This is a discussion on Kerb View Mirror within the Octavia II forums, part of the Skoda Model Discussion Area category; On our L&K DSG with memory seats and mirrors, the left-hand mirror tilts down when you select reverse to give ...
| Briskodian Join Date: Jun 2005 Location: Canterbury, Kent
| On our L&K DSG with memory seats and mirrors, the left-hand mirror tilts down when you select reverse to give you a view of the kerb. An excellent idea, and one which helps avoid scuffed wheels, but when you change into drive it stays tilted down for 15-20 seconds - not only a nuisance but dangerous if you need the mirror to check for traffic. Is this delay normal, or should I mark it up for attention at the dealer? |
| Ho Hum Join Date: Jan 2006 Location: Not here
| It's to give you time to set your trilby at a jaunty angle and light your pipe Seriously though it sound like too long a delay.
__________________ I turned the light off............. |
| | #3 | |
| Briskodian Join Date: Jul 2005 Location: Northern Ireland
| Quote:
__________________ Johnny "Americans have different ways of saying things. They say "elevator", we say "lift" ... they say "President", we say "stupid psychopathic git." | |
| | #4 | |
| Briskodian Join Date: Apr 2006 Location: Craggy Island Parochial House
| Quote:
__________________ It doesn't make any difference who you vote for. The Government always get in.... | |
| Briskodian Join Date: Dec 2005 Location: SOUTH EAST UK
| I have an L&K and I haven't noticed the left hand mirror tilting down at all. Do you have to set this in a down position using one of the seats memory settings or should it do it automatically? If the latter can you adjust how much it tilts down? |
| | #6 | |
| Quote:
| Briskodian Join Date: Jun 2005 Location: south east
| The other odd thing is if you set the control for nearside, only it moves, but if you set it to do driver's side. both move together. So apparently you have to set the driver's one where you want it first, then alter the nearside alone if it isn't right. |
| | #8 | |
| Quote:
(Exits grumpy old man mode and heads for bed and horlicks - well, actually a large scotch) | |
| Briskodian Join Date: May 2005 Location: Southampton, England
| To Quote the manual............ Tilting surface of front exterior passenger mirror "When the rotary **** is in position R, and the reverse gear is engaged, the surface of the mirror tilts down slightly. This provides an aid for seeing the kerb of the pavement when parking the car." Furthermore: "The mirror returns back to its initial position, if the speed is more than 15Kph, opr the rotary **** is moved out of position R and put in another position." I think that this is reasonable clear. |
| | #10 |
| Briskodian Join Date: Feb 2003
| I test drove an Elegance trimmed Superb, and had this feature. Being someone who has correctly adjusted mirrors, I thoroughly hated this option. I found it caused a lack of vision and awareness.
__________________ Andy Owner of a sense of humour. |
| | #11 | |
| Quote:
| | #12 | |
| Briskodian Join Date: Oct 2004 Location: Northern Ireland
| Quote:
If you still insist on wanting to change the settings, can these not be changed by VAG-COM or at your local dealers, the same way you can amend the central locking settings, alarm/ immobilisor settings etc?? JD
__________________ Octy Elegance TDI (110bhp) | |
