This is a discussion on Aircon service on 1.9TDI within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi there, Does anybody know how often the air conditioning should be serviced on a 1.9 TDI ? [ 06 ...
| Briskodian Join Date: Jul 2008 Location: Dublin
| Hi there, Does anybody know how often the air conditioning should be serviced on a 1.9 TDI ? [ 06 model / 55000 km / service every 15k ] Thanks vic |
| Briskodian Join Date: Nov 2007
| Never. Unless the condenser (the air-con rad) gets dirty with road debris (leaves, etc) you will never need a routine service on the air-con. It's a refrigeration system and they are sealed. The gas in it is a refrigerant which is circulated, not consumed. So, unless it's not working properly, then you don't need to do anything to it. Oh, and I'm a refrigeration engineer by trade so I do know a bit about air-con. ![]() |
| | #3 | |
| Quote:
i was wondering as my previous car [ a Peugeot 306 :-( ] had to have the pollen filter replaced/cleaned every x kms | |
| We advise every two years. The gas graduallly leaks through rubber hoses etc on a car is its a harsher enviroment than your average kitchen where your fridge lives. Also gives a good chance to de odourise the system as bacteria builds up on the evaporator inside the car, most dealers/garages that do ac servicing will offer a sonic cleaning of some sort. The pollen filter should be changed every 40k.
__________________ Unit 18 Automotive Services |
| The Following User Says Thank You to Lummox For This Useful Post: | vico1612 (24-07-2008)
