This is a discussion on 1.6 FSI plastic engine cover removal within the Octavia II forums, part of the Skoda Model Discussion Area category; Hello. Does anyone know how can I remove the plastic engine cover of the 1.6 FSI engine? I have tried ...
| Briskodian | 1.6 FSI plastic engine cover removal Hello. Does anyone know how can I remove the plastic engine cover of the 1.6 FSI engine? I have tried to pull it up but it seems that it has the air fiter built-in and I'm afraid not to do any damage to it. Also I can't locate where the oil filter is mounted. I checked the MANN catalogue and it seems that it is mounted inside the engine with some kind of aluminium cap to seal it but I can't find it. Any help please? |
| Re: 1.6 FSI plastic engine cover removal Lift it up, no fixings, but there is a connector on the right for the air temp sensor and a small pipe. Oil filter is down on the left hand side (above alternator) under a plastic cap (36mm nut on the top iirc). |
| Briskodian | Re: 1.6 FSI plastic engine cover removal Thanks. I removed it with no problems. And the oil filter also. |
