian
Members Car: Octavia vrs Images: 2 Thanks: 17
| Re: windscreen wipers juddering Looking at the picture it looks like you have Aero style blades but have not attached the spoiler to the wiper arm,this could cause the blade to lift of the screen.
__________________ Diamond silver octavia vRS,xenons,Jetex downpipe with sports cat,Jetex cat back system,Green panel filter,Forge i pro remap,Forge 007 dv,Milotec bumper grills,TT arch vent mod. |
| Briskodian | Re: windscreen wipers juddering ive been told that defective wiper springs can cause juddering problems, but would try windscreen clay first as mentioned.
__________________ Octavia 1.9TDi, exeons, painted brake calipers, 18" VW anniversary wheels, rear spoliler, front and rear aero wipers, Ram-Air induction kit, 2x JBL 1200w subs, JL audio door speakers, 3000w Amp, sony GT710 CD player, Tuning box unit. Longlife Full stainless exhaust system, Decat pipe. |
| The Following User Says Thank You to Pimpmyskodia For This Useful Post: | matt@theforce (11-02-2008) |
| | #10 |
| Re: windscreen wipers juddering Thanks, I've taken a look and the metal arm looks to be straight. Yes I am using the Aero wipers but they didnt come with a spoiler for the wiper arm, the same also happens when I had my Bosch set of blades. I've got the screen clean and polish autoglym products, they do appear to have made it better but it's still not ideal. Will have a look to find out more about this clay before I look at going down the purchasing of new wiper arms. Thanks everyone |
| | #11 |
| Re: windscreen wipers juddering thanks everyone. clay'd the windscreen and it was no better. Bought a new wiper arm and problem solved, only problem now ITS NOT RAINING ![]() |
| | #12 |
| Re: windscreen wipers juddering Quick update. Although the new wiper arm worked to start with the problem is back again. It is worse at 70mph than 60mph but does it as low as 30mphI've tried Clay bar'ng the windscreen New wiper blades New wiper arm Does anyone else have any suggestions? |
| | #13 |
| Briskodian Join Date: Dec 2002 Location: Sheffield
| Re: windscreen wipers juddering I think you'll find this problem occurs as the blade settles in and becomes 'bent' over time in one direction (try lifting it off the screena dn looking at it end on). When this happens the balde doesn't 'flop over' at the end of the up stroke before it returns to the park position - meaning it judders and jumps across the screen. Try gently bending either he arm or twisting the blade itself (they have metal rods in them) to compensate slightly such that the balde in its bent position sits more squarl to the screen. THis usually works.
__________________ If everything was as reliable as a VW... My Skoda would be at the bottom of the JD Power tables! Octavia II 2.0 TDi 4x4 Estate and Fabia I 1.9 TDi Estate and Modified Mk1 Mazda MX-5 1.8iS |
| | #14 |
Members Car: Octavia 2001, 110TDi Elegance estate Thanks: 0
| Re: windscreen wipers juddering if u lift the wiper arms off the windscreen and operate the wipers, does it still judder on the down stroke? |
| | #15 |
| Re: windscreen wipers juddering it could, as mbames suggests be a problem with the mechanism. I would remove both arms, then the scuttle panel from the bottom of the screen to get access to the mechanism. Lubricate all the linkages and bushes, reassemble and test it again.
| | #16 |
| Briskodian Join Date: Jun 2004 Location: in the great north west
Members Car: octavia Thanks: 2
| Re: windscreen wipers juddering what i have done in the past which has worked is: clean the screen with meths to remove all the residue on the screen and then put new wipers on it may also be that the genuine vw/skoda wipers on the passinger side has a slight curve which may causing the problem? |
| | #17 |
| Re: windscreen wipers juddering Mine certainly used to judder, and I think it was more in one direction than the other, and then one day in the pouring rain they seized up. I had to get low-loader back home. Took the linkage out and cleaned it all up. http://www.matthewames.co.uk/briskod...inkage/001.jpg http://www.matthewames.co.uk/briskod...inkage/002.jpg |
| | #18 | |
| Re: windscreen wipers juddering Quote:
I'll see if I can get some time before work tomorrow to have a look. | |
| | #19 |
| Re: windscreen wipers juddering Remember to mark the assemble before taking it all apart... you will need some circlip pliers (or similar) to take it apart. I just cleaned mine up and packed it back out with grease and reassembled. No problems two years on. Might need some pullers to get the wiper arms off (but if you have changed them recently you should be ok)... just read up on getting the scuttle pannel off :-) |
| | #20 |
| Re: windscreen wipers juddering didnt get chance to look today, eldest boy has chicken pox and didn't goto nursery today. So much to looking at this and getting some sleep before my night shifts. Will see if I can have a look over the weekend. |
| | #21 | |
Thanks | |
| | #22 |
| Re: windscreen wipers juddering i still think new set of wipers and a really good clean of the screen with a window cleaning compound has got to be worth doing before you dismantle the wipers. you may find that it works and saves the challenge of punting the wipers back together |
| | #23 |
| Briskodian Join Date: Jan 2007 Location: west yorks
Members Car: Octavia vRS Thanks: 3
| Re: windscreen wipers juddering Matt...get my Bosch blades form Andrew Pages off Jacobs Well Lane...swear by them..(both Page's and Bosch blades)
__________________ PROTECTING THE PEOPLE OF THIS WORLD FROM THE SCUMBAGS OF THE UNIVERSE !!! |
| | #24 |
| Re: windscreen wipers juddering I changed both arms for VW Aero arms a couple of weeks ago and now have bosch aero blades. I've also cleaned the winscreen with a clay bar to get it even cleaner and I have also applied glass polish but it still happens. ![]() |
| | #25 |
| Re: windscreen wipers juddering A litre of oil on the screen should cure it ![]() !!!!
