Changing rear Pads
This is a discussion on Changing rear Pads within the Octavia II forums, part of the Skoda Model Discussion Area category; Apart from the pads themselves and a wind back tool, is anything else needed to do the rear pads on ...
Old 15-07-2008, 15:57   #1
cheezemonkhai's Avatar
Default Changing rear Pads
Apart from the pads themselves and a wind back tool, is anything else needed to do the rear pads on an Octy II?
Looking at about £20 for a set of rear pads so it will save £80 worth of labour.
Do the discs usually last a couple of sets of pads or are they usually worn after one set and also where is the best point to jack the rear of the car with a trolly jack and to put the axle stands.
Thanks in advance.
cheezemonkhai is offline
Old 15-07-2008, 16:19   #2
Default Re: Changing rear Pads
The pads are the only things in need of replacing on the standard Octavia. You can hack it from behind, lifting from the suspension arms, if you have a long jack, or just in front of the real wheels with a standard one.
Milk Inc's newest #1 fan
sebulbus is offline
Old 15-07-2008, 16:26   #3
So no springs/screws etc?
Just wondering if they are held in by screw or spring clip and the size of any tools I'll need.
Old 15-07-2008, 16:33   #4
It was a while since when I changed mine, but I think there are just two regular hex bolts to undo in order to remove the calliper and the spent pads.
I changed both the front and rear while I was at it, and I remember either or both of the pad sets came with new bolts and locking pins. And only basic tools were used.
sebulbus is offline
Old 15-07-2008, 16:38   #5
Excellent. Will have to have a look at a few things this evening.
Ta
Old 15-07-2008, 17:54   #6
Moderator
Bigw2069's Avatar
Copperslip for the back of the pads and a freedom membership
Bigw2069 is offline
Old 15-07-2008, 19:49   #7
Get out the way
Taxi 219's Avatar
Yes remember to copperslip them.Don,t want any squeelie pads after
Car now: 56 Octavia MK2 1.9TDi Ambiente
Previous: 06 Octavia Mk1 1.9TDi Classic with + pack
Sadly missed: 97 Nissan Primera 2.0TDi SLX
Taxi 219 is online now
Old 15-07-2008, 19:53   #8
Hairy Yeti
Lummox's Avatar
If you use standard pads that have the sticky back on them DONT copperslip them.
15mm and 13mm spanners are required to change the rear pads and a piston wind back tool.
Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote.
Lummox is online now
Old 15-07-2008, 20:09   #9
jamesmckelvie's Avatar
do you really need the piston wind back tool? a piece of wood acting as a lever would push the piston back in if need be.
1.9 TDI Elegance - Cappuccino Beige
Plenty enough power and torque for the economy offered
jamesmckelvie is online now
Old 15-07-2008, 20:12   #10
Hairy Yeti
Lummox's Avatar
It needs to be twisted as well as pushed back so yes.
Old 15-07-2008, 20:26   #11
Get out the way
Taxi 219's Avatar
Otherwise you fook it up.
Old 15-07-2008, 20:47   #12
DGW
BRISKODA Staff
DGW's Avatar
If you do that, you risk destroying the automatic adjuster in the brake caliper.
Denis
2007 Fabia vRS - CC, ESP, Jabba rear ARB, and full leather trim by Seat Surgeons ...48.01 mpg...
DGW is offline
Old 15-07-2008, 23:24   #13
I didn't see anybody do anything to the new pads, and for the first 1k miles after the pad change I was embarrassed by how loud it could squeal under light braking. It even scared people off pedestrian crossings.
Kinda like having a 3rd horn.
sebulbus is offline
Old 16-07-2008, 00:36   #14
Bully Bully :)
vRSLen's Avatar
Just remember that the handbrake may feel poor until the
pads are the same profile as the disc face
Current car: Black MKII Octavia vRS Combi
Previous: Black MKI Octavia vRS Combi
Black Fabia Elegance 100 BHP
vRSLen is offline
Old 16-07-2008, 08:09   #15
Hi, would this kit fit ?
https://www.portlandtools.co.uk/Auto...OOLS_1734.html
cj_uk is offline
Old 16-07-2008, 10:06   #16
Ah ah ah . . no
yashicamat's Avatar
Also it will take a lot longer to bed them in that the front pads as the rears are subject to a lot less wear.
Mark, don't copperslip the bolts holding the calliper on though. If anything, these should really have Loctite or similar on them. They are not bolts you want to be working loose over time.
Rob
Nissan Primera GT in Silver
'56 Octy 2 2.0TDi Elegance . . . also gone but not forgotten
2002 Fabia 1.9TDi . . . . gone but not forgotten
http://uk.youtube.com/yashicamatonline
yashicamat is offline
Old 16-07-2008, 10:33   #17
Thanks Guys, especially Ross for the spanner sizes
What has happened to the thanks button actually?
I have the winding tool and spanners and some threadlock so it doesn't sound like a hard one. The dealer has offered me an extremely good price on supply or supply & fit of pads so I'll be using the genuine pads
As for the freedom membership comment, if I had £12 spare I'd not even consider fitting myself as time and effort outweigh the small labour cost.
Is it worth putting a small amount of copper slip on the small parts of the pads where they locate on the slides or is this again not required on an Octy II.
I always used to rely on the shims on the rear and just put a small amount of slip on the slides after cleaning it all up on other cars.
Old 16-07-2008, 12:47   #18
Moderator
Bigw2069's Avatar
Dont take it personally Cheeze, I was just messin
Bigw2069 is offline
Old 16-07-2008, 13:14   #19
Can anyone point me in the right direction of where to buy a winding tool for the octy ii, many thanks.
cj_uk is offline
Old 16-07-2008, 14:03   #20
Halfords or GSF or most motor factors will sell them.
I once saw that the VAG tool was cheaper but no idea if this is true.
The usual brand is Laser and it's about £10-15
