This is a discussion on Condensation in Zenons within the Octavia II forums, part of the Skoda Model Discussion Area category; After rain there is a small amount of condensation at the bottom on the headlamps which after time disappears. My ...
| Briskodian Join Date: Dec 2005 Location: SOUTH EAST UK
| After rain there is a small amount of condensation at the bottom on the headlamps which after time disappears. My dealer says that this is normal but if it becomes excessive then it is not. Is what my dealer saying correct or is the dealer just trying to avoid a warranty claim? If Ok at what point does the condensation become abnormal? |
| I did notice a bit in mine at the start but havn't really noticed it since. I could be wrong but I would have thought there shouldn't be any, its a sealed unit. I'd be interested to hear of any updates with it.
__________________ GAFF ![]() Briskoda Ireland Events, Meets & Pictures.....Race Blue Octavia MkII vRS.....Old Octavia MkI vRS |
| Briskodian Join Date: Jun 2006
| It may have something to do with the fact that Xenon lamps are gas filled (when lamps are on the gas burns giving the blueish tinge). Perhaps when the humidity outside the lamp gets to a certain level the gas in the lamp causes the condensation. Am not certain but just a thought. |
| I wouldn't have thought there should be any liquid in there. The gas in the light 'bulb' won't have any water in it, or shouldn't so you shouldn't get air in it. I'm assuming you mean the housing, but even so I'd still be supprised. If you get an arc lamp from a cinema projector wet it will explode, so I would be double checking with another dealer on the sly if you can.
| Briskodian Join Date: Sep 2004 Location: London
| Thought there was a recall / fix for this ??? |
| Briskodian Join Date: Mar 2004 Location: preston
| It should be a sealed unit like mentioned before. I dont have any condenstation in mine, but my car doesnt live outside during the night. The zenons on my bmw sometimes had a little misting condensation when they had been on for a bit when it was cold outside. Never had anything excessive though! I would be tempted to ring Skoda Customer service and tell them you arent happy and you want it sorting - if they agree then you dealer should just do the job |
| Briskodian Join Date: Aug 2005 Location: Back in the Green
| I don't think there should be any moisture in the lamp unless a seal has been compromised. Do you have any chips/cracks on the plastic cover that could let rain in? The xenon gas discharge effect won't cause any sort of condensation either. Have you tried a search of the forum to see if this has come up before? If the condensation is at the bottom of the light fitting it might also affect halogen lights too.
__________________ MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely! SWMBO's: MY08 vRS TDI - Standard ![]() |
| I don't leave the car outside - I garage it and its only 3 months old. I did contact skoda uk as the dealer said it was normal I wasn't convinced. Their reply was: With regards to condensation on xenon headlights, misted up headlights > (without visible condensed water drops caused by moisture ingression) > are natural and permissible from the viewpoint of the headlamp design. > > The vent holes in the headlight body provide natural ventilation during > operation. However, the speed and the time of demisting depends on the > current atmospheric pressure, the temperature and the relative humidity > of the environment. |
| Briskodian Join Date: May 2005 Location: Southampton, England
| Having hasd a xenon Hid equipped car before, I would suggest that this is quite normal. This is mainly because the lamp source does not get nearly as hot as an incandecent lamp in a conventional headlight. Remember that an Hid lamp consumes less than 35 watts, and is much more efficient at turning the electrical input into light and not heat. Therefore there is less heat in the lamp unit to evaporate the condensation. You could just check that the rubber vent tubes at the back of the headlamp are not pinched though. This would not allow such efficient equalisation within the lamp unit with regaqrd to temperature and humidity etc. |
| | #10 |
| There is a recall on some headlights to cap the front vent hole.
__________________ Unit 18 Automotive Services now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| | #11 |
| how does one know which headlights are being recalled? |
| | #12 |
| Open your bonnet. In the corner of the headlight there may well be a rubber bent pipe, or at least a tube that sticks out. Have a look up this tube with a torch, if its blanked its ok. If its open it should be sealed up. But your dealer will be able to tell you if its due the recall.
