This is a discussion on Zimmermann 256mm vented rear discs within the Octavia I forums, part of the Skoda Model Discussion Area category; I'm looking for a supplier of 256mm vented discs for the rear of an Octavia to match the cross-drilled ones ...
| Briskodian | Zimmermann 256mm vented rear discs I'm looking for a supplier of 256mm vented discs for the rear of an Octavia to match the cross-drilled ones supplied by GolfTurbo as part of his 312mm front upgrade kit. Any ideas?
__________________ Si Last edited by SimonT; 11-05-2006 at 12:49. Reason: sp. |
| Briskodian Join Date: Mar 2006 Location: Bristol
Members Car: Ovtavia vRS Thanks: 0
| Re: Zimmermann 256mm vented rear discs Hi, Try, http://www.speedways.co.uk/ they do vented or grooved as requested. Think it comes to £124 a pair though instead of £46 for standard. Andy Last edited by andy_197; 12-05-2006 at 07:20. |
| Briskodian Join Date: Oct 2003 Location: shropshire
Members Car: skoda octavia VRS Thanks: 10
| Re: Zimmermann 256mm vented rear discs mk5 polo rings a bell for some reason
__________________ louder than war |
| | #4 | ||
| Briskodian | Re: Zimmermann 256mm vented rear discs Quote:
I'm trying to find some Zimmermann 256mm vented rear discs ![]()
__________________ Si | ||
| 207/340 Join Date: Oct 2004 Location: Around Manchester & Cheshire
Members Car: Skoda Fabia vRS Thanks: 457
| Re: Zimmermann 256mm vented rear discs A Mk5 Polo (well some of them) use a 256mm on the front? My GTi for example... Is that what you're thinking of? Steve
__________________ Wardy's Fabia vRS ![]() xenons : sunroof : cruise : OEM+ ![]() "Racing is life. Anything before or after is just waiting." - Steve McQueen "If in doubt, flat out." - Colin McRae |
| | #6 | |
, but besides, that doesn't help me find a Zimmermann supplier![]() It'd be easier to find some rocking horse poo ![]()
| Re: Zimmermann 256mm vented rear discs No, they are 4 x 100. |
| Re: Zimmermann 256mm vented rear discs Not sure mate - Mk5 Polo is 4-stud though, so may pose a problem? I would consult a friendly neighbourhood Skoda tech if I were you ![]() Steve
