39,459 Members 1,489,960 Posts
Correctly use 6-speed gearbox
This is a discussion on Correctly use 6-speed gearbox within the Octavia II forums, part of the Skoda Model Discussion Area category; My first time owning a six speed gearbox. What's the best speeds to change into each of the 6? I've ...
Old 21-04-2007, 22:35   #1
Go Gadget Octy!
Members Car:
What's the best speeds to change into each of the 6? I've been using the normal 1-5 speeds, and using 6th at either 60 or 70 for the steady motorway cruise.
Is this the correct way, or does someone have a good speed/gear guide? I'd have thought it'd be in the manual.....
EDIT: For the petrol 2.0 FSI if that makes any difference.
gadgetman is offline
Old 21-04-2007, 22:44   #2
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
Re: Correctly use 6-speed gearbox
Use sixth as if it were fifth. It's not what might have been termed many years ago as an overdrive, it's just another gear.
Use it whenever you and the engine are comfortable with it.
Stu
VRStu is offline
Old 22-04-2007, 00:25   #3
Members Car:
No offence intended but is this a serious question? Driving the car will tell you when and what gears are required to fit the circumstances appertaining. The additional info provided by the rev counter will give you a head start but basically you should very soon 'know' what gear you want to suit what you expect the car to do. There ain't any manual that will tell you.
Spence2 is offline
Old 22-04-2007, 00:33   #4
Go Gadget Octy!
Members Car:
Unhappy Re: Correctly use 6-speed gearbox
Yes it was. I was after a guide/others ecperience, really to get the best performance etc out of the engine.
Basically I was unsure as the changes are earlier than a 5 speed, as I can't 'feel' any difference between 5th or 6th. Both seem the same revs/engine noise wise
to me.
I'd rather break in he gearbox & engine correctly as I've done with my previous new cars.
Old 22-04-2007, 11:57   #5
irin's Avatar
Members Car:
I have a tdi engine with 6 speed gear box and I change up the gears at 2500 rpm
and down at 1500 rpm
I use to change the gears in the petrol cars at 3000 up and 2000 down.
Sometimes I go to the red zone (up-hils , overtecking , hi speeds)
Everibody has his personal way of driving !
irin is offline
Old 22-04-2007, 12:56   #6
dstev2000's Avatar
Use the gears of your car to keep the engine in it's peak torque band.
Or cane the *** off it from 1st to 4th then block change to 6th and ignore 5th
MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely!
SWMBO's: MY08
vRS TDI - Standard
dstev2000 is offline
Old 22-04-2007, 13:28   #7
mello in yello
postmanpat's Avatar
Members Car: fabia vRS/ octavia vRS
Or look upon 6th gear as the vtec zone.............. hit 6500 in fith and then change up woo hoo another 1000 revs or so to play with
Originally Posted by Emily-Elizabeth
Sperm donership: It is not like giving blood, it is tossing away...............
Postmanpats car Fabia vRS Zennons, ESP, autochanger, 3rd headrest, heated seats, cruise control
SWMBO Octy Mk2 vS maxidot, duel zone wotsit, cruise, parking sensors, 18" alloys
postmanpat is offline
Old 22-04-2007, 16:22   #8
Members Car:
to me.
In which case I will copy my brief comment from a previous topic:
I was brought up to use the engine when running in but with care. Prolonged full throttle no but let the engine run freely not using imposed rev limits that can mean the engine is laboured because drivers slavishly try and stay below those limits. Car empathy is the most appropriate term, you sense the load and effort being placed on the vehicle and use the engine and gearbox to provide the 'kindest' combination to deal with that load.
Spence2 is offline
Old 22-04-2007, 16:49   #9
Harry_vRS's Avatar
Members Car: Skoda Octavia vRS Mk2
And how fast would you be going if you were doing 6500RPM in 5th
As said, just use which gear feels right for the load.
Harry_vRS is offline
Old 22-04-2007, 17:39   #10
mello in yello
postmanpat's Avatar
not as fast as 6500 rpm in sixth hth
Old 22-04-2007, 20:10   #11
Go Gadget Octy!
Members Car:
Thanks folks.
Old 23-04-2007, 05:41   #12
Hardcore
Basil's Avatar
Members Car: Fabia vRS
As Stu points out, the 6th is just another gear, use it as such, it's not an overdrive....
I remember searching through the posts when I first got my Fabia vRS, looking for the best way to run in the car.
Few points that I seemed to find:
two schools of thought about running it in - drive carefully and not staying at a particular rev level for long (like a petrol). OR driving absolutely normally when warmed up... Peeps claimed no diff over the car's life...
For a diesel, the important thing is that they don't warm up at idle, they need load to warm up so drive off gently right after starting up.
Also Diesels are built pretty much "bulletproof", they only start to be really run in after about 10-15K, so basically don't sweat it about running in too much...
You'll notice a better mpg only after the 10-15K, and if your geark0b rattles at first, this will settle after this period as well...
Enjoy your new car and however you do it, it'll run itself in a treat!
(Probably more info than you really wanted, but I understand what you're really asking.)
HTH
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is online now
Old 24-04-2007, 19:08   #13
I stick mine in 6th as quick as I can, engine pulls quite happily from 1500rpm, only drop if I need faster quicker if you know what I mean
justdoit is offline
Old 24-04-2007, 20:00   #14
www.oscarli.com
Shifty's Avatar
Members Car: Skoda Fabia vRS
Images: 1
Running in tip - once the engine is warm, drive it as you would any other car. Diesels respond better to a good kicking
Old engines needed running in. New engines don't. I ran my ex work's DAF XF430 space cab in by loading it up to it's gross wieght of 44 tons, and going somewhere far away with it. I also kicked its head in, and it out pulled the other dafs on the fleet weight for wieght as they were generally on lighter work.
Dervs love a load.
Official 0 to 60 mph - 5.85 seconds. Standing 1/4 mile - 14.3 seconds. 251.5 BHP and 400 lbs/ft of torque. Oh - and 55 mpg on a run
My car is for SALE!!
Shifty is offline
Old 24-04-2007, 23:11   #15
Members Car: '02 SEAT Leon Cupra
Similar usage here - when I'm not driving hard I change up between 1500 and 2000rpm. Doing that over a weekend away at the coast (once I was off the motorway on A roads) I averaged over 60mpg in my 2.0TDI.
I find that giving it some welly now and again (usually when the wife's not with me ) cleans out the pipes and still gives 50+ mpg.
Never thought I'd say this but I'm really glad I bought a diesel.
unclerichy is offline
Old 25-04-2007, 11:08   #16
pretty sure thats it's not really the revs that eat fuel but the throttle you use if that makes sense. i.e. on slight upwards hill 3000rpm and very light throttle much better than 1500rpm and half/full throttle with a labouring engine.
smerko is offline
Old 25-04-2007, 15:50   #17
Members Car:
LOL that would be me. 5th gear now seems a little pointless.
Krispe is offline
