This is a discussion on 140 2.0L Oil within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi, I'm trying to find the correct oil for a 140 PS 2.0L diesel on fixed servicing. I've managed to ...
| Briskodian | 140 2.0L Oil Hi, I'm trying to find the correct oil for a 140 PS 2.0L diesel on fixed servicing. I've managed to find the spec for a car on variable (thanks Denis Anyone help? Thanks,
__________________ Octavia 4x4 |
| Briskodian Join Date: May 2007
Members Car: octavia estate 140bhp DSG Thanks: 0
| Re: 140 2.0L Oil Hi, Vw507-01 For Fixed Servicing, Main Dealer Price £38 For 5l [shell Helix] . You Can Also Use Vw506-01 Or Vw507 Longlife Oil As Used On Variable Servicing. |
| Briskodian Join Date: Apr 2007 Location: Norfolk
Members Car: Octy II L&K 2.0TDI DSG Thanks: 35
| Re: 140 2.0L Oil I presume the longlife oil is better quality to cater for variable servicing, hence it is ok, maybe over the top though, for a fixed service engine?
__________________ 2007 Octavia Hatchback, 2.0TDI DSG L&K in Black Magic. |
| Briskodian | Re: 140 2.0L Oil IIRC the PD140 is good on VW 506.1 or VW507 on variable. Yes it is better oil so that it can last the extra distance. If it was me i'd do the service as a variable with the good oil and if you want an early oil change you can do that at 10 or 12k. If it isn't convenient then you can go on the variable one until the car tells you ![]()
| Re: 140 2.0L Oil Thanks.
| Briskodian | Re: 140 2.0L Oil Look at the sticky above for all the info you need as this has been covered many times. Opie Oils can supply the spec you need via the net. |
