39,455 Members 1,489,908 Posts
2.0 TDi running a bit lumpy
This is a discussion on 2.0 TDi running a bit lumpy within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi, My occy seems to have developed a bit of roughness when running around town. when you reach around 30-35 ...
Old 27-04-2008, 09:42   #1
Farmerp2005's Avatar
Members Car: Octavia 2.0 TDi
Hi, My occy seems to have developed a bit of roughness when running around town. when you reach around 30-35 and feather back a bit on the accelerator, it starts kangarooing a bit. Put your toe down and it dissapears again. It runs fine on the motorways and is fine when at idle. It doesn't seem to matter what gear you are in when it does this. Has anyone any ideas on what this could be, or is this definitely a trip to the stealers?
Cheers,
Martin
Farmerp2005 is offline
Old 27-04-2008, 11:55   #2
dstev2000's Avatar
Re: 2.0 TDi rnning a bit lumpy
Sounds like the notorious 2.0TDI issue that is usually known as the 'Stutter'.
The engine appear to cough and misfire slightly under light throttle at about 2300-2500rpm. Noticeable on the motorway at about 75 -80 IIRC (of course none of us do that kind of speed on a public road do we...)
Both of my 2.0TDI's have done it and the vRS does it on very rare occasions.
As for a fix - I know there was a fix for the Fabia vRS that suffered a similar problem but I don't know if SUK have bothered to sort the 2.0TDI as yet.
IT gets much worse if you fit a performance filter as well.
MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely!
SWMBO's: MY08
vRS TDI - Standard
dstev2000 is offline
Old 27-04-2008, 13:47   #3
Funny thing is, this started about a month after the service. It didn't do it before. Did yours do it from the get go or did it develop over time?
Old 27-04-2008, 13:54   #4
Cupra Bush King
Lummox's Avatar
Images: 2
If its happening around 3000 to 3500 rpm I would be thinking its a fuel lift pump issue.
How many miles have you done?
www.unit18.co.uk
Lummox is offline
Old 27-04-2008, 14:02   #5
I've done just over 25,000 miles, the problem seems to be about 1500 - 1800 revs though. It is definitely under light throttle. Just tried it under cruise at that speed and it doesn't appear to happen then. Not sure if that's relevant.
Old 27-04-2008, 14:49   #6
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
Have you changed brand of fuel lately?
Stu
VRStu is offline
Old 27-04-2008, 16:44   #7
dstev2000's Avatar
Mine never does it when the cruise is on but will do it under manual throttle usage, my 07 does it and my '06 did the same thing too. I just live with it. Never had any faults logged either.
SWMBO's: MY08
vRS TDI - Standard
Old 27-04-2008, 16:52   #8
The fuel was my first thought, so I've tried a couple of different ones (Esso being the latest) and it's made no difference. If it's a common fault then fair enough, just seems strange that it's a recent phenomena. Surprised Skoda haven't sorted it out if it's a very common problem though. Could it be something to do with the accelerator pedal (or the controller it's connected to) getting a bit "Noisy", much like a volume conrol can?
Old 27-04-2008, 20:23   #9
Re: 2.0 TDi running a bit lumpy
Mine used to do it, which got worse over a period of time. No longer does it since having throttle body replaced.
tomo2001 is offline
Old 30-04-2008, 17:29   #10
114whp per ton
yashicamat's Avatar
Members Car: Nissan Primera GT
Mine has just started doing this today.
Seems to be worst between about 1200rpm and 2300rpm. Almost non existant above 2300 rpm and also not noticeable when squirting the throttle, it's just when crusing. Very annoying, I've also seen a fairly significant drop in fuel economy too - maybe related? No change in fuel . . . used the same fuel for months now from the same station.
Rob
Nissan Primera GT in Silver
'56 Octy 2 2.0TDi Elegance . . . also gone but not forgotten
2002 Fabia 1.9TDi . . . . gone but not forgotten
http://uk.youtube.com/yashicamatonline
yashicamat is offline
Old 03-05-2008, 10:39   #11
Weird thing is, Mine's stopped doing it again now. I've heard lots of peeps say it's the Throttle body that gets a bit gummed up. Cleaning it out solves the problem, but if it's under warrantee, the stealers should replace it for you. If the problem comes back, I'll put it in and let you know what happens.
Old 03-05-2008, 15:51   #12
114whp per ton
yashicamat's Avatar
Mine decided to start shouting about the problem by bonging, lighting up the CEL and displaying "Emissions Workshop!!" on the maxidot screen.
Car booked in for Wednesday, but I have a lot of miles to drive between now and then.
Rob
Old 03-05-2008, 18:45   #13
Members Car:
I don't know if i'm having the same problem but i've started to notice the engine is lumpy under idle, but only when the engine is warm. Its fine when cold, but when warm, you can feel the engine juddering through the seat at idle. I find that it is worse when i have been either moving along slowly and stopped, or stop start in traffic and then come to a hault.
Also, from cold, when the outside temperature is above about 15 degrees, if you pull away and stop, you can here a knocking noise coming from behind the steering wheel when the engine is at idle. Isn't there when outside temp is cold and doesn't go away once car is warm. Any ideas?
Car goes in next week anyway so i'll speak to the dealer.
Car is a 2005 2.0 tdi.
hoskurner is offline
Old 03-05-2008, 19:29   #14
Octavia5's Avatar
Had a similar problem on my PD140 some time ago - dealer changed the 'Vacuum Valve Body'? and the problem went away, I was told this was a known fault and cure.
'06 Octavia Elegance 2.0TDI DSG - Diamond Silver
Octavia5 is offline
Similar Threads
Remapped and now Loosing power and Very lumpy running when cold RichB86 Octavia I 6 18-12-2007 16:24
lumpy running harryhill Favorit, Felicia, Fun and Forman 12 29-11-2007 01:15
1.9D lumpy running cured Call me Ishmael Favorit, Felicia, Fun and Forman 0 10-01-2007 13:20
Running in a 2.0 TDi alock Octavia II 13 19-08-2005 20:02
Running in TDi robert79 Maintenance & Performance 4 16-06-2004 18:51
