39,456 Members 1,489,918 Posts
Air Con Ambiente
This is a discussion on Air Con Ambiente within the Octavia II forums, part of the Skoda Model Discussion Area category; My brother in law has just purchased a 1 year old 1.9 TDI ambiente and was concerned that the air ...
Old 05-05-2007, 20:57   #1
NascarMike's Avatar
Air Con Ambiente
My brother in law has just purchased a 1 year old 1.9 TDI ambiente and was concerned that the air conditioning was not working correctly.
We started the car up, turned the temperature control to 18 degrees, switched on the air con button, and waited.
The air coming through the vents did not appear to be getting cooler at all.
Went back to my 1.9TDI 2001 Elegance, started my car up, set the air con temperature to 18 degrees & within a minute cold air was emitting from the air vents.
I can't believe that a 1 year old car needs a re-gas already.
Anyone with any ideas or am I missing something.
By the way, it was me that convinced him to get an Octavia & trade in his Ford Focus.
NascarMike is offline
Old 05-05-2007, 21:04   #2
runboy's Avatar
Members Car: Octy II L&K 2.0TDI DSG
Re: Air Con Ambiente
If the aircon had not been used for a year I suppose it could have leaked if the seals had perished, but a year sounds a bit too soon....
Presume the aircon gubbings look in order-I have heard of stones bouncing up and damaging the aircon system on other makes of cars.
2007 Octavia Hatchback, 2.0TDI DSG L&K in Black Magic.
runboy is offline
Old 05-05-2007, 21:05   #3
Cupra Bush King
Lummox's Avatar
Images: 2
Sounds like there is a fault, might be a faulty flap motor.
Or it could be out of gas if it has a hole in the condensor.
It wont be seals perishing as the A/C is always running and circulating the gas and oil in the system.
www.unit18.co.uk
Lummox is offline
Old 05-05-2007, 21:14   #4
dstev2000's Avatar
The condenser may have copped an unfortunate one, check for stone damage on the front of the coil, IIRC it's at the front of the condenser/intercooler/radiotor sandwich.
The air con is one of the first things to be checked when giving a potential purchase the once over or it could be expensive. It's regularly overlooked.
As the car is only 1 year old it could be a warranty issue or you could take it up with the seller of the car
MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely!
SWMBO's: MY08
vRS TDI - Standard
dstev2000 is offline
Old 05-05-2007, 21:29   #5
runboy's Avatar
Interesting - I thought if the ECON light was on, there was no "aircon" as such, just a normal heating system as you find in a 10 year old car with no aircon? With the ECON light out the aircon is running? Only just got my Octy so I'm still learning!
runboy is offline
Old 05-05-2007, 21:49   #6
dstev2000's Avatar
It doesnt run at full capacity all the time, when the ECON is on the compressor runs at a very small percentage of it's normal capacity. It's not enough for you to know it's still running.
SWMBO's: MY08
vRS TDI - Standard
Old 05-05-2007, 21:50   #7
Briskodaholic
Tom_vRS's Avatar
Members Car: '97R BMW 328i Saloon
As Lummox says, in all newer VAG motors, the a/c is always on at about 2% load to keep all the seals and condensor moist and lubricated
97/R BMW 328i in Boston Green.
Tom_vRS is offline
Old 05-05-2007, 21:57   #8
Steve R's Avatar
Members Car:
I've had a problem with my aircon on my Vrs at 12months old. changed the control unit first but turns out it is a faulty flap motor. Apparently this is not uncommon!
Just because you are paranoid it doesn't mean they're not after you!
Steve R is offline
Old 05-05-2007, 22:12   #9
Cupra Bush King
Lummox's Avatar
Images: 2
It isnt. If a flap motor goes down it usually knocks out the 5v feed to the other flap motors from the contol unit. And the only way to find out which one is to disconnect each one in turn and wait for them to come back online,
Which is all well and good but to get onto one of the flaps the dash has to come out.
www.unit18.co.uk
Lummox is offline
Old 07-05-2007, 01:30   #10
runboy's Avatar
Cool, they think of everything these days!
runboy is offline
