This is a discussion on Advice before 1st service within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi all, Got my 1.9tdi Elegance (2nd hand) going in for it's 1st service on Friday and got a couple ...
| Briskodian Join Date: Dec 2007
Members Car: Octavia 1.9TDI Elegance Thanks: 11
| Advice before 1st service Hi all, Got my 1.9tdi Elegance (2nd hand) going in for it's 1st service on Friday and got a couple of things I'm thinking of asking the dealer ot look at. Wondered what people's opinions are for: 1. Central Locking Mine is configured for driver door unlock on 1st button depress - and everything else on 2nd press. But it's a bit frustrating as if you leave it just a few seconds too late, it doesn't open all doors. Been thinking of getting then to change the setting to one press unlocks all. What do people have on their cars? 2. Delamination I think my windscreen has this problem, it affects about 75% of the bottom edge but only a couple of millimetres deep. Do you think it's worth getting the dealer to look at this? Is any sign of delamination a straight forward case of changing the screen under warranty? 3. DMF I asked the local Skoda dealer a couple of months ago to check whether my car was on the recall list (it wasn't according to them) but is it reasonable for me to ask them to make the physical check of the DMF?? Any advice/comments would be greatly appreciated. Cheers. |
| | #2 | ||
| Briskodian Join Date: Mar 2004 Location: North Wales
Members Car: Octavia II VRS Estate CR2.0tdi in Race Blue Thanks: 138
| Re: Advice before 1st service Quote:
not sure on this one, suppose it may depend on how helpful the dealer is feeling
__________________ 2008 OctyII VRS Estate CR 2.0Tdi Race Blue - 18" Zeniths - Sunset Glass - Maxidot - Dual Zone - Cruise - Jumbo Box/Rear Elec - Rear park - Active headrests - Curtain Airbags - MFD2 & OEM Bluetooth my flickr Photos | ||
| The Following User Says Thank You to sworrall For This Useful Post: | kmc (20-03-2008) |
Members Car: Octavia 2 Elegance Estate 1.9 TDI DSG Thanks: 13
| Re: Advice before 1st service Is the VAG COM plugged into the car on a servicing? |
| Briskodian Join Date: Sep 2004 Location: London
Members Car: Renault sport clio 197 Images: 1 Thanks: 36
| Re: Advice before 1st service |
| | #5 | |
Windscreen should be replaced without question (known problem). One press opening as said may be done free of charge. If not it shouldn't cost very much. Defo worth getting done. I would also recommend getting the confirmation chirp enabled so you know the car is locked. | |
| The Following User Says Thank You to Chris.G For This Useful Post: | kmc (20-03-2008) |
| Briskodian Join Date: Feb 2008 Location: West Berkshire
Members Car: Silver Octavia Scout Thanks: 8
| The Following User Says Thank You to scouter2 For This Useful Post: | sworrall (22-03-2008) |
| Re: Advice before 1st service Hi all! Just had the service done and everything okay. In the end, the Skoda garage did the central locking one press change for free although because the service manager was on holiday (it being Good Friday), they need me to take it in again for the windscreen to be looked at for the delamination. The woman in servicing who I dealt with seemed to hint that it was a known problem tho! They even swapped my front/rear wheels over (since they get taken off anyway) as the fronts were getting worn down. They also adjusted my drivers door as it's always sat proud by about 2mm when closed since I've had it (3 months). Car didn't get washed or anything. Nothing spectacular but efficient service - I went to Farmers Nottingham. Cost was £217 - this was after I haggled them down on the phone when I booked the service - they originally wanted £270!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Will take the car down on Tuesday to see what they say about the windscreen. Have a Happy Easter all!! ![]() |
| Re: Advice before 1st service thanks id forgotten about that. its not available on my maxidot though as its a 55 plate. that function only came in later so it depends on how old your car is
| Ok to delay 1st service | Flanno | Octavia II | 30 | 22-03-2008 22:02 |
| vRS 1st service | wishlist | Octavia I | 3 | 29-01-2008 11:10 |
| 1st service due | mitchtech | Fabia I | 2 | 20-05-2007 10:50 |
| 1st major service.. | Terry G | Octavia I | 16 | 22-02-2007 15:57 |
| 1st Year Service | Mark Harrison | Maintenance & Performance | 2 | 14-10-2004 08:31 |
