Discussing air filter? within the Octavia II forums, part of the Skoda Model Discussion Area category; is there any advantage to putting in an air filter from k+n or pipercross? is it easy to do and ...
| Login | ||||||
46,769 Members 7 Posts | Register | FAQ | Members List | Calendar | Mark Forums Read |
| Notices |
Register to reduce ads, enable search and join our community.
| | LinkBack | Thread Tools | Display Modes |
| Briskodian | air filter? is there any advantage to putting in an air filter from k+n or pipercross? is it easy to do and will it improve the sound of the car. mines an octavia vrs tdi. thanks for the help |
| Briskodian Join Date: Oct 2003 Location: South East England
Members Car: White Octavia vRS Thanks: 11
| Re: air filter? I'll let you know. I've got a K&N on order for my TDI vRS.
__________________ Phil Then: Red Fabia vRS: Not quite standard .Now: White Octavia vRS: Eibachs/FSDs - WALK - Neuspeed shifter (thanx Stu!) - K&N - Angel re-map - Milotec B pillars - Lumin-X front fogs - Climatronic 'OFF' mod. |
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
Members Car: Octavia Mk2 FSI Sport Thanks: 53
| Re: air filter? i have a green filter on, you can here a slightly louder sound of the air being sucked in but thats about it. |
| Briskodian Join Date: Dec 2008 Location: Devon
Members Car: Octavia II TDi Estate 140 Thanks: 6
| Re: air filter? I've got the pipercross on order for my 2.0 TDi. Will let you know if you want if there is any difference. It did make a slight performance increase on the ST170. Only about 1-2 BHP in real terms I expect. I'm not sure it makes a difference on dervs since they are always taking in a full lung full of air no matter if idling or full throttle aint they? I mate tried a K&N in his focus TDCi and said there was slight improvement to the smoothness of the drive and a slightly better pull. Could be placebo ![]() |
| Briskodian | Re: air filter? @ rsbspt - cheers lad let me know how it goes @smstext - was it hard to fit? |
| | #6 | |
| Briskodian | Re: air filter? Quote:
You will be very happy with the result thats for sure. Panel filter will let the car breath better but dont expect any sound improvements it will be the same. (I also tried K&N panel filter) | |
| Re: air filter? On mine it wasnt, undone the four screws holding the air housing together, then the screw holding OEM filter in, took OEM out, put green filter in and screwed in making sure no wholes and fitted securely, then put lid back on air cover and did the screws back up. |
| Bookmarks |
| Air filter help | starch | Maintenance & Performance | 2 | 10-02-2008 14:22 |
| New air filter | th4neuk | Octavia I | 3 | 05-10-2007 22:00 |
| Where's the Air Filter? | Makefish | Octavia II | 3 | 13-03-2006 13:46 |
| Air filter | p1tud | General Car Chat | 11 | 12-06-2005 18:10 |
BRISKODA.net is operated by Summit 360 Ltd. Site Design and vBulletin Theme by Alex Pinner (apinner)
Problem viewing this site? Upgrade to the latest version of your web browser of choice:
Opera | Firefox | Safari | Internet Explorer
