This is a discussion on Engine compartment mud and salt within the Octavia II forums, part of the Skoda Model Discussion Area category; For some time I've been bothered about how filthy the engine and under bonnet areas get. It seems that there ...
| Briskodian Join Date: Jan 2004 Location: Wirral, Merseyside
| For some time I've been bothered about how filthy the engine and under bonnet areas get. It seems that there is no sealing on top of the radiator housing. I experimented with various things and found that a length of 22mm pipe insulation zip tied above the radiator seems to work. I also pushed two short lengths of insulation into the gaps between the headlamps and the radiator area. It all looks a bit crude but certainly worked in the last week when local motoways were very wet and salted. The attached photos hopefully show the idea. |
| Briskodian Join Date: May 2007 Location: north wales
| Good idea that I like the stone catcher too I have one on the bottom grill save them hitting the cooler |
| Briskodian Join Date: Jan 2008 Location: Fife, Scotland
| Yes, good idea. They have put an undertray on the cars to stop crud coming up but then it gets in through the front anyway, seems a little daft. The 06 Navara I used to drive had a rubber seal (as you get on the doors) all the way round the bonnet area to do what you have achieved and that really did work well. Steve
__________________ Brilliant Silver vRS TDi Hatch,Maxidot,Light Assist,Cruise,Park Assist, Jumbo Pack,OEM Bluetooth Kit, Vag-Com Micro-Can. |
