Colour coding my Grille - DIY
This is a discussion on Colour coding my Grille - DIY within the Octavia II forums, part of the Skoda Model Discussion Area category; Well, i began today - Im doing it all DIY - see how it pans out before i resort to ...
Old 13-05-2008, 22:46   #1
Weak Effort.
djgritt's Avatar
Default Colour coding my Grille - DIY
Well, i began today - Im doing it all DIY - see how it pans out before i resort to a Pro... If i have to!
Removing and disassembling the Grille was extremely easy - thank to Stu's Octavia Site
Anyway, after some GREAT fun trying to get the Skoda badge off, i began sanding the Chrome - expecting it to be a bitch - it was.
After an hour, i had only managed the top of the grille - but noticed the plating had worn through along the edge after my efforts, managed to flake a part of the plating up - i just went to flatten it and it lifted, so i started to peel it off...
2 1/2 hours later, its NEARLY all off, gave up cos i was getting bored - still gotta finish, but it will be easier to prep, so should make it easier to do the paintwork though
How it stands now;
Hopefully finish the chrome peeling tomorrow night, and also the sanding down/flattening - if the weather holds out, it should all be done proper job by end of the Weekend
Detailing?! Feck that... Whatever happened to just driving a car?
Owner of the most reliable Octavia II on the forum
VxON South Central Regional Organiser
http://www.vauxhallownersnetwork.co.uk
Horse Livery & Grazing available in North Dorset;
http://www.freewebs.com/holebrookfarmlivery/index.htm
djgritt is offline
Old 14-05-2008, 01:13   #2
mrx
Default Re: Colour coding my Grille - DIY
I'll be doing this soon too - I've ordered a grill surround to butcher, just waiting for it to arrive.
I was thinking of using etching primer over the chrome instead of trying to sand it off - any thoughts on this? I don't think I have the patience to sand/peel it. I can always sand the whole lot off later if it starts to flake.
Is the badge just glued on?
mrx is offline
Old 14-05-2008, 07:08   #3
Jonno VRs's Avatar
You just need to key into the chrome instead of taking it totally off.
Unfortuneatly my spraying efforts were a bit carp so I think I will seeking the services of a professional.
06 Skoda Octavia VRs 200 bhp (Black)
Previous Cars:
04 Audi TT 3.2 V6 250 bhp (Black)
02 VW Golf V5 170 bhp (Black)
Jonno VRs is offline
Old 14-05-2008, 08:08   #4
Weak Effort.
djgritt's Avatar
Yes and No
It has 2 lugs which are melted to spread out over 2 holes in the surround, and it is also held on with the sticky foam you normally see on badges etc
djgritt is offline
Old 14-05-2008, 10:36   #5
sworrall's Avatar
looking good, are your fingers in bits now as I found that chrome quite sharp!
Skoda Octavia II 2.0 tdi L&K Estate
Xenons - Sunroof - Sensors - 17" Pegasus - Island Green - MFD2 - OEM Bluetooth Kit - Colour coded grille
flickr Photos
sworrall is offline
Old 14-05-2008, 13:54   #6
whoosh's Avatar
Well done
I took the easy way got a spare grill from ebay removed the crome surround and took it to a body shop that did the crome grill on my last mk1 vrs lot less hassle.
Hope you get ok
Regards Whoosh
black magic octavia vrs,jumbo box,18"s,dual zone climate,oe window blinds,connects 2 ipod connection,xenon conversion kit,black grill,painted logo steering wheel,parrot bluetooth
whoosh is offline
Old 14-05-2008, 15:47   #7
Weak Effort.
djgritt's Avatar
Managed to get use of the Blaster at work today, so use that to remove the remaining Chrome, and to key the Plastic underneath
Also managed to get the afternoon off, so have managed to get the Primer and Black Magic coats on (Sun is beating down here - drying time is immense!)
2 Coats of Black so far, one more then some Lacquer me thinks...
At this rate, it'll be good to fit tomorrow at some point...
djgritt is offline
Old 14-05-2008, 15:48   #8
Weak Effort.
djgritt's Avatar
Yes, yes they are
It is a tad sharp
djgritt is offline
Old 14-05-2008, 16:24   #9
Get out the way
Taxi 219's Avatar
Coming along quick...nice work.Thinking of doing mine but not sure what it would look like in Metallic Flamenco Red
Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged
Previous: 06 Octavia Mk1 1.9TDi Classic with + pack
Sadly missed: 97 Nissan Primera 2.0TDi SLX
Taxi 219 is offline
Old 14-05-2008, 19:02   #10
Weak Effort.
djgritt's Avatar
Well, everything went OK in the end - a couple of small blemishes, but what do you expect for a DIY job by a non-pro... Still, im happy with it!
Even managed to get it on the Car this evening
Sex wee all over the place!
1000000000x better than before IMO - Skoda should have done this as OE!
This has to be a "Must-Do" mod for the Octavia II
djgritt is offline
The Following User Says Thank You to djgritt For This Useful Post:
sworrall (14-05-2008)
Old 14-05-2008, 19:20   #11
Get out the way
Taxi 219's Avatar
Very nice and a huge improvement on OE.Especially Black
Taxi 219 is offline
Old 14-05-2008, 19:30   #12
Fezboy's Avatar
Yes that's so much better!
I bottled out and got mine sprayed by a body shop
Octavia VRS
A standard looking car with a twist of Impossible Performance
Hertfordshire South Mimms & Pub Meet 25th Sept DETAILS HERE
Marlin Rolling Road Day 13th Sept DETAILS HERE
Fezboy is offline
Old 14-05-2008, 19:31   #13
yeah well done, looks really nice dechromed, much meaner, anyone done a silver 1 yet ?
wudzy is offline
Old 14-05-2008, 19:33   #14
2.0 FSI Sport.
smstext's Avatar
i keep meaning to do mine, just need to find a body shop who will do the spraying for me.
smstext is offline
Old 14-05-2008, 19:47   #15
dan_the_v8man's Avatar
hmm im wanting to do it, in two minds whether have a go my self or not
57 Mk2 2.0TFSI vRS Estate in Race Blue, jumbo box, cruise control, dual zone climate, zenith 18", maxidot, xenon's, rear parking sensors, light assistance, sunset glass
dan_the_v8man is offline
Old 14-05-2008, 22:05   #16
sworrall's Avatar
looks like a great job. it always looks best when done on black cars
flickr Photos
sworrall is offline
Old 14-05-2008, 23:29   #17
Funkycat's Avatar
Recently bought my vRS from a dealer, previous owner had done this to it, I wasn't sure to start with, but now I like the "stealth" black look it has!
See for yourself.
Funkycat is offline
Old 15-05-2008, 14:27   #18
Mac Monkey
moox's Avatar
Has anyone done this on a Race Blue vRS? Would love to see a pic of how it looks!
moox is offline
Old 15-05-2008, 16:59   #19
ditto
Old 15-05-2008, 17:27   #20
cheezemonkhai's Avatar
I don't see the point on silver myself.
It gets enough stone chips down there as it is.
cheezemonkhai is offline
