39,456 Members 1,489,912 Posts
Alarm query?
This is a discussion on Alarm query? within the Octavia II forums, part of the Skoda Model Discussion Area category; Went to get a takeaway tonight on the way back from walking the dog. I took the keys out the ...
Old 05-10-2008, 19:12   #1
blackspaven's Avatar
Alarm query?
Went to get a takeaway tonight on the way back from walking the dog. I took the keys out the ignition to pop in and left the wife in it with the dog in the boot. Three times the alarm went off without me setting the alarm in the first place, but went off each time I 'disarmed' the car, if you see what I mean. Does anyone know why it's doing this and how I can stop it from doing it the future? The wife tried pressing the button on the B pillar just to see but it still went off.
Any ideas??
blackspaven is offline
Old 06-10-2008, 09:50   #2
Members Car: O2
Re: Alarm query?
Doesn't the care lock itself when you take the keys out and don't do anything for a certain time?
If this is the case, I guess the alarm goes on automatically when the doors are locked.
If you push the button on the B-pillar before closing the car it shuts off the interior alarm, but I don't know what happens if it closes automatically.
bogey555 is offline
Old 06-10-2008, 10:01   #3
Birdwell L&K's Avatar
Members Car: 06 Octavia L&K 140DSG
Re: Alarm query?
Try when you lock the car to press the locking button on key fob twice, this deactivates the dead locks and alarm. Hope this helps
Birdwell L&K is offline
Old 06-10-2008, 18:58   #4
GAFF's Avatar
Members Car: Octavia II vRS
Re: Alarm query?
Stupid question but did you accidentally arm the car (i.e do it out of habit), then unarm it when you remembered people in car .....but didn't open door. If so it will reset alarm.
GAFF is offline
Old 06-10-2008, 20:25   #5
Members Car:
Re: Alarm query?
Just pressing unlock without the car being locked will do the same (doors lock in 30 sec) if no door is opened in the mean time.
Milk Inc's newest #1 fan
sebulbus is offline
Old 07-10-2008, 23:43   #6
Re: Alarm query?
Okay, so let me get a definitive answer here...
I turned the engine off, took the keys out and walked into the shop. Without doing anything with the keyfob, the alarm went off after a very short while and thereafter twice more. Nothing more than that
a) what is the car doing
b) how do I stop it doing it again?
Old 08-10-2008, 04:57   #7
Members Car:
Re: Alarm query?
Two possibilities I can think of:
1 You pressed the lock button on your remote without realizing it. Do you have any other keys or anything else hard in your pocket (steady down you dirty mined sods !) that could accidentally press the button.
2 Your cars electrics have a fault which needs fixing.
My money is on #1 as the most likely, as I've locked and unlocked mine several times, especially if I bend over with other stuff in the same pocket as the remote.
Sprint Yellow 2008 Octavia II RS Wagon 2.0TFSI manual (Xenons)
White 2006 VW Transporter LWB van 2.5 TDI manual (camper)
gregozedobe is offline
Old 08-10-2008, 08:51   #8
Re: Alarm query?
If I did do it accidentally, then unlocked, what happens with the alarm then? That's why I asked the questions in the previous post. Hopefully someone can give it a definitive answer to them.
Old 08-10-2008, 10:09   #9
Members Car:
Re: Alarm query?
My alarm regularly goes off if I lock the car very quickly after closing the doors. I just unlock and relock and all is well.
I suspect that there is enough air turbulence caused by closing the door to set the alarm off.
fredw is offline
Old 08-10-2008, 10:13   #10
pdhealy's Avatar
Members Car: Skoda Octavia vRS
Re: Alarm query?
IIRC, if you locked it accidentally, then unlocked it, and you didn't open a door within 30 seconds of unlocking, the car will relock itself and rearm the alarm system. Movement inside the car will then set off the alarm.
The car "thinks" that when you unlocked it, because you didn't open a door, that you did so unwittingly.
Dear Lord.. The gods have been good to me. For the first time in my life,
everything is absolutely perfect just the way it is. So here's the deal: You
freeze everything the way it is, and I won't ask for anything more. If that
is OK, please give me absolutely no sign. OK, deal.
pdhealy is offline
Old 11-11-2008, 02:17   #11
Members Car: superb
Re: Alarm query?
You failed to say if your car has been involved in any sort of shunt by what you describe I can only assume it has or has had some sort of bodywork modification the alarm wiring runs close to the surface both front and rear to allow for an upgrade to the LS42I alarm system.
It sounds like the wiring has been pinched between the body panels this would more apparent in damp conditions when the voltage drop is greater
doctoroctavia is offline
Similar Threads
Query... Wardy JabbaSport 3 27-08-2008 20:02
Hello and a query banjoman INTRODUCE YOURSELF! First time visitors, say hello here. 0 20-01-2007 12:21
query Daddy2Coull Diagnostics & VAG-COM 9 30-10-2005 21:13
