maxidot menu
This is a discussion on maxidot menu within the Octavia II forums, part of the Skoda Model Discussion Area category; Hi, i have changed the steering wheel and the steering unit. The problem appeared when installing again the original one ...
Old 20-04-2008, 18:09   #1
Default maxidot menu
Hi, i have changed the steering wheel and the steering unit. The problem appeared when installing again the original one ( due to skoda airbag does not fit in gti steering wheel and horn kept on sounding even without airbag). The only thing which does not work is the maxidot menu. I can only see board computer data, and pass trough the different values but when i press the wipper button nothing appears on maxidot. Vag-com does not report any error and code is the same it had before changing unit. Even if i use the navi, it appears on maxidot and if i press wipper button it returns to board computer, so i think it works. Can anyone help me, please? It doesnīt mind so much because i am changing airbag soon but it is a matter of curiosity.
Thanks in advance and sorry for my English
mmfvk is offline
Old 20-04-2008, 21:00   #2
Briskoda Staff
VRStu's Avatar
Default Re: maxidot menu
Have you added a MFSW (With Buttons)
What code is in your steering controller?
Also what is the part number of the steering controller?
Stu - Freedom Pimp
Stu's Car - Hmm, Have a guess......
VRStu is offline
Old 20-04-2008, 22:28   #3
Hi, thanks VRStu. Maybe i have not explained it correctly. I had to replace the new AG unit by the old one a BC because my skoda irbag did no fit the new Steering wheel, so i place the skoda steering wheel and BC unit. The Bc code is 42 (the one it had before changing it) and cruise control as well as wippers and so on works properly but i can enter maxidot menus to change time, and so one. With new MFSW all worked fine but airbag did not fit so i had to go back.
Thanks
mmfvk is offline
Old 20-04-2008, 22:48   #4
Briskoda Staff
VRStu's Avatar
The coding looks ok. 0000042 is for Cruise and Onboard Computer with Rear Wiper.
I would suggest that you remove and refit the steering controller making sure that all connections are made correctly. I have seen this before with an indicator stalk.
Stu - Freedom Pimp
VRStu is offline
Old 21-04-2008, 06:55   #5
That is only what i think, because the pins on the board seem too weak and you have to be carefull when fitting them into de plastic cover so maybe any of them is disconnected or even broken.
Thanks
mmfvk is offline
Old 22-04-2008, 18:53   #6
Hi, I have checked the steering unit, and every pin seems in good condition, even i have disconnected battery for 10 minutes and joined +/- pole in order to discharge residual tension and all is the same. With the MFSW i could enter maxidot menu without problem. The only thing i see is that i cannot enter adaptation in the steering unit ( i donīt know if i shoul) and in measure blocks (i think) the multifunction display appears as something like non opperative but i can see BC values and i can pass through them. Moreover i have changed time by entering module 17 because i cant do it other way.
Strange, isnīt it?
mmfvk is offline
Old 07-10-2008, 18:32   #7
mrbrunodk's Avatar
mmfvk: Have you solved the problem ? I have the exact same problem.
Skoda dealer tried to install a MFSW but without any luck.
And installed the old steringwheel again, after that i can only change between milage, time, temp and so on.
When start a new route on the navi or the phone rings it comes up on the maxidot.
When i press the button on the wiper stalk the maxidot change immediately before it was when i released the button
Henrik
Car: 2006 Silver grey 1.9TDi Combi, Elegance, Front and Rear parking sensors, Dualzone clima, Jumbobox, Xenon, Maxidot, Columbus, Stu's OEM Integrated Bluetooth Telephone
mrbrunodk is offline
Website Đ 2002-2008 BRISKODA ltd & SUMMIT360 ltd E. & O.E.
