This is a discussion on Bulkhead Cabling within the Octavia II forums, part of the Skoda Model Discussion Area category; Need to run a small cable from the engine bay into the car and wanted to know of the best/easiest ...
| Ex-Moddy Join Date: Jul 2005 Location: Hampshire
| Need to run a small cable from the engine bay into the car and wanted to know of the best/easiest route to go through the bulkhead. If anyone has done something similar or has got any ideas please let me know
__________________ Black magic Octy II vRS MY2008 with Maxidot ~ Xenons ~ Cruise ~ Light Assist ~ Dual Zone Climate Control ~ Rain Sensing Wipers ~ MFD2 Satellite Navigation ~ VAG Bluetooth Phone Kit ~ Milltek Exhaust with 2.75" Downpipe ~ EVOM Ram Air Intake ~ Nuespeed Shortshifter ~ Eibach Rear ARB ~ Koni FSD Dampers ~ Eibach Springs ~ Forge Front Mounted Twintercooler ~ Nuespeed Hi-Flo Intercooler Pipe ~ Nuespeed Hi-Flo Turbo Outlet Pipe ~ Eurojet PCV Valve ~ Forge DV ~Autotech Hi Volume Fuel Pump ~ Nuespeed Torque Arm Insert ~ NGK Iridium Spark plugs ~ REVO Stage II+ Software ~ Matt Black Viper Stripes! |
| the mk5 golf has a small rubber bung down behind the back of the engine which leads through to the area behind the glovebox, but it is under the carpet! i'm asuming it's the same as the octyII?????
__________________ vorsprung durch czechnik |
| Keep on going Join Date: Nov 2003 Location: West Midlands
| This may help - http://www.briskoda.net/forums/ice-s...10/#post756876 |
