This is a discussion on Max speed for gears within the Octavia II forums, part of the Skoda Model Discussion Area category; I'll be getting my 2.0 TD pdi soon and was wondering if someone would tell me the max speeds for ...
| Briskodian Join Date: Jan 2004 Location: Lincs
| Max speed for gears I'll be getting my 2.0 TD pdi soon and was wondering if someone would tell me the max speeds for the 2nd 3rd and 4th gears - or the mph/1000rpm would do. Thanks. |
| Briskodian Join Date: Sep 2004 Location: Near Selby, North Humberside
| This information is not available in any of the glovebox data. I could work it out for you given a quiet enough road although i'd do it at 2000rpm and hope that the tacho is accurate.
__________________ -- Simon Houghton Octavia II, Elegance with toys Westfield SEiGHT in garage |
| Briskodian Join Date: Feb 2005 Location: Morayshire, Scotland
| Put it this way, it doesnt like sixty in second! Going to overtake and block changed from 6th to 2nd, instead of 4th. Luckily realised and dipped clutch as revs hit 5,000. Seems to be no damage done.
__________________ Octavia Elegance 2.0 PD TDI Island Green Metallic; Onyx Leather Interior; Pegasus 17" Alloys/Sports Suspension |
| Doh..... why were you going for 4th? 5th at 60 would've been well into peak torque and given you longer in gear (and that's not a criticism)
| | #5 | |
| Quote:
__________________ Octavia Elegance 2.0 PD TDI Island Green Metallic; Onyx Leather Interior; Pegasus 17" Alloys/Sports Suspension | |
| go green Join Date: Jan 2005 Location: Rochester, Kent
| The wife tried to change down under brakeing from 6 to 5 but got 3rd instead luckely relised and dipped the clutch before to many rev's |
| Briskodian Join Date: Jun 2004 Location: Leeds, West Yorkshire
| I still find switching down gears useful, sure you may have more torque but in my remapped furby I have 195 hp to play around with at 3.5k rpm ![]()
__________________ Metro Blue '06' 5 Door Astra 1.8 SRi |
| tried a little experiment last night on my private test track... from 60-100 in 4th was 13.7 seconds in 5th is was 15.2 seconds 60-90 would favour 4th even more as it was starting to run out od steam around the ton. So, You were right to change to 4th for best pull at 60. As for the max speeds. I'll do a proper simulation but at 4500rpm the max speeds for each gear are APPROX... 1st - 27 2nd - 47 3rd - 74 4th - 103 5th - 128 6th - 151
| Thanks Studbuckle for the info. Just for interest sake, if you were overtaking with a starting speed of 50mph would you do it in 3rd or 4th? i.e. start in 3rd then change to 4th at about 70mph or do the whole thing in 4th? |
| | #10 | |
| Quote:
| | #11 |
| ditto. 3rd would give you the best acceleration but you'd be wanting to change up to 4th at 60 which would come pretty quickly. Depends how long you're going to be in the danger zone. There's a compromise between fast acceleration and having to change gears mid overtake. The latter should be avoided wherever possible
| | #12 |
| Briskodian Join Date: Mar 2004 Location: South East UK
| Or you could buy a car with the DSG gearbox which would look after the gears for you............until it exploded mid-overtake ![]()
__________________ Patrick Octy II Elegance 2.0PD TDI DSG Flamenco Red Maxi-dot Multifunction Steering wheel Light Assistant Towbar |
| Tyre Numbers | eatsoot04 | Maintenance & Performance | 14 | 21-12-2004 21:20 |
| Speed Cameras - Alistair Darling asked to resign | ColinD | General Car Chat | 5 | 03-09-2004 13:19 |
| Hey Big Boy, Max Your Driving! | ColinD | General Car Chat | 0 | 14-07-2004 23:01 |
| 2005 Ford Gt Joins Ranks Of World's Fastest Cars With A 205 Mph Top Speed | ColinD | General Car Chat | 0 | 14-06-2004 20:27 |
| Technical Data | the_ape | Maintenance & Performance | 23 | 14-05-2004 19:43 |
