39,455 Members 1,489,909 Posts
Aero Wipers Rubber only - Here's part Nş
This is a discussion on Aero Wipers Rubber only - Here's part Nş within the Octavia II forums, part of the Skoda Model Discussion Area category; I've discovered part number to change the rubber only on my Aero wipers. Went to dealer and price left me ...
Old 21-11-2007, 20:47   #1
bosnjo's Avatar
I've discovered part number to change the rubber only on my Aero wipers. Went to dealer and price left me suprised: 10€ for a pair + VAT ( it would be like 6£ + VAT for a pair). The part number is:
1KO 955 429
Now I'm trying to trace the part number for wiper rubber (Aero as well) for the tail wiper. Does anybody have it?
When I went to dealer and asked for rubbers only they said they don't have such a thing, only complete wipers. Then I asked to check by a part number, and voila, there it was.
Hope this helps others. It was 1 min to change each. They come a bit longer and with new caps. Very cheap.
Octavia 2006 2.0 TDI Sport (equal to L&K in UK)
- 17' wheels, Sport suspension, Xenons, Audience with Sound System, Bluetooth, Front & Back Parking Sensors -
- VAG COM -
bosnjo is offline
The Following 2 Users Say Thank You to bosnjo For This Useful Post:
dstev2000 (21-11-2007), radders (31-10-2008)
Old 21-11-2007, 21:09   #2
dstev2000's Avatar
Re: Aero Wipers Rubber only - Here's part Nş
As long as the UK dealers have the parts then thats a result.
Nice find pal.
MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely!
SWMBO's: MY08
vRS TDI - Standard
dstev2000 is offline
Old 21-11-2007, 21:12   #3
RADIOTWO's Avatar
Members Car: Fabia
1KO 955 429
Hope this helps others. It was 1 min to chenge eacs,. The come a bit longer and with new caps. Very cheap.
Hi Bosnjo
I wonder if you could tell me what length they are ? as might be usefull for another car
Radiotwo
RADIOTWO is offline
Old 22-11-2007, 10:15   #4
bahnstormer vrs's Avatar
Good piece of info as a set of new wipers is about £25!
Mine - '07 Octavia vRS TDI, Superchips BlueFin (210bhp/293lbft) 'Winter wheels' 7.5J x 17" Audi S-line, Ultrac Sessantas 225/45 17, xenons, rear parking sensor, heated seats (driver's Recaro Style full leather), climate/jumbo etc., Koni FSDs, Neuspeed Rear ARB & Short-Shifter, K&N induction kit, RallyFlapZ - Colin McRae memorial decals.
Wife's - '08 Roomster Scout 1.6 Tiptronic, Cruise, parking sensors
Son's - '02 Fabia 1.4mpi, vRS 16" alloys, Michelin Pilot Exalto 2 195/45 16, vRS front bumper, Koni Sport shocks.
bahnstormer vrs is offline
Old 22-11-2007, 11:20   #5
bosnjo's Avatar
Originally Posted by RADIOTWO View Post
Hi Bosnjo
Radiotwo
They are 65 cm (would be 26" I guess).
As long as I understood, they are good for all VAG range (stamp on the tag has VW, Seat, Skoda and Audi mark), plus Ford and Opel. Maybe some other too.
- VAG COM -
bosnjo is offline
Old 22-11-2007, 11:27   #6
bosnjo's Avatar
I'm just not sure if it's:
1KO 955 429
or
1K0 955 429
I mean if in the third position is digit zero or letter "O", but looking at the tag I guess it's digit zero.
- VAG COM -
bosnjo is offline
Old 22-11-2007, 11:35   #7
bosnjo's Avatar
Just found this:
- 1K0 955 429 - RHD 650mm
- 1K0 955 429 A - RHD 700mm
- 1K0 955 429 B - LHD 650mm
- 1K0 955 429 C - LHD 700mm
- VAG COM -
bosnjo is offline
Old 22-11-2007, 14:56   #8
cheezemonkhai's Avatar
Members Car:
Dealer says 1k0955429 and 1k0955429B don't exist, but A/C do.
I've ordered a pair of the A parts so hopefully they will cut down to size as they are non returnable due to being a special order.
cheezemonkhai is offline
Old 22-11-2007, 17:33   #9
Will A and C be right for a RHD pair. Do you need one of each length or can you cut one to do the shorter blade?
ednmra is offline
Old 22-11-2007, 18:05   #10
bosnjo's Avatar
Well, the only difference between LHD and RHD is the shape of the cap. To take off the old rubber you have to take off the cap first. Then just pull off the rubber. Put the old rubber by the new one and cut it the same size. Rubber has no metal rails like standard wipers do. So, just cut it with scisors or knife.
Now the difference between the caps is like this. Look carefuly to caps on each side of your aero wiper and you'll see they have little wing, but the wing is not in the middle. That's the difference. To change the rubber you have to take off the cap on the top and not on the bottom, as the bottom one is not supposed to get off.
When I got my rubbers they were for RHD and my car is LHD. Rubbers come with two caps each, but both caps are the same and both for the top of the wiper. You get those caps because when you take off old ones they usualy break inside so don't fit back. As my new ones were for RHD I took old ones off carefuly and they didn't break. At the time I've ordered mine I didn't know about A, B, and C, so they sold me RHD. I put the old caps back and everything is OK.
One more thing:
After yoy take the cap off, you'll see one metal pin stucked into rubber. Just put the screwdriver below it and pull it out of the old rubber, but only 1-2mm. When you put the new rubber in, press the pin back in. It servers for rubber not to move.
Here is the link how to do it. It's in spanish but photos are more then enough:
http://www.vagclub.net/tec/escobillasat.pdf
- VAG COM -
bosnjo is offline
Old 22-11-2007, 18:11   #11
Members Car:
Well since i have my old wiper blades in the boot and a pair of these on order when they turn up I'll do a quick how to on them with part numbers etc
Old 22-11-2007, 18:48   #12
So, in theory if, like me, you got new wipers a while back and have the old ones lying around, you could get new rubbers and caps, fit them to the old "complete" aeros at leisure, and then just swap them onto the car when appropriate. Then keep the ones you just took off and some time later fit new rubbers to them, and so on till you get rid of the car!
ednmra is offline
Old 22-11-2007, 19:01   #13
bosnjo's Avatar
Yes, that's the idea.
This is my first car with Aero Wipers. On my previous cars I was always changing the rubbers only like 3-4 times and then had to change the whole wiper because to change the rubber in standard wiper you have to bend the metal parts so wiper wouldn't accept it many times. Now, with Aero Wipers seems to me that you can change the rubber as many times as you want untill you change the caps too.
By the way, you don't have to have the spare pair to change the rubber. I didn't have the spares. Just took them off, brought them into the house, changed the rubber and put them back. Whole operation - 15 minutes.
- VAG COM -
bosnjo is offline
Old 22-11-2007, 23:09   #14
rvacaru's Avatar
For the back wiper the part number for the blade is 7E0 955 425 and costs around 8 euro
nov 2005 Silver Skoda Octavia 2 Elegance 1.6 FSI
nov 2001 Green Skoda Fabia Comfort 1.4 16V
Pics: http://myfabia.de
rvacaru is offline
The Following 2 Users Say Thank You to rvacaru For This Useful Post:
bosnjo (22-11-2007), frogeye (26-11-2008)
Old 22-11-2007, 23:59   #15
bosnjo's Avatar
Thanks, do you know if it comes with caps like the front one does?
- VAG COM -
bosnjo is offline
Old 23-11-2007, 09:00   #16
rvacaru's Avatar
I have no idea
rvacaru is offline
Old 23-11-2007, 10:05   #17
What is involved in removing the caps? Do they just clip on and pull off?
ednmra is offline
Old 23-11-2007, 11:49   #18
bosnjo's Avatar
Yes, I pulled them off with screwdriver, but not putting the screwdriver under them, fearing to break them (as I didn't have LHD spare ones I needed). If you have new caps, just pull old ones off, the way you want. You dont need to care if they break.
- VAG COM -
bosnjo is offline
Old 23-11-2007, 18:29   #19
Members Car:
Good information!
I need to buy some new fronts myself as the current ones leaves streaks due to damage from parking under some trees at work this summer that left blobs of hard resin on the car.
richardjh is offline
Old 14-04-2008, 16:21   #20
radders's Avatar
Members Car: Octavia 2.0 TDi
Did anyone try this with a RHD car?
Are the part numbers correct? How much were they from the dealer?
More importantly, is it easy? Did you break the caps?
Sorry for all the questions, but I am going to have to replace my wipers shortly and this seems a good way of doing it.
Mark
radders is offline
Old 14-04-2008, 16:27   #21
Members Car:
Tried it and still have them in the boot waiting for the new ones to expire.
Only some of those part numbers are correct, but you basically need the part number for the seat wiper refills for the altea.
Old 14-04-2008, 20:29   #22
bosnjo's Avatar
Mark
RHD is on post Nş7 and price on post Nş1. The rest is all in other posts of this thread, just read them carfully
- VAG COM -
bosnjo is offline
Old 15-04-2008, 11:04   #23
Members Car:
Nope the dealer looked at this page and tried all combos and some just don't exist on the skoda/seat database they said.
Old 15-04-2008, 13:04   #24
wonderbadger's Avatar
Members Car:
I contacted my local Skoda dealer in York to order the replacement blades and he couldn't find the part numbers supplied. He did a bit more digging on another system and found the parts and they were listed as "brand restricted" so as a Skoda dealer he was unable to order them.
The VW garage 2 minutes down the road got them in next day for me though... don't you just love internal VAG politics!
wonderbadger is offline
Old 15-04-2008, 14:53   #25
flynntech's Avatar
Members Car:
I bought my wiper refills at the VW dealer...as well as my oil filters, air filters
VAGdrivers.net - Ireland's online VAG community
flynntech is offline
