This is a discussion on adjusting xenons? within the Octavia II forums, part of the Skoda Model Discussion Area category; Is there away to adjust the xenons so they point abit lower? i have tried reseting them with vag com ...
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
Members Car: Octavia Mk2 FSI Sport Thanks: 11
| adjusting xenons? Is there away to adjust the xenons so they point abit lower? i have tried reseting them with vag com and they still seem to high (when drivers start flashing you you know theres a problem). They also go through stages where they really bounce or if you going along a perfectly flat road they will bounce for no apparent reason. help this is doing my head in now. |
| | #2 | |
| Briskodian Join Date: Jul 2006 Location: Portugal
Members Car: Octavia 2.0 TDi Sport 2006 Thanks: 3
| Re: adjusting xenons? Quote:
"Headlight unit off: Open bonnet and look down You will see a white plastic wing nut thing on a black threaded screw coming through the engine front member from the back of the top of the headlight unit. Remove it There is a locking lever at the bottom of the headlight on the left. Push down on the plastic tab and pull the lever straight out (away from the headlight). It might need a bit of a tug. Then just carefully withdraw the headlight using light pressure from behind. Then reach behind the headlamp, pull out the little locking tab at the bottom of the wiring connector and remove the connector. This is a bit awkward as you are doing it by feel but you will get it eventually. Offside is exactly the same except there is enough slack in the wiring loom to allow you to change bulbs without disconnecting the wiring connector. Unscrew plastic nut (not in picture but where arrow A is pointing) and pull lever B in direction of arrow. Unclip wiring loom which will leave the headlight assembly free to remove. All the bulbs are now very easy to replace except the sidelights (minnimum). This is a real pig of a job and you will almost certainly need two pairs of hands and some very thin bull nose pliers!. Incidently, the red arrows point to the screws which adjust the headights, top one adjusts side to side and the bottom adjusts up and down. To change the headlight bulb: 1) Unscrew the white plastic retaining nut holding the headlamp in place. 2) Pull the metal lever (b) out beneath the headlamp unit 3) The headlamp unit should pop forward, you can now disconnect all leads and the headlamp is out 4) Unclip both large metal springs holding the black dust cover in place and remove the dust cover How do you gain access to change a bulb in the H8 front foglight? Pull out the grill next to it. with a torx bit (?) undo the retaining screw and pull out. access is from the back Indicator bulb change: There's a small bolt on the top in the corner where the wing meets the front. (Actually it's a self tapping screw but it looks like a bolt!) Undo the bolt and the whole indicator unit slides forwards until it's free of the body work. Bulb holder is a bayonet fitting in the rear of the assembly. Job done! Be careful putting it back. Adjustments: With the bonnet open you can see two hex nuts one above the other on each light fitting, these adjust the horizontal and vertical position of the projector lens, this is the same with halogen and xenon bulbs, you don't need to mess with these unless you intend to fiddle with the dipped beam alignment. If you look inside the engine compartment at the rear of the light fitting you will see the white nylon nut that keeps the fitting in place, directly underneath this there is a single upward facing hex nut, this is what adjusts the up/down position of the main beam. Note, this screw adjusts the entire main beam unit - that's the bulb AND the surrounding reflector. I found mine needed to be wound down quite a bit to achieve the desired effect and as a result there is no longer a gap between the top of the xenon cut off and the main beam. The output from the nightbreakers means the colour difference is minimal and the light output is excellent too."
__________________ Octavia 2006 2.0 TDI Sport (equal to L&K in UK) - 17' wheels, Sport suspension, Xenons, Audience with Sound System, Bluetooth, Front & Back Parking Sensors - - VAG COM - | |
| Briskodian Join Date: Aug 2006 Location: Herts
Members Car: Octavia vRS TDI - Koni FSDs & RallyFlapz Thanks: 46
| Re: adjusting xenons? I got my dealer to align mine properly for me as a 'warranty' job as they were both too high and one higher than the other!
__________________ Mine - '07 Octavia vRS TDI, Superchips BlueFin (210bhp/293lbft) 'Winter wheels' 7.5J x 17" Audi S-line, Ultrac Sessantas 225/45 17, xenons, rear parking sensor, heated seats (driver's Recaro Style full leather), climate/jumbo etc., Koni FSDs, Neuspeed Rear ARB & Short-Shifter, K&N induction kit, RallyFlapZ - Colin McRae memorial decals. Wife's - '08 Roomster Scout 1.6 Tiptronic, Cruise, parking sensors Son's - '02 Fabia 1.4mpi, vRS 16" alloys, Michelin Pilot Exalto 2 195/45 16, vRS front bumper, Koni Sport shocks. |
| | #4 | |
Members Car: Octavia II vRS Thanks: 29
Dips or Fulls?
__________________ GAFF ![]() Briskoda Ireland Events, Meets & Pictures.....Race Blue Octavia MkII vRS.....Old Octavia MkI vRS | |
| Re: adjusting xenons? I tried the Full beams this evening, a good tip for anyone planning it is to MARK THERE CURRENT LOCATION FIRST, EG TIPEX. Anyway looking at the part the allen head screw actually turns, I turned it 2 full turns clockwise (when looking from back of lamp). The were touching the road , anyway its a good thing I did over adjust them as it looks like the drivers side one is slightly higher (would this be normal ????), anyway I backed off the Passangers side one by 1 revolution and I think they are more level now. So I brought back up the level of both a bit, so they are now Drivers 1.25 turns & Passangers 0.25 turns from there original position.
| Briskodian Join Date: Dec 2002 Location: Sheffield
| Re: adjusting xenons? Only two full turns? - Mine needed three!
__________________ If everything was as reliable as a VW... My Skoda would be at the bottom of the JD Power tables! Octavia II 2.0 TDi 4x4 Estate and Fabia I 1.9 TDi Estate and Modified Mk1 Mazda MX-5 1.8iS |
| Re: adjusting xenons? On the Black allen head screw or the White part that it turns? My adjustment was on the white part.
| | #9 | |
The mian beams no point at the road instead of treetops and are actually useful!
__________________ If everything was as reliable as a VW... My Skoda would be at the bottom of the JD Power tables! Octavia II 2.0 TDi 4x4 Estate and Fabia I 1.9 TDi Estate and Modified Mk1 Mazda MX-5 1.8iS | |
| | #10 |
| Briskodian Join Date: Apr 2006 Location: Blandford Forum, Dorset
Members Car: Octy vRS Estate Thanks: 0
| Re: adjusting xenons? If it is of any interest, you do have a left / right adjustment on the main beams also. I found tweaking these adjusters (as well as the up and down ones) lets you ‘fine tune’ the main beam pattern quite nicely. Regards Ken
__________________ Got a full 6-pack but lacks the plastic thingy to hold it all together |
| | #11 |
| Briskodian Join Date: Aug 2006 Location: East Lothian
Members Car: Octavia vrs Images: 2 Thanks: 17
| Re: adjusting xenons? On the mk1 octavia,after any adjustment using the manual adjusters,you have to reset the values using vag com.
__________________ Diamond silver octavia vRS,xenons,Jetex downpipe with sports cat,Jetex cat back system,Green panel filter,Forge i pro remap,Forge 007 dv,Milotec bumper grills,TT arch vent mod. |
| | #12 | |
), the fulls are actually running along the top of the dips, but should the fulls over lap or have a gap? -------n--n-----I actually think because of the upside down V's being apart theres still a dead spot in the middle between them. @ Crinkley wheres the sidewards adjustment?
| | #13 | |
I used a deserted unlit car park to set them up (it’s better than tying to dodge fast moving traffic on a B road) and just played with the adjusters until they gave the results I wanted. The left / right adjusters are sort of diagonally opposite the up & down ones, at the back of the lamp fitting and are (just about getattable) using a flat bladed screwdriver. (N.B. They are a bit flimsy, please make sure your screwdriver fits them well, coz if it don’t, you’ll chew the ends of them off)! Picky attached which may help. Ken.
__________________ Got a full 6-pack but lacks the plastic thingy to hold it all together | |
| The Following User Says Thank You to Crinkley Ol Sod For This Useful Post: | bahnstormer vrs (08-03-2008) |
| | #14 | |
| Go Gadget Octy! | Re: adjusting xenons? Quote:
Quick test is, car about 5 ft from a wall. If light cutoff is above lights, get them adjusted! Also since adjusting, rather than both lights giving a perfect horizontal, there is now a -~- looking line on the horizontal. Lights also point towards the pavement more, and you now notice the difference when you use mains (before didnt see any change from the drivers seat). You'll always get some drivers who flash thinking your lights are too bright, but not EVERY car | |
| | #15 |
| Re: adjusting xenons? Update to my last post. On reflection (no pun intended), in the text of my attached photo I may have reversed the effect that turning the main beam adjuster has. Best bet is to point the car at a wall (in the day time) and try the adjusters first to see which way the beams deflect relative the rotation of the adjusters. This will give you the chance to become familiar with the operation before setting the lamps up for the real world (i.e. on the road / car park at night). Ken.
| | #16 | |
| | #17 | |
Having read these instructions, I found the sideways adjusting screw and brought the main beam to the right so that it illuminates the dark spot within the 'V' of the dip beam. Eureka - I can now see the road further ahead on main beam!! Thanks for the instructions.
__________________ Mine - '07 Octavia vRS TDI, Superchips BlueFin (210bhp/293lbft) 'Winter wheels' 7.5J x 17" Audi S-line, Ultrac Sessantas 225/45 17, xenons, rear parking sensor, heated seats (driver's Recaro Style full leather), climate/jumbo etc., Koni FSDs, Neuspeed Rear ARB & Short-Shifter, K&N induction kit, RallyFlapZ - Colin McRae memorial decals. Wife's - '08 Roomster Scout 1.6 Tiptronic, Cruise, parking sensors Son's - '02 Fabia 1.4mpi, vRS 16" alloys, Michelin Pilot Exalto 2 195/45 16, vRS front bumper, Koni Sport shocks. | |
| Adjusting Xenons with VAG-COM | Irf | Fabia I | 11 | 16-12-2007 22:16 |
| Non adjusting Xenons | superb555 | Superb | 3 | 28-11-2007 07:54 |
| How do I know if my Xenons need adjusting? | des_pd_ tdi | Fabia I | 4 | 19-06-2007 23:02 |
| Adjusting Xenons | r32 | Fabia I | 6 | 19-10-2006 11:29 |
| Xenons not auto adjusting ? | MotorMad | Octavia II | 4 | 17-02-2006 21:49 |
