This is a discussion on Can I manually adjust the camber of the rear wheels to avoid excess tyre wear? within the Octavia II forums, part of the Skoda Model Discussion Area category; Can I Manually Adjust The Chamber Of The Rear Wheels To Avoided Excess Tyre Ware...
| Briskodian Join Date: Feb 2008
| Can I manually adjust the camber of the rear wheels to avoid excess tyre wear? Can I Manually Adjust The Chamber Of The Rear Wheels To Avoided Excess Tyre Ware |
| Re: Can I Manually Adjust The Chamber Of The Rear Wheels To Avoided Excess Tyre Ware your not supposed to be able to because the stub axles are fixed.... but a trick i learned rallying was to unbolt the stub axles and stick shims under one side to increase the camber.... i dont recommend it tho on a road car.. leave it well alone |
| Briskodian Join Date: Apr 2007 Location: Warminster
| Re: Can I Manually Adjust The Chamber Of The Rear Wheels To Avoided Excess Tyre Ware |
| Re: Can I Manually Adjust The Chamber Of The Rear Wheels To Avoided Excess Tyre Ware Basil had a succesful go at it here: http://briskoda.net/forums/technical...ar-axle/98991/
__________________ ![]() |
| Violated Join Date: Feb 2006 Location: North East Hants
| Re: Can I Manually Adjust The Chamber Of The Rear Wheels To Avoided Excess Tyre Ware Micheldever tyres adjusted mine ok. ![]() There are revised figures from Skoda regarding tyre wear. 1.25 degrees as opposed to 1.45 degrees. |
| Tyre wear on the inside edge! all 4 wheels! | charles | Octavia II | 11 | 16-01-2008 15:13 |
| Tyre wear on both NS wheels | Aaquil | Octavia I | 15 | 01-02-2007 02:33 |
| Uneven tyre wear - huge ammount of camber | Goochie | Octavia I | 2 | 30-10-2006 11:13 |
| Excess negative camber? | sjfw | Fabia I | 0 | 10-10-2006 16:00 |
| Can you adjust the camber and toe-in on the RS? | TurboČ | Maintenance & Performance | 8 | 22-07-2003 06:17 |
