This is a discussion on y reg octavia estate trying to start with no ignition within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi, Got woken at 5am by neighbour to say car was turning over! It would turn over by itself for ...
| Briskodian | y reg octavia estate trying to start with no ignition Hi, Got woken at 5am by neighbour to say car was turning over! It would turn over by itself for 3-4 turns, have a rest for a minute, then do it again. It is parked on a steep slope with front pointing upwards, so i am thinking that water has got in somewhere, but not sure where at the moment. I have disconnected the battery at the moment. Has anyone else had this, or heard of this weird problem? Thanks in advance Paul |
Members Car: Octavia 2001, 110TDi Elegance estate Thanks: 0
| Re: y reg octavia estate trying to start with no ignition That is not good..... at least it was not in gear! How are the carpets? Any dampess? Maybe the uphill direction of the car has encouraged some water into the cabin somewhere. Handy if you loose your keys though ![]() |
| Briskodian | Re: y reg octavia estate trying to start with no ignition Carpet was wet, back passenger carpet drivers side could have supported goldfish! the water came down the bonnet cable hole and guess what's directly below that? All the important relays. Fusebox was dry. relays soaked, so it was remove them all and get the hair drier out. Car is now parked on more level ground. Beware! Do not reverse park down a steep driveway else you may suffer the same fate. |
| Re: y reg octavia estate trying to start with no ignition i would suggest maybe a bit of silicon sealant around the bonnet cable hole to help prevent more water appearing.... If the rear passenger side was wet too, I would check the gromet near to the pollen filter too. |
| Briskodian | Re: y reg octavia estate trying to start with no ignition I have sealed that area with silicon this morning but i have not checked the grommet near the pollen filter. Thanks for that. |
| Briskodian | Re: y reg octavia estate trying to start with no ignition just realised, the water was in the passenger back behind the driver. Sorry, misled you a bit there. |
| Re: y reg octavia estate trying to start with no ignition probably ingress from the bonnet release which you have resealed then. |
Members Car: Octavia TDi110 Thanks: 65
| Re: y reg octavia estate trying to start with no ignition How was the water getting round the immobiliser? |
| | #10 |
| Briskodian Join Date: Aug 2007 Location: Kent
Members Car: vauxhall vectra and omega and 1.9tdi new fabia Thanks: 37
| Re: y reg octavia estate trying to start with no ignition it wasnt thats why it only turned over and didnt start. the engine will turn over if you have a immobiliser but it wont catch. had a fabia that the passive chip went wrong in the key, the dash used to flash up error and just turn over. new chip and it wad fine. lucky escape but the sounds of things, mine would have walked itself into the gate as i leave mine in gear! lol
__________________ Where has my sig pic gone???? |
| | #11 | |
| Re: y reg octavia estate trying to start with no ignition Quote:
| Octavia II Ignition Wire | Pandybelly | Octavia II | 6 | 09-05-2007 22:07 |
| R reg Felicia 1.6 estate questions! | WoodieGuthrie | Favorit, Felicia, Fun and Forman | 2 | 19-01-2007 22:19 |
| X Reg Fabia 1.4 Engine Start Blocked by Immobilizer | dieselnut | Diagnostics & VAG-COM | 4 | 30-09-2006 17:54 |
| Skoda 1.4mpi estate 01 reg seat strut | olikbu | Fabia I | 6 | 25-07-2006 22:44 |
| ignition module recall/ ignition coil | mw5618 | Fabia I | 1 | 31-05-2006 20:09 |
