This is a discussion on Aux input---help please !! within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi All, please talk me through running an Ipod through the Aux input, Aux is selected ON at the head ...
| Briskodian Join Date: Nov 2004 Location: nr Reading,Berks
Members Car: Fabia Vrs & Riley Elf (1968) Thanks: 2
| Aux input---help please !! Hi All, please talk me through running an Ipod through the Aux input, Aux is selected ON at the head unit, items all connected up----and nothing!!! Is there something totally obvious that I have missed ? Thanks in anticipation ![]()
__________________ Octy Vrs Tdi Estate & Fabia Vrs,silver and standard |
| Briskodian | Re: Aux input---help please !! Try pushing the CD button on your radio three times if you have a 6disk add on or two times if not |
| Briskodian Join Date: Nov 2004 Location: Cork City, Ireland
Members Car: Octavia L&K 1.8 FSI Thanks: 23
| Re: Aux input---help please !! The volume is turned up on the output of the i-Pod? Other that that all sounds like it should work fine |
| Re: Aux input---help please !! Try another device on the 3.5mm jack, if that works then the problem is the ipod.
| Briskodian | Re: Aux input---help please !! How is your ipod connected to the 3.5mm jack? Do you have it plugged into the headphone socket on ipod or via the docking connector at the base? |
| | #6 | |
| Briskodian Join Date: Apr 2007 Location: Finland
Members Car: Skoda OCtavia II Combi Elegance 1.6FSI Thanks: 22
| Re: Aux input---help please !! Quote:
There's been a little mixup just before the model year changed to 2007. 2006 cars might have aux input option but it doesn't actually work. The radio doesn't support aux even it is possible to enable it from Stream. There's been some discussions here about that problem.
__________________ '05 OctaviaII 1.6FSI Combi Elegance : Xenons, Aftermarket H1 HID kit on main beams, Rain sensor, Autodimming rearview mirror, Light assist, Dual-Zone Climatronic, MFD2, Kufatec Digital music interface (USB, SD), MaxiDot (Retrofitted, parts from VrStu), Multi-function steering wheel (Retrofitted, parts from VrStu), Rear Parking Sensors. | |
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
Members Car: Octavia Mk2 FSI Sport Thanks: 11
| Re: Aux input---help please !! if another device doesnt work then follow the wire to the back of the radio and make sure it hasnt popped out or snapped. |
| Re: Aux input---help please !! Thank All,its a 56 plate, once the rain stops I will have another go !!! Regards,Mac
| Briskodian | Re: Aux input---help please !! Hi mac, I hope you don't have to go through the hassle I had with this, but for reference, here's my story!: http://briskoda.net/octavia-ii/when-...am-come/88626/ Note, do you have a CD changer and does it work ok? This was the other symptom I had as well as the aux socket not working |
| | #10 |
| Proud new Dad Join Date: Feb 2007 Location: Carlisle, Cumbria
Members Car: Octavia vRS TDi Thanks: 165
| Re: Aux input---help please !! There is a setting on the HU as well to set the volume level, set this to the higher setting. Also if the 3.5mm jack is plugged in to the headphone socket on your i pod then you'll have to turn the volume on the ipod up high, and maybe the HU volume up a little to hear anything. Getting one of these Ipod Base To 3.5-Mm Jack Lead will mean you don't have to alter the volume on the ipod to hear it, and will give a better quality of sound. Otherwise Belkin do a version of the above but which also chages the ipod as well. It's what I use. Can't find a link to it at the moment.
__________________ Running on the fuel of Satan.... |
| | #11 |
| Briskodian Join Date: May 2008
Members Car: Octavia Estate 1.9TDI Elegence Thanks: 5
| Re: Aux input---help please !! To summarise Guiness' thread: The Stream MP3 was included only after the start of the MY2007 build. Early builds were done with the Stream even though the loom was built for the Stream MP3. Guiness got his swapped by the dealer, but SUK were refusing to do it. The Stream was theoretically capable of using an Aux input, but actually was not. The change in wiring makes the CD changer sound awful if the Stream MP3 loom is used with the Stream. There is an easy diagnosis of which HU you have: there is text on the upper right of the HU, just above the CD slot, which should read "Stream MP3". Last edited by rurwin; 10-09-2008 at 08:45. |
| | #12 |
| Briskodian Join Date: Oct 2007 Location: Islington
Members Car: Skoda MK2 1.9 TDI PD + Merc E 280 CDi Thanks: 0
| Re: Aux input---help please !! please check the CABLE you are using... IPODS sometimes don't accept cheap cables. I faced this problem with my mk2 and an ipod touch. got me a monster cable jack.. plays like a dream now. |
| Aux in on old Stream using CD changer input? | wonderbadger | ICE, Security and Insurance | 3 | 21-05-2008 17:47 |
| where is located aux input jack | mayatitan | Octavia II | 10 | 05-01-2007 05:35 |
| Stream MP3 / Aux input | yashicamat | Octavia II | 15 | 23-09-2006 00:39 |
| Aux input on Alpine HU | JUT | ICE, Security and Insurance | 10 | 20-09-2005 16:39 |
| aux input converter | madfiddler | ICE, Security and Insurance | 2 | 30-08-2005 16:30 |
