39,456 Members 1,489,919 Posts
air con octy 11
This is a discussion on air con octy 11 within the Octavia II forums, part of the Skoda Model Discussion Area category; since i bought my octavia 2.0tdi the heater works ok when on hot but when you turn it to cold ...
Old 18-08-2008, 16:18   #1
Members Car:
air con octy 11
since i bought my octavia 2.0tdi the heater works ok when on hot but when you turn it to cold it still fells luke warm any ideas wat it could be , ive the car 8mths and it has never worked has always feltluke warm
skoda300 is offline
Old 18-08-2008, 17:31   #2
Not anymore
Taxi 219's Avatar
Members Car: Octavia TDi 2006
Re: air con octy 11
I have found this too in the recent or should i say past hot temperatures but obviously turning the AC on certainly cools things right down.The normal air is coming from outside so will not feel cold like Air Con.
Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged-Metallic Flamenco Red DMF Reqiured soon
Previous: 06 Octavia Mk1 1.9TDi Classic with + pack-Diamond Silver
Sadly missed: 97 Nissan Primera 2.0TDi SLX- Red
Paul
I only live for GTA IV
Taxi 219 is offline
Old 18-08-2008, 19:20   #3
Members Car:
Re: air con octy 11
when i turn air con on cold its not very cool as i said it just cums out as luke warm air???
skoda300 is offline
Old 19-08-2008, 02:48   #4
Members Car: Octavia vRS TFSI
Re: air con octy 11
I made a similar post about this over the weekend.
I'm a new vRS owner and really enjoying the car.
I traded in my 2004 Peugeot 307 and I'm going to be honest - the AC was a lot better in the Peugeot.
If I set it to coldest setting (no temperatures, not that advanced) and then put the blower on say 2, AC on, within minutes it would be icy cold in my car.
To the point where I would have to switch the AC off and just have "regular cooling".
Did the same on my vRS, set it to the blue square (not the lowest temeprature of 18oC), pressed AC on, turned the blower to 2 (and then 3) and the air temperature was just so warm compared to my old Peugeot.
On the drive home I actually had a small sweat on my brow I couldn't shift.
I'm speaking to the dealer at the moment as I want them to check it out for me.
It could be that the AC just is nowhere near as good as the Peugeot's - it just surprises me if that is the case.
Stoofa is offline
Old 19-08-2008, 07:18   #5
Cupra Bush King
Lummox's Avatar
Images: 2
Re: air con octy 11
Sounds like either you have an a/c fault or a temp flap motor issue.
www.unit18.co.uk
Lummox is offline
Old 21-08-2008, 23:36   #6
Timo's Avatar
Members Car: Octy VRS Tdi
Re: air con octy 11
I had to take mine in after 8k, needed regassing for some reason, think might have to take back to get checked for leaks. Regas worked though. Got mine done on warranty.
Timo is offline
Old 22-08-2008, 01:34   #7
Re: air con octy 11
I spoke to the dealer where I got mine from and was told that from the sound of things there was a problem.
It's obviously difficult to describe "not cold enough" over the phone
I'm going back a week on Saturday and they are going to run some tests and see if any work needs doing.
Scary if AC units need work after only 15k miles.
My old Pug 307 that I just traded in had 62k miles and had only one re-gass at around 30k and was still ice cold when AC was switched on.
Stoofa is offline
Similar Threads
Octy RS Air Con Electronics dswhite Diagnostics & VAG-COM 25 20-04-2008 14:16
Still no air con Maymun Fabia I 9 10-04-2008 22:44
Air Con, yes or no? colkai Fabia I 32 21-08-2006 18:40
Octy 2 Dual Zone Air Con option... MrkyMrk General Car Chat 8 11-06-2006 22:55
air con bengie Maintenance & Performance 7 10-02-2005 00:12
