39,456 Members 1,489,918 Posts
1.9TDi v 2.0 PD
This is a discussion on 1.9TDi v 2.0 PD within the Octavia II forums, part of the Skoda Model Discussion Area category; Currently on my 3rd Elegance in 9 years, which must say something.... The new wheels are 2.0 PD, replacing 2 ...
Old 15-06-2008, 17:32   #1
Members Car:
1.9TDi v 2.0 PD
The new wheels are 2.0 PD, replacing 2 1.9TDi's, but I'm a little disappointed in low rev pickup. The old 110s seemed to pick up their skirts and go a lot smarter than the new 140.
No complaints above about 2000 rpm, but around 1400-1800 it seems to fall asleep....
I thought at first it might be the new tight engine, but it's done nearly 3000 miles now, and still a bit lethargic at low speeds.
Any thoughts, or is 3k still a bit early? I don't remember it being a problem on the new 110's.
I believe this is now a fly-by-wire. Is that the difference?
turnoot is offline
Old 15-06-2008, 17:41   #2
go green
mdk1's Avatar
Members Car: Roomy 3 & Fabia
Re: 1.9TDi v 2.0 PD
Welcome to briskoda,
never really remember a problem with my 2.0tdi oct'y, maybe i just had my foot on the floor more.
Mike.
Mine Skoda Roomster 3 TDI in matallic Anthracite Grey MK**LJK
Swmbo's Skoda Fabia 2.0I Elegance in Dark matallic Blue MK**LJK
mdk1 is offline
Old 15-06-2008, 18:46   #3
Members Car:
Re: 1.9TDi v 2.0 PD
Test driving the 140 and the 170 and they seem to suffer the same as the PD130 in that below turbo boost they are a bit crappy compared to the 110!
I have a 110 and liz a PD130 and around town mine is much easier with better off boost performance (smaller turbo?). However, the trade off is much much better mid and top end performance in the PDs
One Seat Toledo TDI 110 SE and One Furby vRS.....how come the missus gets the fast one
'04 Plate Silver vRS - pretty much stock apart from the Vredestein SporTrac3s!
Nathanio is offline
Old 15-06-2008, 19:03   #4
Dr Zoidberg's Avatar
Re: 1.9TDi v 2.0 PD
My PD140 never felt sluggish after I changed from a Mk1 tdi 110.
The economy did improve noticably over the first 20k miles , and it certainly got a bit faster too
Alex
www.drzoidberg.co.uk
Dr Zoidberg is offline
Old 02-07-2008, 12:49   #5
Members Car:
Re: 1.9TDi v 2.0 PD
I found the 2.0 140 PD really disappointing at first. After about 3-5000 miles, it settled down and is now almost as good as the 1.9 130 in the oh's Fabia vRS. Happy now.
The power is delivered much more smootly in the 2.0 and will run happily at low revs, whereas the 1.9 is sluggish low down but then takes off as the turbo gets going.
nohands is offline
Old 02-07-2008, 18:27   #6
jamesmckelvie's Avatar
Members Car:
Re: 1.9TDi v 2.0 PD
Which 1.9 are you referring to?
1.9 TDI Elegance - Cappuccino Beige
Plenty enough power and torque for the economy offered
jamesmckelvie is offline
Old 02-07-2008, 19:23   #7
Members Car: 2.0 TDI - DSG
Re: 1.9TDi v 2.0 PD
In the 2.0 the "accelerator" works very different than in the 1.9
Half down is only 20% power and then it's start to work - you will get use to it after a while.
Cheers
Ivan
2.0 Tdi - DSG
Ivan-DK is offline
Old 02-07-2008, 22:08   #8
Members Car:
Re: 1.9TDi v 2.0 PD
It just doesn't feel as sharp, somehow. Mid to upper range is great as long as the revs are above about 2500, but it's just that "Oh ****" moment as you turn out of a junction, and the artic's going quicker than you thought......
Can't even raise a chirp from the tyres from standstill unless you load up with beans, and slip the clutch a bit.
I think that Ivan-DK might be on the right track with the accelerator.
It's done about 3500 miles now, so hopefully it will improve a bit (and the mpg, which is also a bit disappointing at about 10mpg worse than the 1.9)
turnoot is offline
Old 02-07-2008, 22:17   #9
Re: 1.9TDi v 2.0 PD
The pickup should be strong from 1,300 - pulls hard. BUT you do have to put your foot well down.
Greg.
greg123 is offline
Old 02-07-2008, 22:25   #10
BRISKODA Staff
mannyo's Avatar
Re: 1.9TDi v 2.0 PD
You need to use more throttle, mine spins the wheels easily pulling away in first, or indeed applying full throttle when already moving. The same thing happens when rolling in second as well, full throttle=wheelspin.
Manny
2005 Octavia 2.0TDi Elegance combi
my skoda website http://www.octaviars.co.uk
Join the briskoda.net folding team click Here for more info
mannyo is offline
Old 03-07-2008, 09:14   #11
Members Car:
Re: 1.9TDi v 2.0 PD
Don't think anyone's ever accused me of not using enough throttle before
I tried some tests on the way to work this morning (quiet roads, honestly), and with the foot on the floorboards in any gear, there's no real grunt until about 2000rpm.
Another little symptom that I've noticed is that if taking a tight corner in the wet with welly on the 1.9, the traction control kicked in, and a nice satisfying, controllable angle of attack could be varied with said welly.
On the 2.0PD, traction control seems to just kill everything and it takes a kind of lurch and bogs down.
I think I might see if the dealer has a demonstrator around to borrow for comparison.
turnoot is offline
Old 03-07-2008, 19:25   #12
SilveRS's Avatar
Re: 1.9TDi v 2.0 PD
On the 2.0PD, traction control seems to just kill everything and it takes a kind of lurch and bogs down.[/quote]
That doesn’t sound right, I’ve had two 2.0 tdi's now and the traction control is quite restrained. Before going diesel I had a MK1 vRS and that literally killed all power when spinning the wheels in the wet.
SilveRS is offline
Old 04-07-2008, 09:59   #13
Re: 1.9TDi v 2.0 PD
I think the only way we can settle this is if you go and test drive another similar model. The 2.0 140 I have in with DSG pulls hard from 1,300 and changes up before 2,000 quite often while slinging you forward at a good pace, eg don't keep your foot on for long or you'll be doing 80mph on that 40 road out from the roundabout.
If you drive another you can tell us what you think and then we can look at the 'problem' if there is one, if not call it your perception and maybe look at chip or custom tuning to give you the spread of power you 'feel' is right when you are driving.
Do rule out problems before going down the tuning route though!
Good luck and please post back, Greg.
PS maybe another 2.0 owner in your area if you search or post on the various forums can take you out.
greg123 is offline
Old 04-07-2008, 13:44   #14
thebobster's Avatar
Members Car: VW Golf TDI 105 Match
Re: 1.9TDi v 2.0 PD
Sound like you need to swap tyour carpet slippers mate - nowt wrong with the grunt in my 2.0TDI goes like the proverbial off a shovel
VW Golf 1.9TDI Match
Gone but not forgotten....
2.0 TDI Elegance Octavia 2 17" Pegasus Alloys and sports suspension, front and rear parking sensors. Standard engine. around 48mpg average.
thebobster is offline
Old 04-07-2008, 17:46   #15
matt@theforce's Avatar
Re: 1.9TDi v 2.0 PD
could the difference in low down grunt be down to the 1.9's being 8valve and the 2.0's being a 16valve and the 16valve engine needing to be worked harder at lower rpm?
They are 2 completly different engines and as such will respond and work better in different ways.
Support Briskoda Join FREEDOM >>> <<<
matt@theforce is online now
Old 04-07-2008, 17:58   #16
Members Car:
Re: 1.9TDi v 2.0 PD
Have to say that I wasn't aware that it was 16v, and from old Golf GTI days, I know that the 8-valver was a lot more driveable than the 16v (although quite considerably slower).
Can't help thinking that there's either something slightly amiss, or that the engine's still quite tight. (I'm struggling to average 40mpg, while the 1.9 did 50; it's new owner's claiming 62...!!)
More than 4,000 on the clock now.
turnoot is offline
Old 04-07-2008, 18:25   #17
Re: 1.9TDi v 2.0 PD
The 2.0 tdi with DPF is a 8 valve engine
Cheers
Ivan
2.0 Tdi - DSG
Ivan-DK is offline
Old 04-07-2008, 18:29   #18
Re: 1.9TDi v 2.0 PD
Take me away (double post)
Cheers
Ivan
2.0 Tdi - DSG
Ivan-DK is offline
Old 05-07-2008, 20:16   #19
skomaz's Avatar
Re: 1.9TDi v 2.0 PD
No it's not - its a 16 valver!
If everything was as reliable as a VW... My Skoda would be at the bottom of the JD Power tables!
Octavia II 2.0 TDi 4x4 Estate and Fabia I 1.9 TDi Estate and Modified Mk1 Mazda MX-5 1.8iS
skomaz is offline
Old 05-07-2008, 21:38   #20
Members Car:
Re: 1.9TDi v 2.0 PD
I've had 2 2-litres now and been very happy with power from both. But - there isn't much below about 1500. Pulls like a train from 2000 upwards. Tails off above about 3500-4000.
Hope you get any probs with your ironed out.
dominic81 is offline
Old 06-07-2008, 08:38   #21
Members Car:
Re: 1.9TDi v 2.0 PD
Seems to be quite a few different views....
My experience is in line with dominic81; practically nothing at 1500rpm, but goes (and well) above 2000.
I've more or less come to the conclusion (because of the fuel consumption), that the power plant needs quite a long time to loosen up, so I'll hang fire for a couple of thousand miles more, and see how it's doing.
Thanks for all the input.
turnoot is offline
Old 06-07-2008, 10:25   #22
Re: 1.9TDi v 2.0 PD
All with DPF are 8 valve engine. Even the 2.0 Tdi RS DPF has only 8 valve
SkodaOctavia2.0TDIRSDPF - NewCars on RT Motoring powered by Carzone.ie
Cheers
Ivan
2.0 Tdi - DSG
Ivan-DK is offline
Old 06-07-2008, 11:34   #23
Re: 1.9TDi v 2.0 PD
I,ve got a 2.0tdi estate 35,000 miles and I get similar sounding characteristics.There is not much power if you don't use quite a bit of throttle when setting off.I think it is something you get used to.My son has a golf tdi that is the 1.9 it has more power low down, but mine really has it beat everwhere else.Regards Monkster.
monkster is offline
Old 06-07-2008, 13:13   #24
Members Car:
Re: 1.9TDi v 2.0 PD
On the other hand......
If you look at the power curves on the Superchips website, the standard 110/140 should produce (at 1500rpm) 31/42 bhp and 150/200 Nm of torque respectively, so the 140 SHOULD feel livelier at low revs.
Isn't that frightening, 42 bhp? Wow!!
Does have to be pointed out though, that their "standard" 140 was producing 148 to start with.
turnoot is offline
Old 07-07-2008, 10:03   #25
skomaz's Avatar
Re: 1.9TDi v 2.0 PD
Iavn,
Suggest you check with Skoda rather than a motoring website. All brochures note Skoda Octavia 2.0TDi's are 16 valve and I'm positive my 4x4 2.0 TDI with DPF is a 16 valver.
Maybe a difference for the Eire market...?
Last edited by skomaz; 07-07-2008 at 15:26. Reason: to clarify I was talking about Octavia's only
skomaz is offline
Similar Threads
1.6 vs 1.9TDi bunglebear32 Fabia II 9 29-04-2008 21:59
1.9TDI Won't start. AlexvanDijk Fabia I 6 09-08-2007 21:07
What next for my 1.9TDI Octy aerodynamic18 Octavia I 19 05-04-2007 15:47
1.9tdi Pd moley Octavia II 4 01-04-2007 19:12
