This is a discussion on Dual Climate cutting out within the Octavia II forums, part of the Skoda Model Discussion Area category; Has anyone had a problem with their dual climate control cutting out? if so how did you sort it? Is ...
| Briskodian Join Date: Mar 2004 Location: preston
Members Car: skoda octavia vRS II Thanks: 1
| Dual Climate cutting out Has anyone had a problem with their dual climate control cutting out? if so how did you sort it? Is there a batch of faulty compressors for example? |
| Briskodian Join Date: Jun 2005 Location: south east
Members Car: 2005 2.0FSI hatch elegance Thanks: 9
| Re: Dual Climate cutting out How do you mean, "cutting out"? |
| | #3 | |
| Re: Dual Climate cutting out Quote:
I start the car and the climate control is set to say 18C. When it is hot outside and it need to put on the blowers full wack it stops. The lights showing the fan speed are still right over to max but the fans have stopped. However this doesnt happen all of the time. When its not so hot outside and the system doesnt need to work as hard, it doesnt cut out at all - even if i knock the temp right down, | |
| Re: Dual Climate cutting out Is that with "Auto" set? |
| Re: Dual Climate cutting out yeah - set to auto |
| Re: Dual Climate cutting out The only thing I've come across on mine is that sometimes when I press auto, I notice the temp figure has gone to 72. I turn it down to 60 or "lo" and it all gets going. But yours does sound more like a fault. When it cuts out, see if the temp figure that you set has changed to a high one. |
| Re: Dual Climate cutting out i know its a fault and its in the local garage. they dont know how to fix it. I was after someone with some experience of this happening really. |
| Briskodian Join Date: Jul 2005 Location: Northern Ireland
Members Car: MkV Golf 1.9 TDI Thanks: 0
| Re: Dual Climate cutting out I've heard of it before on here. I think it's just a fan fan fault of some kind.
__________________ Johnny "Americans have different ways of saying things. They say "elevator", we say "lift" ... they say "President", we say "stupid psychopathic git." |
| Briskodian Join Date: Nov 2004 Location: Camberley
Members Car: 2001 Octavia L&K 1.8T Thanks: 1
| Re: Dual Climate cutting out If it were a BMW I would say it was the CC resistor pack. I would assume Skoda CC would have a similar system for controlling the fan speed. |
| | #10 | |
Having said that I would say the Skoda speed control system is probably more complicated than that.
__________________ Johnny "Americans have different ways of saying things. They say "elevator", we say "lift" ... they say "President", we say "stupid psychopathic git." | |
| | #11 |
| Re: Dual Climate cutting out turned out to be the controller unit behind the dash which has its own little computer to control the climate. Swapped out and it seems to be working fine again now |
| | #12 |
| Briskodian Join Date: May 2005 Location: Southampton, England
Members Car: Skoda Fabia VRS and Skoda Octavia II 1.9 Tdi Thanks: 9
| Re: Dual Climate cutting out Good stuff, gald you're sorted! |
