This is a discussion on Advice on a fault please. within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi, Can anyone give advice on a fault on my 05 1.9TDi PD. I have the management light on and ...
| Briskodian | Advice on a fault please. Hi, Can anyone give advice on a fault on my 05 1.9TDi PD. I have the management light on and the fault codes relate to the Manifold Intake Flap not functioning. From what I have managed to find out this is usually open then closes briefly when the engine is switched off as an anti shudder or something. Does anyone know if this is right and if so will I be ok to carrying on driving it. I am reluctant to just replace it as they cost over £260. Any advice from you experienced Briskoda members gratefully appreciated. |
| Not anymore Join Date: Oct 2007 Location: Bournemouth
Members Car: Octavia TDi 2006 Thanks: 107
| Re: Advice on a fault please. Hi there is a thread about this on here if you use the search facility.
__________________ Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged-Metallic Flamenco Red DMF Reqiured soon ![]() Previous: 06 Octavia Mk1 1.9TDi Classic with + pack-Diamond Silver Sadly missed: 97 Nissan Primera 2.0TDi SLX- Red Paul ![]() I only live for GTA IV |
| Briskodian | Re: Advice on a fault please. Thanks Taxi I did try that first but didn't get any relevant results, but I will try again. |
| Briskodian | Re: Advice on a fault please. Problem solved without having to replace the Flap Assy. I learnt that Fuse 8 under the bonnet usually blows when there are problems with the flap. So as I had already cleaned the flap assy I thought I may as well change the fuse and try it. Fortunately it worked and has remained working after a few stop starts, Although I think I will keep a supply of 10A fuses to hand just in case, cheaper than a new assy. |
| Re: Advice on a fault please. HI just out of interest where is this assembly located and how do you clean it? Piccies would be good too.
| Re: Advice on a fault please. Odd i've only heard of that on the 2.0. If the fuse blows the t/b is jammed and will need to be replaced at some point. |
| Briskodian | Re: Advice on a fault please. As reqested Taxi here are some pics. The first shows the location of the Intake flap with an orange ring round it. The second shows inside the flap assembly. Sorry about the poor quality pic but did not want to remove from the car again. The assembly is held on with 3 allen headed screws I have marked 2 but the 3rd is not visible/ hard to access. It is on the left hand side opposite the the other one.After removing I just gave it a good clean inside here with carb cleaner, especially around where the flap pivots. The last photo shows the location of fuse 8 in the fuse box. Hope this helps others, mine is still ok after a couple of days use. Apologies if the photos have not worked out very well this is the first time I have posted pics. |
| The Following User Says Thank You to d0ss For This Useful Post: | Lummox (11-05-2008) |
| Re: Advice on a fault please. They are just fine. Thanks for the effort. |
| Rear Discs worn due to fault,advice required! | rodpix | Fabia I | 3 | 06-05-2008 20:05 |
| Power steering fault - fault code 01288 - is this the normal plastic sensor fault? | mgskoda | Diagnostics & VAG-COM | 6 | 05-11-2007 19:31 |
| fault help and advice | pphilos | Octavia I | 11 | 15-10-2007 16:25 |
| Fault codes - advice | jase555 | Octavia I | 3 | 10-08-2007 13:56 |
| Advice needed - ECU fault code P0172 | nottmvrs | Octavia I | 1 | 25-01-2006 23:26 |
