This is a discussion on Fixed towbar and Reversing Sensors? within the Octavia II forums, part of the Skoda Model Discussion Area category; I'm looking at fitting a towbar on my 04 plate mk2 Octy and am wondering if there are any fixed ...
| Briskodian Join Date: Mar 2004
| I'm looking at fitting a towbar on my 04 plate mk2 Octy and am wondering if there are any fixed towbars which are less likely to cause issues with the reversing sensors. I have been doing some searches on the forums but other than a few comments I haven't found an answer. Ultimately I just need a bar that is functional, it doesnt have to be stylish or removable (unless having a fixed bar with reversing sensors is no good). I assume that for the best chance for the bar to be ignored a swan-neck bar would be best? Does anyone have any experience of the fixed bars with sensors and have any useful advice? ![]() |
| Briskodian Join Date: Jun 2007 Location: Dundee
| The fixed towbar supplied by Skoda should be okay. My Scout has rear parking sensors and they are not triggered by the towbar fitted by the dealer.
__________________ Fabia 1.2 70bhp in Black Magic Pearl. Octavia Scout TDi in Satin Grey |
| Briskodian Join Date: Jun 2007 Location: Darn Sarf
| Briskodian Join Date: Nov 2007
| Have fixed towbar by Witter and on our 55 plate A5 Elegance it causes problems such as continouse to bleeping when nothing is there. Solution , get Skoda detachable or Witter etc detachable. |
| | #5 | |
| Briskodian Join Date: Jun 2005 Location: Scotland
| Quote:
A Skoda dealer "local" to me has quoted £550 inc fitting to fit a detachable bar to my Scout with the official loom and single electrics. As I'll have the car for a while I'm prepared to stump up so that it all works at it's best. Still one problem though - still need to find £550.............. Niall
__________________ 07 Octavia Scout TDi -------------------------- All the Scout standard toys + Xenons, MFSW, Maxidot, Curtain Airbags, OEM Bluetooth. | |
| Briskodian Join Date: Aug 2007 Location: Barnsley
| I have a detachable brink fitted to mine, but causes no problems when its fitted at all. Hope this helps. |
| | #7 | |
| Quote:
Niall
| A colleague has an Octavia Elegance with permanant Brink towbar and has no problems whatsoever. Looks quite tidy for an always there install too. ![]() |
| | #9 | |
| Quote:
Niall trying not to sound like a broken (but inquisitive) record! ![]()
| | #10 |
| Cuthbert Dibble Join Date: Apr 2006 Location: Watching Tom peeping at Lady Godiva.
| I had a fixed towbar to start with but it caused intermittent problems. I now have a removable but bizarrely enough it doesn't set the sensors off when fitted.
__________________ ![]() I drink, therefore I spam. |
| | #11 |
| I have a question.....................
| | #12 |
| Thanks for the replies so far ![]() I second Nialls question though, for those saying that you had a detachable bar that caused no issues when it was in place, do you know which wiring loom you were using? Was it a full Skoda one or a bypass relay? I have been searching on the VAGCOM forum and can't see how to tell the car that you have a towbar fitted, anyone have any advice on this? |
| | #13 |
| Briskodian Join Date: Dec 2005 Location: Cruising the M65
| Might be a bit different on a Scout as the bar sits lower than the sensors, due to the ride height. ![]() ![]()
__________________ ![]() Ants |
| | #14 |
| Briskodian Join Date: Oct 2006
| Hi all, I have a Brink Fixed Towbar fitted to my 56 Reg Octavia Estate. I have had a look and the electrics are brink, and I had the swan neck bar fitted. When I booked it in for a fitting, I was concerned about the reverse sensors, which they couldn't guarantee, and I had to sign to say I knew this and abou the Bumper cut (not visible unless you are under the car). The sensors do still work as before with no interference, the only thing to remember when needing them in close moves is that the bar is about an inch away on solid bleep. The only other downside is when you are reversing the trailor the beep is very annoying, so no long reverses for me! Pictures below, I paid for reference £175 inc Vat for everything fitted and took about 2 hours from drop off to collection. Using Indespension (if I can mention them?) ![]() ![]() Hope this helps Ian |
| | #15 |
| Briskodian Join Date: Sep 2007 Location: Cheshire
| I had a tow trust detachable flange towbar fitted to my 06 Elegance. Left in place it has caused no trouble at all. The advantage of this system is that if the fixed ball did cause trouble to your car, the detachable flange is a straight swap. All fitting and electrics are not affected. Interestingly, it was fitted by a local mobile fitter who I’ve used many times over the last 20 years. He always fits all VAG cars WITHOUT any bypass. – Just a straight clip-in. The piece of kit he had was much more than the old scot locks clips (or however they’re spelt) Since fitting, the car has been serviced and I specifically asked for the electrics to be vag com tested and they told be everything was fine. Even thought the following firm didn’t fit the bar, they were most helpful in providing advice. Cheap too! http://www.towbarsdirect.co.uk/homepage.htm and http://www.towbarsdirect.co.uk/products/towbarmakes.htm#TT |
| | #16 |
| Briskodian Join Date: Jun 2008
| I've just had a fixed Witter towbar with twin electrics, Alko towball and protective plate fitted by Fast Fit to my new Octavia Elegance 1.9TDi Hatchback. At first I thought there was a problem - sensor would bleep every time the car went into reverse. Took it back to Fast Fit - first removed the tow ball cover (no change) and then after a brief discussion tried moving the "wings" of the protective plate back each side and, hey presto, no problem any more. Regards John R |
| | #17 |
| Briskodian Join Date: Mar 2008 Location: Barnsley
| I'm trying to order a bar for my Octy. Dealer in Leeds needs some assistance about this. What does he need to fit/do so the reversing sensors turn off when a trailer is connected? Is it VAGCOM or CANBUS or both?
__________________ Elegance 08 Estate 2.0 TDI - Metallic Silver, Child friendly version - blacked out rear windows, curtain airbags, boot liner, Isofix child seats |
| | #18 |
| Briskodian Join Date: Feb 2008
| I've a dealer fitted Brink & the sensors are fine with no caravan attached. But; that bloody bleeping when reversing the van is very, very annoying. There seems to be no way of silencing it. |
| | #19 |
| go green Join Date: Jan 2005 Location: Rochester, Kent
| We had that aswell, fixed it by getting a motor mover for the now departed 'van. best invention for a 'van ever. And yes i can reverse a car and 'van with no trouble. I think the sensors can be turned off with vag-com when the electrics are plugged in. |
| | #20 |
| Yes sensors can be switched off via VAG COM. I also got the dealer to disable the rear foglight when connected to the van to reduce the red glare when towing in the dark or in foggy conditions.
