This is a discussion on Contradiction in manual within the Octavia II forums, part of the Skoda Model Discussion Area category; This is probably an indication of a mild OCD disorder, but I do like to read car manuals, especially on ...
| Briskodian Join Date: Sep 2006 Location: Ipswich
| This is probably an indication of a mild OCD disorder, but I do like to read car manuals, especially on one newly acquired. ![]() Browsing through the Octy II manual, an amazing tome, I don't think I have met one so thick before, I came across these apparent contraindictions :- Page 259 Working on the Battey "Caution ! You must only disconnect the battery if the ignition is switched on, otherwise the electrical system (electronic components) of the vehicle may be damaged." Then goes on to say what order to disconnect.reconnect the terminals. This struck me as odd, but read on ![]() Page 260 Charging the battery. "- Read the warning notes in "Working on the battery" on page 258 - Switch the ignition and all electrical off" So which is correct ??? My guess is the second, on general logical terms, but it seems a direct contra-indication. |
| Briskodian Join Date: Jan 2004 Location: Up a tree.
| Only disconnect the battery with the ignition switched on. Thats what a well respected Skoda technician told me once. Incidentally, most people come here because they've not read the manual - so I doubt anyone else has noticed ![]() |
| | #3 | |
| Quote:
![]() Chris
| Always re-connect it with the ignition on too |
| | #5 | |
| Quote:
dont do it with the ignition switched on otherwise you'l get sparks! also if there's a short somewhere it could be potentially fatal
__________________ vorsprung durch czechnik Last edited by TeflonTom; 07-11-2006 at 15:32. | |
| Yes why indeed?? There has to be a logical explanation, but I would think there would be a risk of voltage spikes etc. if you disconnect with the system live? |
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
| I was always told to disconnect and reconnect with it all off; I always make sure I have the keys in my pocket so I know it cannot be on.
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() |
| Interesting, forum users so far seem to be equally divided on the issue! There must be a right answer, unless of course it doesn't matter a toss what you do as long as you are careful with disconnecting and reconnecting the battery tereminals. |
| Briskodian Join Date: Aug 2005 Location: Back in the Green
| I personally wouldn't want to hook up or disconnect a battery that will have an instant load on it thank you very much.
__________________ MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely! SWMBO's: MY08 vRS TDI - Standard ![]() |
| | #10 | |
| Quote:
![]() ![]() ![]() Chris
| | #11 |
| also there's a possibility that the airbag( if fitted) can deploy too
__________________ vorsprung durch czechnik |
| | #12 | |
| 200/370 Join Date: Oct 2004 Location: Around Manchester & Cheshire
| Quote:
![]() Must be a good job writing these! ![]() Steve
__________________ Wardy's Fabia vRS ![]() xenons : sunroof : cruise : OEM+ ![]() "Racing is life. Anything before or after is just waiting." - Steve McQueen "If in doubt, flat out." - Colin McRae | |
| | #13 | |
| Quote:
I had a new Civic as a works hire car the other week. 504 pages I think that one ran too, and that was all in English and apparently just for the 5dr varient ![]() Must be a good job writing these! ![]() [/off-topic] I'd much prefer to connect it when I knew nothing was going to magically spring to life the second I made the connection! Steve
| | #14 |
| Ignition off, no way would i ever connect something that can put out 60A to a system that could be drawing a fair amount from it. Also, I would have thought the airbags wouldn't like it and that the warning is wrong otherwise the car could not cope with a flat battery.
| | #15 |
| Disconnect after turning off ignition for sure. The car (ECU in particular) has detection for low/no batt anyway, the only time it causes problems is when you are (re)mapping a car and the battery drops below a certain voltage. That however is only critical for remapping, during normal operation you will be protected against it ![]()
__________________ WW --->> Project Journal (pic links in first post there)Lummox'/Ross thread on Unit18 Automotive progress on my car: here |
